Hello all, I have a presumably SAMSUNG UN50F600 (sticker is gone from the backside and it was purchased used without box, so don't know the exact model number) with black screen issue.
I check the PSU/MB and both showing the correct voltages. Backlight working too.
On the T-CON, I measured:
VGL = 0.05V
VGH = 1V
VVD = 1.16V
VCOM = 0.6V
And If I disconnect the left side of the panel, I get white screen on the right side and the following values on the T-CON:
VGL = 12.5V
VGH = 30.5V
VVD = 15.6V
VCOM = 6.3V
So I narrowed down the problem on the left side of the panel.
I checked for short to ground the Panel PCB, couldn't measure any on the caps. I still need to check the IC Q45F G1563, maybe it went protection mode?
Anyhow, do you guys any tips on trying to fix this problem?
I checked on YT and some videos suggested that I should isolate certain lines on the T-CON ribbon cable until the shorted side starts up again.
Thanks in advance!
VGL = 0.05V
VGH = 1V
VVD = 1.16V
VCOM = 0.6V
VGL = 12.5V
VGH = 30.5V
VVD = 15.6V
VCOM = 6.3V
Thanks in advance!
