Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
  • Diah
    • Feb 2013
    • 6550
    Re: Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
    I didnt think of that possibility, your replacement powerboard should be very much like this: https://www.shopjimmy.com/sharp-runt...ply-led-board/
    if his PSU replacement match.. then the blown fly out MB NOR start script too.
    • sefoster
      • Nov 2022
      • 10
      My replacement is a match I ensured before I bought it that it was the same one. even with our new power board and original t-con we had the same issue. We replaced the t-con due to a suggestion from a different post somewhere else. However I need to replace the main board as there are burn marks on that now that weren't there before
      • Diah
        • Feb 2013
        • 6550
        before you are going to replace MB, need to check the currents on both LED BL sockets.. by each group of LED 1 till LED6. be ware on + & - and note each time when you turn on yours DMM reading for each group.
        • sefoster
          • Nov 2022
          • 10
          There is a spot on the MB that is now burned and it wasn't;t before so I am assuming I will need to replace it as I am not skilled enough to fix anything on there. This is still new to me and I don't want to mess anything else up as I'm not sure of how exactly to test each section. Like I said I'm a newbie so this is a first for me
          • dmcabs
            SHARP LC-60LE640X display flashing white noise patches and totally dropping out randomly
            by dmcabs
            Hey guys,
            I have a SHARP LC-60LE640X TV that has suddenly developed an intermittent fault of flashing white noise patches (appears like an Analog tuner off signal) and then totally dropping out.
            This model I believe is also known as LC-60LE600U or LC-60LE640U in other regions.
            FYI, a long time ago I was a component level repair tech for all consumer electronics and IT equipment.
            I'm a bit rusty but still have ability to dig right down.
            I measured all power supply lines and checked them for AC ripple voltage. Noting any lines that exceeded about...
            09-21-2024, 11:09 AM
          • JunkmanJimbo
            sharp lc-65ub30u plays but screen is flashing on and off
            by JunkmanJimbo
            Hey guys! It has been awhile since I've been on here. I hope everyone is doing well. I just picked up this Sharp lc-65ub30u. It plays but the screen is flashing on and off. Other than that i seems to be a great tv. Any ideas what the problem might be? I haven't pulled the back off yet. I thought I would get some opinions first. Thanks in advance for any help you can offer.
            09-07-2024, 09:45 AM
          • jonah1024
            Sharp Aquos LC-40UG7252E LCD TV burn in?
            by jonah1024
            Hello!
            I'm a few days old into this TV screens repair universe so please bear with me.
            Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
            - I did the classic unplug and hold power button to discharge the caps but it didn't help.
            - I did a factory reset as well...
            07-16-2024, 04:23 AM
          • STKR123
            Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
            by STKR123
            As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
            I wonder if re-flashing the BIOS might be of any use here.
            As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
            There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
            11-03-2024, 06:58 AM
          • klassic
            Sharp Aquos LC-60LE635E three blinks
            by klassic
            Hi community,
            I will describe my problem with a TV in those short following terms to be the most precise :
            What i have :
            power board DPS-162KP-1
            main logic board QPWBXF733WJN2
            symptoms :
            white led light logo at startup,
            after 2 minutes, blinking 3 times a row, repeating
            no backlight (and apparently no picture, checked panel with flashlight)
            no startup sound
            powerboard investigations :
            1-2 PNL : 0v
            3-4 GND
            5-6-7-8 UR : 13.15v
            9-10-11-12...
            10-24-2023, 01:39 PM
