Hello again old friends! I am perplexed with this set. The mainboard was reballed to fix the known issue of HDMI port loss. When it came back from service I reinstalled it and now have the attached image. The image is there but it looks to be some type of Z-sus problem. I have checked and rechecked and replaced the LVDT cable between the logic and main board with no luck. And yes, the inductors on both the Y-sus and z-sus have been re-soldered with clean new 60/40 material. All voltages match the panel label Vs=202, Va =55, Vzb = 110 (it was at 115 and was adjusted down) Vy = 180, and Vsc =150. I did run the jumper test on the logic board and got all clean color screens and the traveling white bar. I am at a loss looking for any suggestions!! Thanks for any help!! Also, I sent the board back to the shop who did the re-ball and they confirmed it was working perfect in their test set!!!
lg 60pz550-ua erratic horizontal pink lines over image
Re: lg 60pz550-ua erratic horizontal pink lines over image
if the set works with the jumper test on logic board, it is the lvds connector/connection problem or main board.
These models are known for terrible bga problems on the main chip, so ask the shop to prove it is working with your board, because it does not makes sense why it would only work in one tv and not in the other which can reproduce test patterns just fine. -
Right, I agree. I am just going on his word that it worked. I am trying to eliminate any other Z-sus / Ysus possible cause that might result in something similar. I saw a number of posts on this model talking about "mal-discharge" with similar screen pictures. Not sure exactly what that term means.Comment
if the test patterns run without issues, it cannot be mal discharge or any problem with the sus boards.Comment
the tv will do that if there is no mainboard connected(auto_gnd pin at 5V)Comment
I'm no good with plasma, but my guess is it has no sense to trim some voltages, the trimmers are not there to trim them after sale, i often read techs do that but usually they don't solve, why don't you check capacitors on the psb or sustain boards?Comment
Sure, worth a try but I don't see any physical indications for bad caps (no bulging, no leaking substance, etc). My next effort will be to apply a heat gun to the main board chip under the heat sink to see if the picture ever goes to normal. I am running out of ideas on this one!! I do have a scope so I may look for a more technical doc from LG that lists some acceptable waveforms for the main board....Comment
^^I agree 1000%, mainboard IS the problem.Comment
You are all convincing me even more that it's the mainboard. I re-ran the logic board jumper test just to satisfy my sanity and same perfect result! So all other components are working fine. I am asking the original repair center for a refund and hopefully will be sending the board to Nick's TV in Arizona. This I what I get for trying to save a few bucks!!!Comment
Nicks is a good choice. With the q-led tvs being around $350 for a 65 inch at the super sales going on or coming shortly, I would just have a hard time investing in the 10+ year old plasma, I would be always wondering whats next to go wrong.Comment
i forgot the auto test, so i also bet for the main board , the problem with LG mainboards i think are some lot of defective chips, it is not the solder probably.. it's a matter of bad contacts under the chips.. no luck with any kind of rework job.. my guess..Last edited by Davi.p; 11-12-2022, 08:08 AM.Comment
@nomoresonys point well taken! The set is my son-in-laws and he loves the plasma depth of contrast and screen speed for sports. Although the newer leds and OLED's are pushing the comparison. I think I can get the board reworked for about $80 - 90 US, so we'll see. But if it's more than that he will probably vote for a new TV. He has the LG 60 and a Samsung 60 mounted side by side so he doesn't miss a play! My daughter wanted him to trash both plasmas and buy one 75 inch 4K but I don't think he's going to comply!Comment
that 75 sounds good, I would just put 2 games on split screen and cast off those energy hogs. Last plasma I messed with a few months ago, just for fun, fought the z/x board all the way, needed all the igbt's replaced a diode and several caps, was a pain all the way, nothing is as easy to get out as the lcd/led tvs, so got that board fixed, just to discover that the buffer boards each had blown chips, not visible, could only tell by testing for shorts, so rather than try to track down the scarce boards that they want silly bucks for, I just called it quits, don't think I will mess with plasmas anymore, have never liked them since I tore one down many years ago, it had 3 big loud fans and LOTS of boards and weighed a ton, theyre too damn heavy and run too hot, no fun.Last edited by nomoresonys; 11-12-2022, 02:56 PM.Comment
^^+1000, those older ones are horrendous.Comment
I love plasma and have bought and fixed many in the span of 5 years, but now I'll only bother if they are full hd or a very rare model, if there's issues like these that it's basically irrepairable and unable to guarantee future proof just drop it, have seen for sale some 60PX950 around here and all had mainboard problems, buying a used one (and who knows how long it will last) costs half of what the TV was worth, nope.Comment
Indeed, the parts are just not readily available anymore, I'll be damned if I'm paying 100 bux for buffer boards that will probably be shorted because the seller is either too lazy to or doesnt know how to do a simple test for shorts, plasmas did and do serve well but when they get long in years, all the running hot that is inherent, takes its toll.Last edited by nomoresonys; 11-14-2022, 09:02 AM.Comment
This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-12-2024, 02:20 PM
Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
The TV was stuck on the logo and I couldn't access the update menu.
I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
The image result was good, but the image is inverted.
The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in... -
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...09-06-2024, 09:30 PM
by maksimthukMODEL JVC LT-58VA6955
MAIN 17mb170
PENAL ves580qndp-2d-n42
T-Con CCPD-TC575-009 V1.0
PSU 17ips72
There are no horizontal stripes (see photo). There is a sound of moving through the menu! Maybe someone has encountered such malfunctions?
2 Photos08-07-2024, 08:11 AM -
by jason123Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
- Loading...
