TCL 40-L141H4-PWG1CG power supply board repair for Thomson 49UV6206W
  • totof
    • Feb 2017
    • 157
    • france
    My TV's power board has blown and I have a mosfet, some diodes and resistors to change.
    The problem is that I cannot identify one of the components (U401, 6 pins chip).
    See photo with the marking on the component.
    I have downloaded the diagram of this card but the reference is not indicated.
    Can someone tell me what is the reference of this component U401?
    Thank you.
  • lotas
    • Jan 2016
    • 4620
    • Russia
    Re: TCL 40-L141H4-PWG1CG power supply board repair for Thomson 49UV6206W
    t37 - LD5537
    • lotas
      • Jan 2016
      • 4620
      • Russia
      Power Supply
      • totof
        • Feb 2017
        • 157
        • france
        Thank you lotas, once again you are great.
        I had looked for codes starting with Qt but not with 37.
        • lotas
          • Jan 2016
          • 4620
          • Russia
          But it also happens
          p37 is already LD7537.
          • totof
            • Feb 2017
            • 157
            • france
            Thank you for the diagram but I have other questions while reading it.
            I have to change the R413 2W resistor but mine is 36.8 ohm (see photo) and not 0.36 ohm as shown in the diagram.
            Same difference for R402, mine is it seemed to me 300 ohm (see photo) and not 390 ohm as on the diagram.
            In the end I do not know by which values are the good ones for these 2 resistors.
            I also have the QW2 mosfet which is blown (short circuit), it is reference CS7N65F and not AP2762.
            • lotas
              • Jan 2016
              • 4620
              • Russia
              According to the photo, 0.36 Om is correct (the silvery stripe is a multiplier of x0.01).
              • totof
                • Feb 2017
                • 157
                • france
                OK, I thought the multiplier was the 4th stripe
                • lotas
                  • Jan 2016
                  • 4620
                  • Russia
                  The fourth band (golden) is the tolerance of ± 5%.
                  This resistor (R413) acts as a current sensor and their resistance is always less than Om.
                  • totof
                    • Feb 2017
                    • 157
                    • france
                    I let myself be deceived by the site https://kiloohm.info by selecting caculator for 5 color band resistor.
