Samsung tv half LCD black
  • edugimeno
    • May 2017
    • 581
    • Spain
    Hi there
    I've seen a posting for a cheap broken Samsung TV series 7 50 "
    The posting states that suddenly the left half of the screen went dark
    Is this a broken LCD or is this a set of backlight led?
    Thanks in advance
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4460
    • Italy - Milan
    Re: Samsung tv half LCD black
    bad led strip
    • edugimeno
      • May 2017
      • 581
      • Spain
      Originally posted by Davi.p
      bad led strip
      Ok are you 100% positive on this?
      I would purchase if the issue is the led strips but I don't want to buy it if the LCD is broken
      Arent the led strips usually arranged horizontally?
      Thanks!
      • lotas
        • Jan 2016
        • 4752
        • Russia
        The backlight is rather end and one bar (on the left, at the bottom) does not work.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4460
          • Italy - Milan
          yes i'm sure, evidently 1 of 2 edge bars is broken
          • edugimeno
            • May 2017
            • 581
            • Spain
            Ok I was just asking cause all the tv sets where I've changed led strips they were arranged horizontally
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4460
              • Italy - Milan
              yes horizontal, one on the left one on th right
              • edugimeno
                • May 2017
                • 581
                • Spain
                Ok I will probably purchase it and see if I can source the led strips.
                  09-07-2024, 05:50 AM
                • Kingfreddie
                  LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
                  by Kingfreddie
                  Ok.. this is the story:
                  Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
                  This is kinda how it looked, just that mine were at the bottom of the screen:
                  09-11-2021, 01:57 AM
                • Raulnn
                  TD Systems K50DLG12US half black and half white screen
                  by Raulnn
                  good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                  By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                  01-20-2024, 04:49 PM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
                  09-06-2024, 11:40 PM
