vizio m50-c1 black screen
  • HMontrose
    variousvariants
    • Oct 2022
    • 6
    first post for me,
    I have a Vizio M-50 that went black.
    Tried unplugging 60 seconds and holding the start for 30,,nothing. 6 times.
    Read about fixing it with scotch tape.
    On the tcon board if I unplug the left side the right side comes us great. I tried taping off different sections of the bad side , the only results were limited color bands. Spent an hour with tweezers and exacto knife getting frustrated.
    I am ready to replace boards, but I read it is most likely not the tcon board. Anyone know which I should change?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: vizio m50-c1 black screen
    You can try checking all capacitors on the left panel board for shorts.
    • nomoresonys
      • 12330
      • U.S.
      also had a struggle but ended up getting a picture: https://www.youtube.com/watch?v=QpQdeV0KLl0
      • TVnovice2
        • Feb 2018
        • 11
        I had the same problem with a 70 inch Vizio. It turned out to be a problem with one side of the panel. When one side of the tconn was unplugged one side of the screen worked perfectly, when the other side was unplugged (and the first plugged back in) there was a problem. The solution is to remove the bezel to get to the tabs on the panel and tear off all the small tabs on that bad side. The other side tabs will take over and the screen will work. It goes without saying that this may be temporary or last a long tome. One person who did it five years ago still uses his tv. The 70 inch i did this summer is still working well.
        • nomoresonys
          • 12330
          • U.S.
          This model does not have side cofs.
          • nomoresonys
            • 12330
            • U.S.
            Dskall gave good advice in post #2, up to you to do the testing.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4539
              • Italy - Milan
              To make a better job is better to block a certain line or two if possible..
              • HMontrose
                variousvariants
                • Oct 2022
                • 6
                thanks, I watched the same video, didnt help me much, thought I would just replace one of the boards, a few dollars more but a lot less time for a tv that retails
                now for only $400 at Target
                • HMontrose
                  variousvariants
                  • Oct 2022
                  • 6
                  not sure how to do that, not terribly handy with electronics, do I use my meter on ohms and see if there is a drop?
                  • HMontrose
                    variousvariants
                    • Oct 2022
                    • 6
                    but which ones, in the video the guy figures out which ones by testing the ones marked ck or clk but on mine there are no such listings.
                    • Storyteller12
                      • Jun 2020
                      • 625
                      A lot of these Vizios suffer from BGA failure on the main board. They get to hot and fail after a while. You can test by heating up the 2 chips with the heatsink attached with a hot air gun. Then turn the tv back on and see what happens.
                      This won’t last long but at least you can confirm the problem
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4539
                        • Italy - Milan
                        Storyteller he is getting image with half screen disconnected, this means only a thing, half side of screen has a fault, not the cpu..
                        To the OP: make some photos of sections of the panel's half board on the bad side, i search for eventual diodes that gone bad, you will have to remove them, or is possible also bad caps.. post a picture of your meter or tellme the approximate cost of it..
                        • nomoresonys
                          • 12330
                          • U.S.
                          ok, have covered this testing many many times, read thru this thread for procedure and help, youtube is a great source too: https://www.badcaps.net/forum/showth...check+caps+low
                          • nomoresonys
                            • 12330
                            • U.S.
                            https://www.youtube.com/watch?v=lpRgRDbhOPI
                            • nomoresonys
                              • 12330
                              • U.S.
                              so you check for very low ohms, go ahead check in circuit, meter set to ohm scale put a probe on both ends of capacitor would expect well over 100 ohms, can check for shorts, meter set to diode/continuity mode, put a probe on both ends if you get 000 or close to it it is shorted, can do as Bob does there, neg. probe on ground, pos. probe on either end of cap, one side will give a reading other side will read 000, if both sides read 000 or close to it it's shorted. THIS TESTING DONE WITH TV UNPLUGGED FROM POWER.
                              • HMontrose
                                variousvariants
                                • Oct 2022
                                • 6
                                appreciate the time taken to help me out. I will work with the meter a bit, but it sounds like it's a bad cap not one of the boards?
                                • nomoresonys
                                  • 12330
                                  • U.S.
                                  yes, looks like the problem can be a component on one of the driver boards or in the panel itself.
                                  • HTR-Informatique
                                    Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                                    by HTR-Informatique
                                    YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                                    I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                                    On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                                    I also changed the screen because the PC fell and the screen was broken.
                                    I changed the battery with a new and original battery.
                                    I also had corrosion/oxidation on the...
                                    02-09-2025, 06:51 AM
                                  • VcemPzd
                                    Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                    by VcemPzd
                                    Hello everyone !
                                    My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                    04-28-2025, 10:14 AM
                                  • DaniK
                                    Acer Aspire E5-574-52RH - black screen
                                    by DaniK
                                    I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                    Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                    Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                    Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                    The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                    Symptoms are:
                                    - random black screen after displaying Acer logo...
                                    02-21-2024, 06:27 AM
                                  • paqman
                                    Vizio M60-C3 black screen
                                    by paqman
                                    So our beloved M60-C3 up and died the other day. I was not there, my wife mentioned that it came on, displayed the logo, then showed the right half of the screen white and fuzzy, with the left half of the screen ok. However when I got around to looking at it, the screen would not come on at all. The indicator LED will come on, then dim a bit. After a while, the LED might blink a bunch of times. I can't get it to be consistent to do that.
                                    So I've got the back off and am checking voltages. The capacitors on the power supply board visually check out. No bulges or anything. They all show...
                                    03-02-2024, 04:37 PM
                                  • kca
                                    by kca
                                    Hello all ~
                                    08-31-2025, 06:38 AM
