White Screen with Lines. Advice needed
  • Ancient1
    • Dec 2019
    • 275
    • Israel
    Pilot PD43S9HE 43" FHD Smart.
    Main : HK.T.RT2842P639
    T-con : Nemu N2TP430FHDLV1D_A1
    Panel : CC430LV1D
    I attach photos of :
    0. The hardware , except the distribution board ( I'll create full view)
    1. The problem : White screen with horizontal lines ( no Vertical lines ! )
    2. Disconnection of one of two FLEX from T-con to Panel boards ( in the next post)
    3. Taping 0.5cm first tracks of the Flex i.e 4 times ( in the next post)
    Photos include descriptor.
    Haven't measured anything yet.
    I'd like to read Opinions and Advice
  • Ancient1
    • Dec 2019
    • 275
    • Israel
    Re: White Screen with Lines. Advice needed
    Flex Disconnection and Taping photos
    Thank you !
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4461
      • Italy - Milan
      Good job with the posts. Try this, with multimeter locate the pin connected to test point LS_STV on the left connector from the rear of tcon, then mask only that, if the job is succesful you can try to perfect the job removing that and masking only one at time those referred to CLK test points. bye..
      PS: my supposition is that both sides are been hit by the extra tension and so the screen is not fixable..
      • Ancient1
        • Dec 2019
        • 275
        • Israel
        You're The Master
        I'm exited , I didn't check beyond the Menu activity forhorizotal lines
        1. What do you mean by "masking only one at time those referred to CLK test points. " Please check the T-con image , I marked with red circle .
        2. Obviously , the TV got hit hard on the bottom Left : Is there a way to reduce the brightness of "the wound" ?
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4461
          • Italy - Milan
          How do you have obtained this near good picture? With no STV?
          By the particular shot i see unfortunately there's a small crack and this is obviously not fixable, you will not obtain much by the sale of this.. sorry..
          It worths no further research on clock lines.. bye..
          • Ancient1
            • Dec 2019
            • 275
            • Israel
            There might be Very Faint lines , but not visible with an image. I need to investigate closer
            There is obviously a white Hue around where the physical damage is, It might also be that the Image properties are not set correct , but if not the above : What do you think ?
            What did you mean " further research on clock lines. " ? I mean to do what , Tape certain CLK line instead of LS_STV ?
            I told you, I don't do it for money. I'm more like Hardware Veterinarian
            I want to understand T-con Panel workings , this is very different from common "repairing a TV" .
            Also, I think that with a little improvement of the image there will be someone who will take it for 20% of Used. perhaps as security cams monitor
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4461
              • Italy - Milan
              No, sorry, in this case you have no improvements blocking single clock CLK lines, there isn't any bad setting, the crack in the screen glass drains the liquid crystals in that area so the white light passes through..
              is it clear the screen is cracked? whatch that half circle blotch..
              • Ancient1
                • Dec 2019
                • 275
                • Israel
                First, the good quality image is my desktop. And I worry a bit that the whole TV image is affected by the damage ?
                There is clearly a dark half-circle at the center of the whiteness.
                Can you explain a bit about LS_STV and clocks ? ( you meant to tape the CLK lines one by one, yes ?)
                I will do the CLK , no problem, but I need confirmation about taping their lines .
                You know what I am thinking ? What if I tape , say Kapton , right behind the area , underside of the Panel ... interesting , it will be somewhat dimmer
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4461
                  • Italy - Milan
                  clk testpoint refers to clock lines, in an integer screen is better to find the single clock line to be madked, but here is unuseful. Covering screen with tape? Are you joking? nooooo!
                  • Ancient1
                    • Dec 2019
                    • 275
                    • Israel
                    I am trying masking the CLK line anyway.
                    #4 is not good , and I ask : do I keep the SL_STV masked ?
                    I meant taping on underside, because you said the Backlight is shining through.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4461
                      • Italy - Milan
                      if clk are masked stv must not be masked
                      • Ancient1
                        • Dec 2019
                        • 275
                        • Israel
                        I did not get good results.
                        At first I tried with STV not masked , than masked
                        I will probably repeat the test tomorrow , because there was something unusual with CLK #4 & its Pin .
                        Can you explain a bit on the relationship of STV and CLK ?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4461
                          • Italy - Milan
                          Forgot to say that if single clk lines doesn't go well then there are more clock lines affected, i have told to you, in this case the trick doesn't work because screen is heavily damaged, stv blocks all side of gate drivers, clk lines controls only a portion of the side, if the clk are 4, the side is divided in 4 groups.. the less you block the better..
                          • Ancient1
                            • Dec 2019
                            • 275
                            • Israel
                            So the best way is to start with all 4 CLK lines, which is the same as blocking STV, no ?
                            Than remove one by one , because it makes sense that one or two CLK are involved with the area of the damage ( bottom right corner )
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4461
                              • Italy - Milan
                              yes
                              • Ancient1
                                • Dec 2019
                                • 275
                                • Israel
                                All CLK lines produced white screen
                                I'm using now the STV line.
                                The guy who gave me will probably sell it for Security Cam screen , its a 43" smart TV and will service quite a few cams.
                                Thanks !
                                • Ancient1
                                  • Dec 2019
                                  • 275
                                  • Israel
                                  Davi.P :
                                  TV returned. Image issues.
                                  Looks like the original STB issue is spilling to other V lines. Beyond my capability.
                                  Since video is needed and can't be uploaded here,
                                  I recorded 3:30 minutes from ON press.
                                  Since middle 2 minutes is repetitive/no change I skipped this part and created 2 videos, Total time of 1:15 .
                                  Uploaded to MEGA folder :
                                  https://mega.nz/folder/cNlxxQrb#1uj28Ab-6RXfBuF62QzYPw
                                  Photos of the taping result are in previous message.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4461
                                    • Italy - Milan
                                    Bad news for you, i have watched the video, that is because a crack can't remain there the same always but it runs especially with every movement you make to it, the picture shows a losing of vgl line that produces the smear of colors, and also lines are sign o contact disturbation, sorry this screen is at the end.. bye..
                                    • Ancient1
                                      • Dec 2019
                                      • 275
                                      • Israel
                                      Thanks !
                                      You are saying that the damage to the screen is not static, and so we see more damage like bright dots at the screen edge, VGL damage spreading, lines etc.
                                      I am really happy with this experience, learned stuff !
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4461
                                        • Italy - Milan
                                        So the lesson is: never sell a cracked screen tv.. or sell it for parts with no return..
                                        • Stanley1843
                                          by Stanley1843
                                          06-29-2024, 11:54 AM
                                        • harp
                                          White screen repairs
                                          by harp
                                          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                          05-13-2024, 03:43 AM
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • jeyoung12
                                          Samsung QN50Q60t lines on screen
                                          by jeyoung12
                                          Hi all
                                          I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                                          My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                                          This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                                          It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                                          So....i don't know what end of the C ribbon to work with...
                                          02-26-2024, 10:38 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
