Dune Duo multimedia player Power supply
  • smic717394
    • Jun 2017
    • 95
    • Spain
    I need a bit of help. I have a Dune Duo, The psu has the fuse blown, maybe the bridge rectifier as well, but the problem is that the ic controller is damage so I cant read the markings. Anybody can help me identify the chip. This power supply is used in allot of dune boxes. If anybody can take a picture of the psu so I can identify the chip I would be grateful. Or where Can I get another PSU.
    Thank you.
    • 31247
    Re: Dune Duo multimedia player Power supply
    the missing piece is in the unit or on that board - shake them over a table
    • lotas
      • Jan 2016
      • 4786
      • Russia
      The whole problem is because of this glue!
      • smic717394
        • Jun 2017
        • 95
        • Spain
        I can´t find it. its somewhere in another dimension by now. I remove the IC, I thought that maybe on the other side would be some markings, but no luck it just some generic number I think something like L04 02
        • smic717394
          • Jun 2017
          • 95
          • Spain
          you think it died because of the glue? I can replace the fuse and the bridge rectifier, but unless I change this, I don't think would do much good. Would be a shame to throw away a perfectly otherwise working unit because of one compontent.
          • R_J
            • Jun 2012
            • 9607
            It is more likely that the small electrolytic cap next to the ic is bad. Post a clear picture of the bottom of the board as well as a clear view of the trace side under the ic.
            • dskall
              • Oct 2016
              • 2905
              • usa
              https://****************/ic_power/
              For some reason Badcaps won't let me post this website.
              ( remont
              -aud
              .net )
              You should be able to iD your chip.
              • smic717394
                • Jun 2017
                • 95
                • Spain
                ( remont
                -aud
                .net )
                Thank you. I´ll try it there. For now I bought a power supply board module 12v 6A and its working fine, get a little hot, but its ok so far.
