Samsung UE50KU6070 black screen
  • totof
    • Feb 2017
    • 157
    • france
    I have my TV model UE50KU6070 which I am trying to repair.
    BN41-02528A / BN94-10800C motherboard.
    If I disconnect the motherboard from the power board, the backlight works. When the motherboard is connected the backlight works but the screen remains black.
    When I plug the TV into the electrical outlet, the standby LED lights up but no reaction to an attempt to start it with the remote control for about 1 minute. During this minute the TV consumes about 20W.
    After one minute the consumption drops to 0W and the TV can turn on with the remote control but the screen remains black. All voltages on the motherboard are correct.
    The TV turns off with the remote control but you have to wait about 1 minute before restarting it again. Sometimes at startup the screen displays "Samsung Smart TV" for 1 second before going black.
    In fact, in addition to the black screen, it is as if the TV was extremely slow.
    The behavior is the same if I disconnect the two LVDS cables.
    Do you have an idea of the problem and do you think that the motherboard is repairable for example by reprogramming the memory?
    Thank you in advance for your help.
  • CapLeaker
    Leaking Member
    • 8184
    Re: Samsung UE50KU6070 black screen
    Reflash the SPI or whatever it is. Looks like a good candidate, at least it’s worth a try if you can find a dump file. Also check the SPI first, before you put a new file on. Not that you have a bad one.
    • totof
      • Feb 2017
      • 157
      • france
      Thank you CapLeaker.
      Attached the SPI file but i have no idea whether the content is valid or not.
      • CapLeaker
        Leaking Member
        • 8184
        read the spi, save a copy, FF the spi and check it. Hopefully it is still good, then all you need is a working dump.
        • totof
          • Feb 2017
          • 157
          • france
          SPI seems good, I wrote FF without problem
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4343
            • Italy - Milan
            it is not a memory problem, must be checked the entire psb with dummy loads
            • totof
              • Feb 2017
              • 157
              • france
              It is very interesting but I don't know how to this check.
              All the voltage on self components seems good.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4343
                • Italy - Milan
                you don't know ohm's law? It's hard starting whatever repair without it , must collect some power resistors and a lamp..
                • totof
                  • Feb 2017
                  • 157
                  • france
                  Thank you Davi.p
                  For the ohm's law it should be fine but the problem is that without a diagram of the card it is very difficult for me to know what to test.
                  I have already checked all the voltages on the inductance and they are OK. No shorted capacitors either.
                  What I would like to test are the signals to the LVDS cable but without a diagram it's complicated
                    • 12206
                    • U.S.
                    backlights and powerboard are fine, proved by results of first post.
                      • 12206
                      • U.S.
                      maybe try the tape cut-off method just for fun, never know when it will work.
                        • 12206
                        • U.S.
                        Capleaker probably nailed it with post #2, eeprom/spi/nand dead.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4343
                          • Italy - Milan
                          maybe we don't understand ourselves, i suggested you to test the power supply outputs, that are usually marked on board each signal, put a resistor on the 5v, a lamp on 12v and so on..
                          • totof
                            • Feb 2017
                            • 157
                            • france
                            I rechecked all the voltages on self and they are good.
                            VON, VCCA, VCCB and AVDD voltages are also correct.
                            I just bought another motherboard pulled from a broken TV and the TV works again.
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • HTR-Informatique
                              by HTR-Informatique
                              02-09-2025, 06:51 AM
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                            • VcemPzd
                              Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                              by VcemPzd
                              Hello everyone !
                              My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                              04-28-2025, 10:14 AM
                            • Chrissygizmo
                              by Chrissygizmo
                              02-10-2025, 12:33 AM
