TCON and self diagnosis!
  • angelos
    • Dec 2012
    • 573
    • South Africa
    Hi Guys.
    I have experienced something rather unique and need to find out by the forum what to make of it.
    I got in this set, a JVC or Telefunken LED TV whose complaint is that sometimes the set comes up blank with the back lights running. So I switched on and yes there was a blank screen and back lights were running. I checked the fuse on the TCON and sometime later I lifted the set off the table to check the image (the TV has no feet to let it stand upright) and noticed the set was cycling red, green blue, test pattern, blank then all over again doing this. Suddenly the no signal logo appeared and tv was working perfectly fine. I switched off and later when i checked it again i noticed that the set was cycling again in "self diagnosis" mode.
    My questions are,
    1. How does a LED TV with a separate TCON board go into "self diagnosis" by itself? I realize that "self diagnosis" is generated by the TCON, right?
    2. Where to start fault finding? Main, LVDS, TCON, Panel?
    I have checked the blue / white LVDS pairs on the cable while TV was cycling and did not get 1.2V, it was 0V. This tells me that the main board is not sending the data to the TCON, right?
    Am i right in assuming that if you supply 12V to the TCON but with no data incoming the TCON starts to generate its own pattern?
    This fault is perplexing to say the least.
    Photo's can be uploaded later, i closed the set to do other work in the meantime.
    Regards
    Angelos
  • angelos
    • Dec 2012
    • 573
    • South Africa
    Re: TCON and self diagnosis!
    So i guess the issue revolves around the main processor and voltages around it, core voltages etc?
    • angelos
      • Dec 2012
      • 573
      • South Africa
      Sorry, I guess it is not "self diagnosis" but rather burn-in mode
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4516
        • Italy - Milan
        yes, check lvds cable..
        • neilc6
          • Nov 2015
          • 1550
          It is called aging mode. Cranks the backlights to max and cycles through colors. Have accidentally turned it on in the service menu in a Haier. Exit on the remote or power button on tv to disable. If it's stuck in aging mode, then main board needs to be replaced.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4516
            • Italy - Milan
            it is not aging mode here, is tcon self test, when tcons are powered with no video signal in, then starts self test.. it is common for many panels
            • angelos
              • Dec 2012
              • 573
              • South Africa
              Thank you Davi. I will check for a LVDS cable connection fault then i should be able to measure the differential signal on the main board if there are test points. Now i know how to test panels if the main board is non responsive. By applying 12V to the tcon without a signal applied.
              • kca
                by kca
                Hello all ~
                08-31-2025, 06:38 AM
              • high-tech
                Samsung UN55F7050AFXZA ver. TD01 power cycling
                by high-tech
                Hello everybody, I could use some help on this one... It's got me guessing...
                I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                9. ground (PWM2) 10. 0.9 volts cycling...
                09-15-2020, 03:39 PM
              • advant
                by advant
                02-03-2020, 12:25 AM
              • Hakuu
                by Hakuu
                Hi There,
                More Details
                TV Model - LG OLED77G1PUA
                07-12-2023, 02:37 PM
              • Daren87
                Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                by Daren87
                I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                08-13-2023, 03:25 PM
