Samsung UE58TU7100K Wont Turn On
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4544
    • Italy - Milan
    Re: Samsung UE58TU7100K Wont Turn On
    one method is to slide out the 2 terminals for the 13v and gnd from the m.b. side of the psb to mb cable with a small screwdriver, and then attach the lamp terminals, other method is to solder 2 wires on the solder side under the connector..
    when testing measure voltage..
    • Diah
      • Feb 2013
      • 6614
      Originally posted by Bloopeta
      Unfortunately not, if I unplug either side one at a time, I get illumination from backlights, but nothing else
      so when you did U riboon test TV start with out blink.. and you can put it in STB via RC... !! please confirm,, if this was YES then you have issue an Panel VCC because no picture,, take out the speaker and upload high Res photo on both sides of the panel buffer boards,,, it could be there ceramic caps short or ESD diode short on the boards.
      • diif
        • Feb 2014
        • 6978
        • England
        Unfortunately I didnt buy the set new myself, so unable to return it. But thats interesting to know for future reference, I always thought electrical goods were 12 month warranty, unless took out extended from Currys etc
        That's a shame. And forget currys. Ritcher Sounds sells all their TVs with a 6 year warranty, so there isn't any need to remind managers of their legal responsibility.
        A receipt isn't needed if it was purchased by debit or credit card. Just a proof or purchase.
        Our consumer laws in the UK and Europe are far better than the US
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4544
          • Italy - Milan
          it could also be a bad processor..
          • Bloopeta
            • Jun 2018
            • 526
            • United Kingdom
            Yes, when did ribbon test, it starts up but with no image, amd I am able to put it in standby with RC
            • Bloopeta
              • Jun 2018
              • 526
              • United Kingdom
              #26
              On the mainboard? Is there any tests to run to check if this is at fault?
              • Diah
                • Feb 2013
                • 6614
                first check the SPI Flash pin 1 which it connected to ESD diode if there >=3.3V
                • Diah
                  • Feb 2013
                  • 6614
                  and on this area check all caps.. when you check caps panel should be disconnected from MB
                  • Bloopeta
                    • Jun 2018
                    • 526
                    • United Kingdom
                    #29
                    Which one is SPI Flash pin 1?
                    • Bloopeta
                      • Jun 2018
                      • 526
                      • United Kingdom
                      #30
                      Non in this area are showing resistance with panel disconnected from MB
                      • Diah
                        • Feb 2013
                        • 6614
                        do the same way to check all caps..
                        spi pin 1 are remarked with circle
                        • Bloopeta
                          • Jun 2018
                          • 526
                          • United Kingdom
                          #32
                          All caps checked, no resistance on any
                          Im sorry to be a pain, but I cannot see a circle anywhere? Lol
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            #33
                            pin one white dot bottom right of ic
                            • Bloopeta
                              • Jun 2018
                              • 526
                              • United Kingdom
                              #34
                              Thanks m8
                              • Bloopeta
                                • Jun 2018
                                • 526
                                • United Kingdom
                                #35
                                0.25v, then when screen illuminates for a second it jumps up to 1.something for a millisecond, then counts back down to 0.25
                                (Meter set to 20v)
                                • Diah
                                  • Feb 2013
                                  • 6614
                                  E.waste. or claim your warranties
                                  • Bloopeta
                                    • Jun 2018
                                    • 526
                                    • United Kingdom
                                    #37
                                    No warranty unfortunately
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4544
                                      • Italy - Milan
                                      #38
                                      in this case does it blink again? (status led)
                                      • Bloopeta
                                        • Jun 2018
                                        • 526
                                        • United Kingdom
                                        #39
                                        No, works as it should, just with no image
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          #40
                                          no harm in contacting samsung though with the serial number etc you may get lucky and they help you its only a quick phone call or email
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
