Philips 65PUS6554/12 - only powers on if you prime backlights first
+ More Options
Posts
  • djmka
    • Aug 2021
    • 35
    • England
    Hi everyone.
    I have a problem that I would appreciate some expert advice on.
    I have a 65” Philips television which powers on, has sound but but no picture. Usually this would lead me to believe an open circuit was present on the backlights. However, if I disconnect the mains power cable to the television and test the power cable going to the backlights using a LED tester, no open circuits are present. If I reconnect the backlight cable to the power board and replace the mains power cord to the tv the device fires up perfectly and displays a beautiful picture. It's almost as though the LED needs need “priming” before they will work. Has anyone come across this before?
    I've attached some images showing the voltages of my LED testing (between 32v and 35v) and the voltages when the television is operating correctly (42.5v).
    Any help is greatly appreciated.
  • petehall347
    • Jan 2015
    • 4437
    • United Kingdom
    Re: Philips 65PUS6554/12 - only powers on if you prime backlights first
    yes i have had same thing .. tv lasted a few months maybe a year working ok . its waiting for me to look at it again . suspected bad contact .
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4456
      • Italy - Milan
      Almost surely you have a single bad fluctuating led..
      try this simple test, cool tv, warm up the leds power supply area (elevator), turn on tv normally, if 100% working then it's so..
      • Diah
        • Feb 2013
        • 6435
        Bad LED on 28.7V line
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4456
          • Italy - Milan
          what's your board model?
          • djmka
            • Aug 2021
            • 35
            • England
            Thank you to everyone that has commented. Please see attached pictures of the power board and main board.
            • djmka
              • Aug 2021
              • 35
              • England
              Davi.p - please explain what you mean by the word elevator.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4456
                • Italy - Milan
                i mean the are near the leds connector, from the big inductor to the connector..
                • djmka
                  • Aug 2021
                  • 35
                  • England
                  Would it be possible to circle the area on one of the images I've submitted?
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4456
                    • Italy - Milan
                    • djmka
                      • Aug 2021
                      • 35
                      • England
                      Thanks Davi.p
                      I’ll try this tomorrow morning and report back.
                      • djmka
                        • Aug 2021
                        • 35
                        • England
                        I tried to power on the television earlier today but it wouldn't start. I took the back off and applied heat (using my wife's hairdryer) to the area you highlighted and it then powered up successfully. Could you please explain why it works when preheating the power board. Can you also confirm that it is 100% the backlights that are faulty, Finally, has anyone had experience of unsticking the panel drivers from the chassis on a Philips tv. They are stuck in a few places making it almost impossible to free them.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4456
                          • Italy - Milan
                          It sounds strange to me that tv remains off with a b.light problem, what it does with standby led? does it blinks? if you change channel can you hear sound without image? The reason of the heating can be because some resistors of the feedback circuit changes slightly value and so permits the driver to turn on the lamps.. i don't know what you mean for sticky panel drivers , search youtube for a dissassembling guide..
                          • djmka
                            • Aug 2021
                            • 35
                            • England
                            Update -
                            I finally dismantled the television to get to the LEDs and found each strip consumed varying voltages using my LED tester:-
                            Strip 1 - 29.1v
                            Strip 2 - 29.2v
                            Strip 3 - 33.5v
                            Strip 4 - 31.5v
                            Strip 5 - 29.2v
                            Strip 6 - 32.5v
                            Based on the above, I have decided to purchase a new set of backlights and shall let you know the outcome. Hopefully, with new lights in, the television should operate correctly.
                              • 12269
                              • U.S.
                              Quote: "Finally, has anyone had experience of unsticking the panel drivers from the chassis on a Philips tv. They are stuck in a few places making it almost impossible to free them" do you have a picture of this? not sure what you mean, the new backlights should be the fix.
                              • djmka
                                • Aug 2021
                                • 35
                                • England
                                Hi nomoresonys. Thanks for your reply but I have already managed to separate the driver board from the chassis using the blade from a craft knife.
                                  • 12269
                                  • U.S.
                                  ok, maybe it was stuck on with a thermal pad?? lol.
                                  • simwalsh
                                    Philips 47PFL4606 Powers on, works normal then powers off after a minute
                                    by simwalsh
                                    I am new to this forum and have searched for some answers with problems similar to mine.
                                    Philips TV powers on as normal for about a minute or less then click and no power at all not even standby light. If i disconnect from mains and reconnect it will power on again but for a shorter time. Once i leave it disconnected from main for a longer time it will power on for a longer period the next time.
                                    It sounds like a power supply issue?
                                    I have the board out and want to run some tests. Not sure what i should be doing but i put a 1k resistor across SB and +5v...
                                    12-04-2023, 04:03 AM
                                  • crozoki
                                    Philips 65PUS6554/12 one time backlight flash
                                    by crozoki
                                    Hello
                                    I have Philips 65" TV (65PUS6554/12).
                                    Problem is when turn on tv backlight flash only one time for about 1 second then turns off and display is dark but sound is there.
                                    Sometimes TV turns on and work with no problem, had backlight and picture, but mostly Tv wont turn on backlight. Any idea where to start looking?
                                    Power board TPV 715G9187-P01-008-001S
                                    Main Board 715G9907-M01-B03-005K...
                                    09-03-2022, 05:47 AM
                                  • whtiey549@gmail.com
                                    PHILIPS 42PFL4606H/58 NO backlights
                                    by whtiey549@gmail.com
                                    Hi all, I have a philips 42pfl4606h/58 and there are no backlights. I can hook up my laptop and play video through the set. Sound but no picture. I can use a flashlight and see picture through the screen.
                                    I will attach some photos. Are the CCFLs good? How can I test the board? Without Electrocuting myself. Any help would be greatly appreciated....
                                    06-13-2022, 07:47 AM
                                  • KevM
                                    Philips Pus 436401/12 flashing backlights question
                                    by KevM
                                    hi had loads of help from this forum getting TVs back up and running but seem to be hitting a brick wall with this one.
                                    Backlights failed before Xmas so ordered a new set and after replacing them and putting the set back together was delighted to see it work for 15 seconds only for the picture to flash on and off and a quick look round the back confirmed the backlights were flashing on and off
                                    I have a steady 44v at +vled and a fluctuating 0v to 10v at -vled when the light start flashing, a steady Bl-on voltage and steady dim voltage.
                                    If i disconnect 2 strings of leds...
                                    02-04-2022, 09:40 AM
                                  • alro7779
                                    Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                    by alro7779
                                    Hello, guys!
                                    The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                    09-14-2025, 12:25 AM
