OLED55B7A-U black screen but powers on
  • Woodstock
    • Aug 2022
    • 5
    I have a fairly new but our of warranty LG OLED55B7A-U TV that all of the sudden developed a black screen. Sound still works, once in a great while can get a faint ghosting to appear in background if you look real close. Using a flashlight close to the screen does not indicate a faint image is present.
    Any thoughts on where to start and likely cause of problem?
    Have toggled on and off, checked inputs, checked inputs with different signals, looked at all boards and connections for any signs of heat or smell. Found nothing so far.
    Any help is appreciated.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: OLED55B7A-U black screen but powers on
    Could use some good pictures of boards.
    • Woodstock
      • Aug 2022
      • 5
      I tried to show front and back where possible. I have reseated all connections. One thing top note, the red standby light does flash three times when the TV is powered on. As mentioned previously, occasionally there is a slight ghosting for a second once in a while, certainly not every time.
      • dskall
        • Oct 2016
        • 2905
        • usa
        https://www.youtube.com/watch?v=Ksa3...ndRepairTVs%2C
          • 12328
          • U.S.
          would check all the solder joints in picture 2, hard to tell from picture but some of them don't look that great, examples of bad joints: https://www.google.com/search?q=bad+...ih=607&dpr=1.5
          • Diah
            • Feb 2013
            • 6560
            you said you have sound but the screen remain black... i would try first to send IN_STOP command to make hard reset for LG. also you can before sending In_STOP check if the Connector from power boards to the middle T-CON driver boards if you have 12V & 24V.. 24V are responsible for OLED
            • Woodstock
              • Aug 2022
              • 5
              How do you perform the in stop function?
              • lotas
                • Jan 2016
                • 4854
                • Russia
                Check the voltage after these fuses (there is voltage on these capacitors).
                • sintv
                  • Feb 2015
                  • 37
                  • scotland
                  Eh....LEDs usually
                  • lotas
                    • Jan 2016
                    • 4854
                    • Russia
                    Originally posted by sintv
                    Eh....LEDs usually
                    What LEDs, this is an OLED tv, it has no backlight.
                    • Diah
                      • Feb 2013
                      • 6560
                      we had before threat over here. it was same boards which the 24V socket burned out at the power boards side.
                      • lotas
                        • Jan 2016
                        • 4854
                        • Russia
                        Yes I remember.
                        • HTR-Informatique
                          by HTR-Informatique
                          02-09-2025, 06:51 AM
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
                        • DaniK
                          Acer Aspire E5-574-52RH - black screen
                          by DaniK
                          I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                          Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                          Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                          Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                          The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                          Symptoms are:
                          - random black screen after displaying Acer logo...
                          02-21-2024, 06:27 AM
                        • classypenguin
                          Grundig 55 GUT 8768_55 (chassis gf) Black Screen, powers on and shows backlight
                          by classypenguin
                          Hello, I bought a Grundig 55 gut 8768_55 (chassis gf) as a defect ‘black screen.
                          Now I have started with the basics:
                          Fuse intact, LED Tester says 123V, BL Cap has 140V, Mainboard to PSU 12V, 24V, 3.3V and 5.2V are avail+able, 12V and 3.3V at TCON (TV has no seperate Tcon)
                          As soon as I switch on the TV, it shows backlight, but a small grey line which disappears again.
                          When I tap Menu, the background light becomes brighter. What can I assume is wrong with the TV?
                          A defective mainboard? Or a software problem?
                          I would be glad of help....
                          09-21-2024, 01:07 PM
                        • turmix
                          AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                          by turmix
                          Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                          The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                          At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                          During another reassembly, I made a mistake, and...
                          01-29-2024, 03:48 AM
