Grundig 55 GUT 8768_55 (chassis gf) Black Screen, powers on and shows backlight
  • classypenguin
    • May 2022
    • 7
    Hello, I bought a Grundig 55 gut 8768_55 (chassis gf) as a defect ‘black screen.
    Now I have started with the basics:
    Fuse intact, LED Tester says 123V, BL Cap has 140V, Mainboard to PSU 12V, 24V, 3.3V and 5.2V are avail+able, 12V and 3.3V at TCON (TV has no seperate Tcon)
    As soon as I switch on the TV, it shows backlight, but a small grey line which disappears again.
    When I tap Menu, the background light becomes brighter. What can I assume is wrong with the TV?
    A defective mainboard? Or a software problem?
    I would be glad of help. I would also be happy to send further pictures and measurement results if required
    Best regards and have a nice evening
    Tobi
  • Diah
    • Feb 2013
    • 6558
    try to capture the small grey line and show us over here..
    take out the speakers.. and have access to the panel buffer boards... you will see at each side at he middle flat ribbon cable like the letters U.. disconnect one side a time and turn on see what you will have on the screen... always photos better than writing
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • David82827372
      Dropped MacBookPro 15” 2012 shows black screen
      by David82827372
      MacBookPro 2012 15” A1398.
      No visual damage was found.
      Mac was inside of suitcase and it was inside of a bag.
      Mac boots up,I can hear the chime,but the screen is totally black,not even “light” black. Caps lock light doesn't work.
      I tried SMC,PRAM reset, didn't work.
      Reconnecting screen display by unplugging those two things didn't work. I used this video
      Reconnecting battery didn't work.
      I also tried SMC,PRAM reset while the battery was disconnected and Mac was getting...
      01-12-2024, 08:16 AM
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
