Philips TV 40PFL3148H/12 keeps restarting on the logo
  • alfonzzo
    • Aug 2022
    • 55
    • fr
    Re: Philips TV 40PFL3148H/12 keeps restarting on the logo
    I can't find the chip for a philips tv, this reference only returns results for samsung tv. That's strange because I have this exact chip on my philips tv
    • lotas
      • Jan 2016
      • 4885
      • Russia
      Originally posted by alfonzzo
      Well I will buy a 1gb one and retry, but honnestly I already tried with 3 usb sticks ( 8/32/128gb) and nothing happened.
      With such a large size, it will not pick up the update, you need to try with 1-2-4 Gb.
      • lotas
        • Jan 2016
        • 4885
        • Russia
        With someone else's firmware, a red square will appear on the screen with the inscription "CI Plus Key Fail" and half of the functions will not work. Here the firmware is tied to the "hardware" and with the "non-native" firmware the TV simply may not start. This applies to TV philips.
        • alfonzzo
          • Aug 2022
          • 55
          • fr
          is this one fine? it 's a 2Gb 2.0
          https://www.amazon.fr/Nilox-Cl%C3%A9.../dp/B07LD3B65H
          • lotas
            • Jan 2016
            • 4885
            • Russia
            I don't know, it's better to find an old release (ask friends or where they sell old things) from Kingston, SanDisk ....
            • lotas
              • Jan 2016
              • 4885
              • Russia
              #26
              And you do not need an update file, but a service firmware to restore the TV.
              • alfonzzo
                • Aug 2022
                • 55
                • fr
                #27
                ok I will try to find an old drive then...
                Philips sent me this file : upgrade_TPN1011E_002.180.000.000.zip
                and I also tried with the last firmware on their website : 40pfl3148h_12_fus_fra.zip
                (I can't upload the files on the forum but I can't put them on a third party website if needed.)
                • lotas
                  • Jan 2016
                  • 4885
                  • Russia
                  #28
                  You can upload the upgrade_TPN1011E_002.180.000.000.zip file to the cloud and post the link here.
                  • alfonzzo
                    • Aug 2022
                    • 55
                    • fr
                    #29
                    Here is the link to the upgrade.pkg file extracted from the zip
                    https://paste.c-net.org/VehiclesMidway
                    (I dont know how to uload on the badcaps cloud so I use a pastebin-like service)
                    • lotas
                      • Jan 2016
                      • 4885
                      • Russia
                      #30
                      You better put this file in rar (original) as it is, because when unpacking, uploading and downloading the file itself may suffer (change the checksum).
                      • alfonzzo
                        • Aug 2022
                        • 55
                        • fr
                        #31
                        Oh sorry, I've uploaded the original zip, thanks
                        https://paste.c-net.org/StacySearches
                        • lotas
                          • Jan 2016
                          • 4885
                          • Russia
                          #32
                          Yes, this service firmware, if you can’t restore TV with it, I’ll post another one for you, while I give instructions on how to do it correctly:
                          1. Unzip the downloaded “upgrade.pkg” file to the root directory of the USB stick, i.e. open the drive and copy the update file there (For full compatibility of USB drives with TV, I advise you to use flash drives no more than 2 GB with the Fat16 or Fat32 file system).
                          2. Disconnect the TV from the power supply - remove the plug from the socket.
                          3. Connect the flash drive with the prepared update file to the TV.
                          4. Connect the TV to the power supply.
                          After the power is turned on, the software update will start automatically.
                          - Do not press any keys on the remote control.
                          - Do not remove the drive from the TV during the update.
                          - Do not disconnect the TV from the network during the update.
                          After the update is completed, the TV will restart automatically and after turning it on, it will enter the USB content display mode.
                          5. Put the TV in the mode of viewing on-air channels.
                          6. Disconnect the USB drive.
                          7. Restart the TV through the menu: Menu / Settings / TV settings / General settings / Reinstall TV
                          8. After the initial TV setup screen appears, remove the plug from the outlet for 5-10 minutes (for de-energization, it is not recommended to use the switch on the surge protector, mechanical removal of the TV plug from the outlet is required).
                          9. After disconnecting the USB drive from the TV, delete the update file by connecting it to the PC again.
                          • alfonzzo
                            • Aug 2022
                            • 55
                            • fr
                            #33
                            Thank you very much lotas for detailing the whole process that's very kind from you.
                            I've ordered a second hand 2gb usb drive on ebay, an old one judging by the pic, maybe it has the same age as the tv (around 10 years) hoping it will work because I am not confident at all to replace the NAND and reprogram it etc, I won't be able to do this. Fingers crossed.
                            I'll update you as soon as I have some new stuff to share, thanks again !
                            Edit: btw I dont have to press a key on the remote while the tv starts? I read we have to press the down button, sometimes it's the ok button... ?
                            • lotas
                              • Jan 2016
                              • 4885
                              • Russia
                              #34
                              There is nothing to press, the process should start automatically
                              • iotaa
                                • Aug 2022
                                • 10
                                • fr
                                #35
                                Hi @lotas it's me alfonzzo I created a new account since I can't access the other one anymore. I received the usb drive and made the test, following your instructions, but unfortunatly the tv keeps restarting over and over again
                                I guess there is nothing more to do, apart from unsoldering the chip and replacing it by another one and reprogramming it.Which I won't be able to do so I'll just trash the tv...
                                • G33RT
                                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                  by G33RT
                                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                  It does power up when pressing the power button.
                                  I already try the power button while plugin the plug with no result.
                                  Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                  Could this be an PSU or eMMC issue ?
                                  07-19-2025, 03:43 AM
                                • janos6662000
                                  Philips 47PFS7509/12 LCD TV problem
                                  by janos6662000
                                  Hi
                                  I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                  When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                  I downloaded original firmware and applied the update, but the problem remained.
                                  From a colleague i received a "factory package software" which is a lot bigger.
                                  I made another firmware update, but still did not solve the problem.
                                  Somewhere on the way the error got worse, because at the moment the...
                                  08-12-2025, 12:54 PM
                                • Magnusa2
                                  dell 5490 (la-f401p) after logo restarting
                                  by Magnusa2
                                  hii
                                  i have 5490. display coming properly . but in windows going time restarting automatically. not going in windows . i have 3 pieces same issue . any solutions have?
                                  06-19-2024, 06:26 AM
                                • Teban1306
                                  [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                                  by Teban1306
                                  Hello everyone!
                                  I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                                  System Information:
                                  • Model: Lenovo ThinkPad T14 Gen 1
                                  • Machine Type: 20S1S4E600 (Intel i7 variant)
                                  • Current BIOS: N2XET42W (1.33) - Latest version
                                  • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                                  What I'm trying to achieve:
                                  Replace the default "LENOVO" boot logo with a custom image during POST.
                                  🔧 What I've tried:
                                  09-14-2025, 11:49 AM
                                • akwky
                                  by akwky
                                  Hi!
                                  04-14-2025, 01:56 PM
