toshiba 50L4333D TV with a LG 32L4300 board low brightness
  • pcbmaniac
    • May 2014
    • 81
    • Greece
    Hi all. I need help on a toshiba 50" 50L4333D TV with a LG 32L4300 board as in the photo. I measured the supply voltages and found them all normal. The problem is that the brightness is relatively low. The voltage for the leds was measured at about 75V. I also noticed that no I can control with commands from the remote neither brightness nor contrast nor colors.Only the menu, volume and channel change work.
    Since I don't know much about led displays and before I order new leds, is there anything I can do?
    Is there any new firmware for Europe available? Thanks for any help.
  • petehall347
    • Jan 2015
    • 4426
    Re: toshiba 50L4333D TV with a LG 32L4300 board low brightness
    it may be in hotel mode .
    • pcbmaniac
      • May 2014
      • 81
      • Greece
      In this mode, the menu option would be available? Do i need to go into service mode to change that hotel mode or from menu as well?
      • petehall347
        • Jan 2015
        • 4426
        i don't know .. maybe find the manual and read it
        • dskall
          • Oct 2016
          • 2905
          • usa
          https://www.manualslib.com/manual/12...page=14#manual
          • yokoono
            • Apr 2010
            • 486
            Try MENU 9301.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              can you confirm you have a toshiba 50" 50L4333D TV and using it with a LG 32L4300 mainboard? im suprised that combination works at all
              • pcbmaniac
                • May 2014
                • 81
                • Greece
                Yes i can because i have a photo of the main board which said:
                32L4300 Rev 1.02A
                • lotas
                  • Jan 2016
                  • 4601
                  • Russia
                  "lg"?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    Originally posted by lotas
                    "lg"?
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      "lg"?
                      maybe this board he has
                      https://www.tvparts.co.uk/lcd-tv-spa...53D-MAIN-BOARD
                      when he said lg i thought would that even work.
                      • pcbmaniac
                        • May 2014
                        • 81
                        • Greece
                        Unfortunately, after a firmware update, the main board is not working properly.
                        Does anyone has the correct Europe firmware for this model?
                        • yokoono
                          • Apr 2010
                          • 486
                          Do you have a flash memory programmer?
                          • pcbmaniac
                            • May 2014
                            • 81
                            • Greece
                            Yes i have TL866A programer.
                            • yokoono
                              • Apr 2010
                              • 486
                              Bin 25Q16:
                              • pcbmaniac
                                • May 2014
                                • 81
                                • Greece
                                Originally posted by yokoono
                                Bin 25Q16:
                                I will try that and i will post again. Thank you.
                                • pcbmaniac
                                  • May 2014
                                  • 81
                                  • Greece
                                  Dear @yokoono
                                  I did try to flash successfuly the 25Q16 8 pin chip but unfortunately didn't work at all.
                                  When i was trying to plug the tv into power, the green light goes on brightly and then stays on with little bright. The tv never comes to life even if press the power button and from remote too. Only black screen with no light at all.
                                  I was wondering if i did something wrong with programming proccess.
                                  I just open the binary file you send and do programming with succesfull message in the end. Any suggestions?
                                  • pcbmaniac
                                    • May 2014
                                    • 81
                                    • Greece
                                    Does anyone has any suggestion to do before throw the tv to garbage?
                                    • yokoono
                                      • Apr 2010
                                      • 486
                                      1. Unsolder the memory and rewrite. Do not rewrite in the circuit
                                      2. Rewrite on a new memory.
                                      • pcbmaniac
                                        • May 2014
                                        • 81
                                        • Greece
                                        1) I did that and put the old memory into appropriate case, i check the pins and after programming i get "succesful" message from programer. Also i did a hex editor check and i see that the data has differences with original data.
                                        2) You mean to get a new chip and reprogram it?
                                        This tv is for european countries. Is you bin file valid for them?
                                        Sorry for my many questions.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                          LCD LED TV Service Menu Codes
                                          TCL LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          10-31-2024, 03:58 AM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
