toshiba 50L4333D TV with a LG 32L4300 board low brightness
  • yokoono
    • Apr 2010
    • 514
    Re: toshiba 50L4333D TV with a LG 32L4300 board low brightness
    I understand that you are trying to restore the TV to its initial state after rewriting another firmware. I also offer you a software for the stick. The installation instructions are in Russian.
    https://files.fm/u/fddttnd3a
    • pcbmaniac
      • May 2014
      • 81
      • Greece
      Should i use your flash bin file or my backup to do this?
      • lotas
        • Jan 2016
        • 4851
        • Russia
        Only with native backup.
        • pcbmaniac
          • May 2014
          • 81
          • Greece
          Hi all. I 've put the backup BIN file back to chip and then flash with the USB stick.
          I 've managed to revive my tv to the previous situation with no brightness, contrast, color ajdustments, just picture, sound and chanel change. So now i bellieve that something else is the problem. If i change the TCON pcb, do i have any chance to fix the problem?
          Any ideas?
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
            LCD LED TV Service Menu Codes
            TCL LED TV Service Menu Code
            LG LED TV Service Menu Code
            10-31-2024, 03:58 AM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
