LG 42LD420 no power
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Re: LG 42LD420 no power
    Oke i try that, all are 0V except 3.3V
    ...the quieter you become the more you are able to hear...
      • 12141
      • U.S.
      ok, now it's tricky but you can use a little precision flat blade screwdriver to lift the little tab that holds the wire in place and slip it out of the connector, you want to remove inverter on-off wire from connector on powerboard side, done with tv unplugged from power.
      • rtstorm
        • Feb 2012
        • 971
        • Croatia
        Ok, i remove it and test. Still 0V on Stand-by and 0V when Power On
          • 12141
          • U.S.
          then temporarily just tape the metal end of wire you removed so it doesn't accidentally contact anything, then with that wire out of the way, put the connector back in place, make sure that wire is out of the way and taped off, use about a 1k resistor to jumper from 3.5 to inverter on-off, then test tv.
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            Yea, now the backlight is working but no picture
              • 12141
              • U.S.
              #26
              ok, that should mean that your backlights and powerboard are ok, looks like the damage is on the mainboard, maybe test some things there, maybe check the voltage regulators on the mainboard, some testing there: https://www.youtube.com/watch?v=ocqnqmBxiqY
              • rtstorm
                • Feb 2012
                • 971
                • Croatia
                #27
                Thank you, will continue tomorrow.
                  • 12141
                  • U.S.
                  #28
                  can also check the fuse on tcon board, see if its blown, see if you have any voltage on either end of fuse neg. probe on chassis.
                  • rtstorm
                    • Feb 2012
                    • 971
                    • Croatia
                    #29
                    I check it and no voltage is goint to tcom board. So i guess the MB is dead. I check under microscope whole board and no shorts or visible damage. I found this component and i do not know what is it?
                    Label A952 (X1002 on board)
                      • 12141
                      • U.S.
                      #30
                      well it's not totally dead, it's sending some signals but not inv on-off to the powerboard but it could be partially dead, ever since I fixed my sony that was took out by lightning with a firmware update, I never rule out that a firmware update might do the trick but I don't know, the lightning may have just killed part of the board, but if all that is too hard to do, then a replacement mainboard should bring it back to life and may be the simplest solution.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        #31
                        Give the processor some heat, it's an LD series, so there's a good chance its suffering from BGA failure.
                        • rtstorm
                          • Feb 2012
                          • 971
                          • Croatia
                          #32
                          I would try to reflash it but i do not think that there are a fw update online or bios .bin file to flash
                            • 12141
                            • U.S.
                            #33
                            Indeed, that's always a problem, the tv makers just can't wait to take the firmware off their sites or just never make it available in some cases, they would rather sell us another tv than give us a way to fix the one we already laid out good money for.
                            • rtstorm
                              • Feb 2012
                              • 971
                              • Croatia
                              #34
                              Hey i found a board on ebay but the seller say that the board is from model: 37LD420
                              The board have the same code on it (attachment). Only EBU number is different but EAX number is the same. Will this work on my 42LD420?
                              • rtstorm
                                • Feb 2012
                                • 971
                                • Croatia
                                #35
                                Hello, just a quick update on this. I replace the main board and TV works. Thank you
                                  • 12141
                                  • U.S.
                                  #36
                                  glad to hear it, was it the board in post #34 that worked for you?
                                  • rtstorm
                                    • Feb 2012
                                    • 971
                                    • Croatia
                                    #37
                                    No, it was this one from ebay
                                    • GLISIT
                                      by GLISIT
                                      01-16-2025, 02:29 PM
                                      by sam_sam_sam
                                      03-31-2024, 02:12 PM
                                      Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                      by sam_sam_sam
                                      I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                      The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                      Found shorted diodes on main controller relays there are 3 of them that...
                                      01-07-2023, 05:43 PM
                                      09-06-2024, 05:59 AM
