Sony Bravia 50w808C - Gliched screen!
  • tmaster21
    • Feb 2021
    • 28
    • Portugal
    Hello guys. My bravia give up after only 4/5 years old. I post a video from what it does above. .I thoght it waas the tcom,ordered a new one from china ,and the problem stays exactly the same. Apears be an sync signal lost somewhere.
    What is your gess?
    https://photos.app.goo.gl/FSmWjFuHBLcxmVcn8
  • mmartell
    • Oct 2013
    • 3189
    Re: Sony Bravia 50w808C - Gliched screen!
    Something going on in the lower left of the screen ?
    You need to take the back off and remove the cable from each side of the screen in turn to see if you get a good picture on one side.
    • tmaster21
      • Feb 2021
      • 28
      • Portugal
      unfortunally i get same result. each half screen shows some picture but gliching, like if some frames pass to lcd,other(majority) not. it's not syncing or updating the picture... can a faulty cpu or broken solder do that?
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        To me it looks like the LCD has suffered some damage on the lower left. Check the tab bonds if someone “washed” the screen and also check the little LCD driver boards. You have to check voltages like vgl, vgh… etc.
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • JUCaESAl
          Sony bravia KD-65AF9
          by JUCaESAl
          Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
          Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
          10-20-2025, 04:03 AM
        • jimbo-bob
          Sony bravia kdl 46nx700 dim screen issue
          by jimbo-bob
          I have a Sony bravia kdl 46nx700. It turns on, but the screen is awfully dim.
          Things I have tried:
          Went into settings and increased the brightness and contrast. Screen did not change at all.
          Went into settings and made sure any auto brightness settings and limit is turned off. Did not see any difference again even after playing with brightness and contrast.
          Did a factory reset. Again no change. Then repeated the steps above. No change.
          At this point I think with myself that this is a hardware problem. Since my tv does not have any...
          02-04-2021, 04:33 AM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • PopsCaps
          Sony Bravia KDL-40V2500 that will not power on
          by PopsCaps
          I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
          I do not hear any sound and I cannot see any backlight.
          I have tried disconnecting every cable on each board one at a time to see if anything changes.
          The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
          My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
          03-25-2025, 11:23 AM
