Sony bravia kdl 46nx700 dim screen issue
  • jimbo-bob
    • Feb 2021
    I have a Sony bravia kdl 46nx700. It turns on, but the screen is awfully dim.
    Things I have tried:
    Went into settings and increased the brightness and contrast. Screen did not change at all.
    Went into settings and made sure any auto brightness settings and limit is turned off. Did not see any difference again even after playing with brightness and contrast.
    Did a factory reset. Again no change. Then repeated the steps above. No change.
    At this point I think with myself that this is a hardware problem. Since my tv does not have any warranty, I decide to open it up and have a look:
    There are no signs of blown capacitors or resistors or diods etc.
    I decided to measure the voltages on the pins going out to TCON board and the motherboard from the power board:
    When the tv is on (image on screen):
    TCON-ON 3.3V
    TCON VCC 12V 12.64V
    DIMMER-DC 3.31V
    DIMMER 1.659V
    BL-ON 3.05V
    BL-ERR 2.4mV
    REG12V 12.66V
    REG12V 12.66V
    REG12V-GND 7mV
    REG12V-GND 7mV
    AUDIO12V-GND 10.8mV
    AUDIO12V 12.7V
    POWER-ON 3.29V
    AC OFF-DET 3.34V
    STBY 3.3 3.34V
    When tv is off (power button is pressed and there is no image on screen):
    TCON-ON 0
    TCON VCC 12V 1mV
    DIMMER-DC 4.7mV
    DIMMER 4.9mV
    BL-ON 3.1mV
    BL-ERR 5.3mV
    REG12V 12.69V
    REG12V 12.69V
    REG12V-GND 3.6mV
    REG12V-GND 3.6mV
    AUDIO12V-GND 5.6mV
    AUDIO12V 12.71V
    POWER-ON 3.3V
    AC OFF-DET 3.35V
    STBY 3.3 3.35V
    So my questions are:
    Where does one find the voltage rating info for these pins? I came across manuals, but they only has schematics with no voltage info.
    I am bit suspicious about the DIM pin having ~ 1.7V. Is that meant to be the case?
    Any help is appreciated and I am happy to provide more information.
  • nomoresonys
    • 12276
    • U.S.
    Re: Sony bravia kdl 46nx700 dim screen issue
    Can you post some good clear straight on detailed pictures of each board and one of the whole back to see how they are all connected?
      Does it have Backlights level control? Backlights level control is not the same as Brightness (for Video).
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • PopsCaps
        Sony Bravia KDL-40V2500 that will not power on
        by PopsCaps
        I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
        I do not hear any sound and I cannot see any backlight.
        I have tried disconnecting every cable on each board one at a time to see if anything changes.
        The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
        My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
        03-25-2025, 11:23 AM
      • Chrissygizmo
        Sony KD-55XG9505 lines on screen problem
        by Chrissygizmo
        Hello again everyone,
        This is my latest mission, to try getting this Sony tv back to normal working order…
        I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
        02-19-2025, 11:31 AM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
