Grundig Vision 7 42-7975 - menu pin
  • betmen
    • May 2019
    • 89
    • Croatia
    I have one old Grundig tv which is working...but it have placed 4 digit pin for chanel scanning and some other settings.
    I don`t remeber pin any more so I can`t make any settings on tv.
    Does anybody know how to baypass or remove pin so I don`t have to write down 9999 or so 4 digit pin combinations to find out which one is it,
    I tried about 1500 so far...it is very boring and time consuming...
  • Diah
    • Feb 2013
    • 6346
    Re: Grundig Vision 7 42-7975 - menu pin
    Grundig /beko pins for different purpose are
    8500 2356 9301 4658 2011 2477 7493
      • 12082
      • U.S.
      maybe try: start menu-storage & reset-factory data reset-confirm it-erase everything.
        • 12082
        • U.S.
        if nothing works, I believe you can contact them and they will give you an over-ride code to put in.
        • betmen
          • May 2019
          • 89
          • Croatia
          It was 2356, thanks.
          Without code you can`t do factory reset.
          Thanks again.
            • 12082
            • U.S.
            yep, there's a few ways to get around it.
            • betmen
              • May 2019
              • 89
              • Croatia
              In the input list there is no "cable" so it can`t be scaned for programs over the cable from provider.
              Softvare is SSUGR.FHD.CIP.R128M.V02.T21.
              Is there any new software for this tv with "cable" included?
              • thommyX
                • Apr 2016
                • 93
                https://www.iwenzo.de/threads/grundi...kcode-2.72598/
                Post 15 V23
                ""Abhilfe: i8500 Service Modus eingeben und im Untermenü "Option0" Punkt "DVB Type" auf "DVB-T + DVB-C" einstellen""
                Greetings Thomas
                • betmen
                  • May 2019
                  • 89
                  • Croatia
                  This works, I found chanels but all chanels are stalling, they can`t be watched.
                  Is there any help in settings?
                  • thommyX
                    • Apr 2016
                    • 93
                    Did a factory reset after the software update? Hope you took the FHD version too?
                    • betmen
                      • May 2019
                      • 89
                      • Croatia
                      I did`n install software, just made adjustment in factory menu Option0 from "DVB Type" to "DVB-T + DVB-C", then made factory reset and I can scan chanels over cable.
                      Chanels are there but all of them are stalling and like that can`t be wached.
                      • betmen
                        • May 2019
                        • 89
                        • Croatia
                        Today I install software V23, FHD version, made factory reset, found chanels, but all chanels are stil stalling...
                        When I connect USB stick with video file it is played normaly.
                        Anibody know what is the problem?
                          • 12082
                          • U.S.
                          tuner might have gone bad.
                          • betmen
                            • May 2019
                            • 89
                            • Croatia
                            Radio stations works fine.
                              • 12082
                              • U.S.
                              that's lucky, none of my tvs even get radio.
                                • 12082
                                • U.S.
                                can you describe the "stalling"?
                                  • 12082
                                  • U.S.
                                  did the channels stay in memory, meaning if you turn it off wait a bit turn it back on the channels are still there?
                                    • 12082
                                    • U.S.
                                    can you play something over the hdmi?
                                    • betmen
                                      • May 2019
                                      • 89
                                      • Croatia
                                      Channels are played for 1-2 second then picture freezes for about 10-15 second or longer, then working agaain 1-2 sec and so on.
                                      All channels stays in memory, and over HDMI like over USB working fine.
                                      In factory menu I can`t open Option3 (don`t know what is in there).
                                        • 12082
                                        • U.S.
                                        wonder if a service remote would help fix it.
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                          LCD LED TV Service Menu Codes
                                          ALL LCD LED TV SERVICE MENU CODES
                                          Service Menu Code with Board Name
                                          China Universal Board / Jumper Board Service Menu Code
                                          Changhong Ruba Service Menu Code
                                          Ecostar LED TV Service Menu Code
                                          Orient LED TV Service Menu Code
                                          Haier LED TV Service Menu Code
                                          TCL LED TV Service Menu Code
                                          Samsung LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          Videocon LED TV Service Menu Code
                                          Supra LED TV Service Menu Code
                                          Toshiba LED TV Service Menu Code
                                          Symphony LED TV Service Menu Code
                                          Veste/ LED TV Service Menu Code...
                                          10-31-2024, 03:58 AM
                                        • Retro140
                                          Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                                          by Retro140
                                          So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                                          To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                                          06-18-2023, 06:13 PM
                                        • Ierwin
                                          Philips 58PUS7805 Menu working but no/weird picture from video sources
                                          by Ierwin
                                          I got a 58pus7805 that shows some weird behavior.
                                          The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                                          However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                                          I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                                          I managed to install the latest official firmware by holding the control button while plugging...
                                          03-10-2024, 12:50 PM
                                        • vf fa
                                          EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
                                          by vf fa
                                          Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
                                          I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
                                          So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
                                          01-31-2024, 01:40 PM
