Grundig Vision 7 42-7975 - menu pin
  • betmen
    • May 2019
    • 90
    • Croatia
    I have one old Grundig tv which is working...but it have placed 4 digit pin for chanel scanning and some other settings.
    I don`t remeber pin any more so I can`t make any settings on tv.
    Does anybody know how to baypass or remove pin so I don`t have to write down 9999 or so 4 digit pin combinations to find out which one is it,
    I tried about 1500 so far...it is very boring and time consuming...
  • Diah
    • Feb 2013
    • 6496
    Re: Grundig Vision 7 42-7975 - menu pin
    Grundig /beko pins for different purpose are
    8500 2356 9301 4658 2011 2477 7493
    • nomoresonys
      • 12306
      • U.S.
      maybe try: start menu-storage & reset-factory data reset-confirm it-erase everything.
      • nomoresonys
        • 12306
        • U.S.
        if nothing works, I believe you can contact them and they will give you an over-ride code to put in.
        • betmen
          • May 2019
          • 90
          • Croatia
          It was 2356, thanks.
          Without code you can`t do factory reset.
          Thanks again.
          • nomoresonys
            • 12306
            • U.S.
            yep, there's a few ways to get around it.
            • betmen
              • May 2019
              • 90
              • Croatia
              In the input list there is no "cable" so it can`t be scaned for programs over the cable from provider.
              Softvare is SSUGR.FHD.CIP.R128M.V02.T21.
              Is there any new software for this tv with "cable" included?
              • thommyX
                • Apr 2016
                • 96
                https://www.iwenzo.de/threads/grundi...kcode-2.72598/
                Post 15 V23
                ""Abhilfe: i8500 Service Modus eingeben und im Untermenü "Option0" Punkt "DVB Type" auf "DVB-T + DVB-C" einstellen""
                Greetings Thomas
                • betmen
                  • May 2019
                  • 90
                  • Croatia
                  This works, I found chanels but all chanels are stalling, they can`t be watched.
                  Is there any help in settings?
                  • thommyX
                    • Apr 2016
                    • 96
                    Did a factory reset after the software update? Hope you took the FHD version too?
                    • betmen
                      • May 2019
                      • 90
                      • Croatia
                      I did`n install software, just made adjustment in factory menu Option0 from "DVB Type" to "DVB-T + DVB-C", then made factory reset and I can scan chanels over cable.
                      Chanels are there but all of them are stalling and like that can`t be wached.
                      • betmen
                        • May 2019
                        • 90
                        • Croatia
                        Today I install software V23, FHD version, made factory reset, found chanels, but all chanels are stil stalling...
                        When I connect USB stick with video file it is played normaly.
                        Anibody know what is the problem?
                        • nomoresonys
                          • 12306
                          • U.S.
                          tuner might have gone bad.
                          • betmen
                            • May 2019
                            • 90
                            • Croatia
                            Radio stations works fine.
                            • nomoresonys
                              • 12306
                              • U.S.
                              that's lucky, none of my tvs even get radio.
                              • nomoresonys
                                • 12306
                                • U.S.
                                can you describe the "stalling"?
                                • nomoresonys
                                  • 12306
                                  • U.S.
                                  did the channels stay in memory, meaning if you turn it off wait a bit turn it back on the channels are still there?
                                  • nomoresonys
                                    • 12306
                                    • U.S.
                                    can you play something over the hdmi?
                                    • betmen
                                      • May 2019
                                      • 90
                                      • Croatia
                                      Channels are played for 1-2 second then picture freezes for about 10-15 second or longer, then working agaain 1-2 sec and so on.
                                      All channels stays in memory, and over HDMI like over USB working fine.
                                      In factory menu I can`t open Option3 (don`t know what is in there).
                                      • nomoresonys
                                        • 12306
                                        • U.S.
                                        wonder if a service remote would help fix it.
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                          LCD LED TV Service Menu Codes
                                          TCL LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          10-31-2024, 03:58 AM
                                        • Robby-Gr
                                          TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                                          by Robby-Gr
                                          I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                                          However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                                          The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                                          Additional issues:...
                                          09-27-2025, 12:02 AM
                                        • Retro140
                                          Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                                          by Retro140
                                          So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                                          To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                                          06-18-2023, 06:13 PM
                                        • Ierwin
                                          Philips 58PUS7805 Menu working but no/weird picture from video sources
                                          by Ierwin
                                          I got a 58pus7805 that shows some weird behavior.
                                          The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                                          However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                                          I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                                          I managed to install the latest official firmware by holding the control button while plugging...
                                          03-10-2024, 12:50 PM
