LG 47LG70 Salvaged
  • rblack711
    • Feb 2022
    • 20
    LG 47LG70 Salvaged
    I picked up this 47" TV and it didn't have a picture or sound, but it did have backlights. No visible damage on any of the boards, and all the voltages were normal on the power supply. I figured it was probably the main board, but could not find one available for this model right now anywhere. I thought I might as well try reflowing the large BGA chip as I have seen others have success doing it. I heated it with my cheapo hot air rework station for a few minutes, monitored the temp with a thermocouple, trying to keep the temperature around 450-500 deg F.
    I was very surprised to find out that the TV actually works 100% now! Just wanted to post this as a possible avenue to try for others in the future.
    • 12276
    • U.S.
    Re: LG 47LG70 Salvaged
    nice job, if it fails again report back, sometimes these reflows work a day sometimes for years.
    • SurrealMustard
      What parts can be salvaged from a plasma with a damaged display panel?
      by SurrealMustard
      I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
      03-09-2025, 08:29 PM
    • capwizard
      Fix Thermocouple
      by capwizard
      I have 3 thermocouples which I bought from Aliexpress has 2 meters long, very inconvenience to use. my question is thermocouple is two metal welded together. can I cut it then weld to make multi thermocouple?
      I cut open the one is not working, the wires are separated can I weld it and fix it?...
      03-13-2019, 11:17 AM
    • Peter_1402
      Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
      by Peter_1402
      Hi Everyone,
      I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
      1. Soldering iron works great
      2. There is a burnt mark on the hot air gun handle.
      I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
      Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
      Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
      Reed switch tested ok with a magnet.
      From the above test, I can conclude...
      07-12-2025, 11:50 AM
    • Justin_D33
      Is what I have compatible with this power supply?
      by Justin_D33
      Hello all. This is my Delta DPS-250AB PSU. It does not work anymore, and I'm assuming the cause is dried-out secondary capacitors. Specifically, those dreaded CapXons. I have some recap stock I salvaged from a dead ECS 945GCT-M3:
      1, United Chemicon KZG 560 µF 6.3V, there's one of these
      2, Sanyo WG 2200 µF 10V, there's 3 of these that came from the VRM area
      3, more Sanyo WGs, these came from the PCIe area. There's 3 in total, they are 6.3V ones. I forgot the exact capacitance, and I don't want to dig them out right now.
      09-30-2025, 06:23 PM
    • 5mall5nail5
      Motherboard component ID and can it be repaired?
      by 5mall5nail5
      Hey all - I have an mITX board that I moved from one case to another. I was showing my son how to work on PCs (maybe mITX wasn't the best) and so he was getting a guided install of putting the board in. It booted after we swapped cases, but it was failed to POST with a CPU light on after a few times. I removed the board and noticed that this component was bumped and the legs were (possibly) touching. I went to push it back gently and it looks like the legs came off on some but also a pad might have lifted? Anyway - going to reach out for warranty/repair, but in case they tell me its dead...
      06-02-2025, 11:29 AM
