Samsung TV 65 inch No picture, but sound
  • Teckman
    • Jun 2022
    • 4
    • Belgium
    Hello friends,
    I have a 65 inch Samsung TV here with a problem. The screen no longer has a "normal" image, but random color everywhere. Sound can be heard from the television from a program that is playing.
    The TV backlights are all fine and working great so I don't know where else the problem could be.
    Would anyone happen to know what the problem would be and what part would need to be replaced?
    Thank you in advance for your effort and cooperation!
  • Gjackson
    • Aug 2021
    • 134
    • Malta
    Re: Samsung TV 65 inch No picture, but sound
    Looks to be a T-CON board issue, There is another board hidden behind a piece of metal where I circled in red in the image I attached, you can see two ribbon cables going to it in the picture you sent. That board handles all video signals and if it goes bad those symptoms can appear.
    • Teckman
      • Jun 2022
      • 4
      • Belgium
      Thank you for your response!
      These cables lead to this (see photo). What would be the name for these parts?
      Could they be the cause of the problem?
      Kind regards
      • dskall
        • Oct 2016
        • 2905
        • usa
        Remove the stand and the metal plate.
          • 12331
          • U.S.
          it's one of those that looks like there might be a seperate tcon under that plate but there isn't.
          • Diah
            • Feb 2013
            • 6608
            you need to write the model of yours TV.. i think its another shit from samsung same to TU NU .. T-CON intergerated at Main Boards.
            • lotas
              • Jan 2016
              • 4892
              • Russia
              Ue65mu6100
              • Teckman
                • Jun 2022
                • 4
                • Belgium
                First, thank you for your responses.
                I've looked behind the metal plate before, but there's no T-Con Board there. There are two cables, which come from the motherboard, which continue behind the metal plate.
                These two cables lead to these parts V650DJ5-QS2.
                Kind Regards
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  I would heat up main processor and see if there's a change.
                  • Diah
                    • Feb 2013
                    • 6608
                    Kind Regards
                    this buffer boards of the panel you showed us the lable of it ... take out the speaker so you can take look on the whole boards.. check each side left and the right if they are one piece boards or 2 pieces connected with U ribbon cable..
                    in case u have the U ribbon cable. disconnect one by one each side and check if there any different at the display
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • Ierwin
                      by Ierwin
                      05-13-2025, 03:31 PM
                    • jchang
                      Samsung UN70NU6900F no picture and no sound
                      by jchang
                      Hi all
                      I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                      Symptom:
                      No picture no sound.
                      When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                      No sound at all.
                      What I tried:
                      1. I tried unplugging the left or right ribbon...
                      01-09-2023, 06:28 PM
                    • Dodgethis
                      Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                      by Dodgethis
                      Hello all,
                      This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                      09-11-2024, 07:39 AM
                    • JohnML1975
                      Samsung UA50TU8000W no picture and no sound
                      by JohnML1975
                      Hello All
                      have seen posts on this model in here but my problem sounded different so thought i would create a thread
                      TV will not turn on
                      There is no standby light
                      When I press ON button for remote the red standby light does flash but no picture and no sound
                      From the back of the TV I can see the red light on the back of the mother board
                      Holding torch to the screen I cannot see a picture
                      I removed the back cover
                      Observing the boards I cannot see any damage
                      I disconnected the main board from the power supply
                      the back...
                      08-30-2025, 09:40 PM
