Samwha Caps - help clarifying some markings please
  • pclyne
    • Jun 2010
    Got a plasma TV (its an "optima" - a re-badged LG) that has a problem with it's horizontal driver - All the picture seems to be condensed into a 4" band down the centre of the screen.
    Looking at the boards inside it, I see several bulged top Samwha's. Time to replace them.
    But I have a query. Some of these caps have the letters HE on them, some have HK, one has CE. Is it located down near the temperature. ie "105 C HK". This could be some sort of country/manufacturing code, or it could be important (tolerance/leakage characteristics/type)
    Can someone clarify for me please. (I have searched).
    Much thanks in advance...
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Samwha Caps - help clarifying some markings please
    that's (usually) the series marking.
    datasheets:
    Samwha HE
    http://www.samwha.com/electric/templ...st_pdf2/HE.pdf
    Samwha HK
    http://www.samwha.com/electric/templ...st_pdf2/HK.pdf
    couldn't find CE.. seems like this is not the series marking..
    Large can type list:
    http://www.samwha.com/electric/templ...ro_list24.html
    miniature type list:
    http://www.samwha.com/electric/templ...ro_list23.html
    • pclyne
      • Jun 2010
      @ Senic.
      THANKS HEAPS - I have spent ages trying to track this down. Let me guess - you found it in about 10 seconds...
      One more question if I may. Which company can supply some similar units?
      I spent several hours this afternoon trying to locate (via RS Australia) replacement units - I can do 105 deg C, but not 35 mm diameter, or all the physical dimensions line-up but the temp is only 85, or specs mostly match but they are 50mm high (only room for 35mm height).
      Heck I'd even use samwha again if only I could find a supplier who could sell me some.....
      Any recommendations?
      • Scenic
        o.O
        • Sep 2007
        • 2642
        i've searched for samwha cap datasheets before.. so i knew where to look
        the only other source for caps (as per this thread) would be Farnell AU
        but yeah.. custom cap sizes/specs kinda suck
        oh yeah.. it would help if you specified the values and sizes of the original c(r)apacitors..
        Samwha is replace-on-sight in my book..
        edit: just noticed.. farnell sells samwha c(r)aps
        • pclyne
          • Jun 2010
          Is there a way of editing your previous posts? I hit submit and _then_ realised I should have included the sizes...
          1000 uF 250 wv HE series
          330 uF 450 wv HE series
          680 uF 250 wv HK series.
          These are the 'bulgy' ones, I wasn't planning on replacing all the small units (I know I should) - just way too many...
          Basically get it fixed so I can get it back to my folks...
          • PlainBill
            • Feb 2009
            • 7034
            That failure doesn't make any sense. I can understand a CRT TV having a narrow horizontal sweep, but plasma TVs don't work that way.
            Agreed, the first step is to replace the bulging caps.
            PlainBill
