I have an old apfc psu in a Samsung TV using Samwha WL-series capacitors. By inspection they are obviously dead. Oddly enough the other caps in the TV seem okay. Samwha appears to be a dubious manufacturer but are they? Their WL datasheet seems like they did do something to rate the capacitors but nevertheless they failed first, spectacularly.
As a proof of concept fix I'm tempted to replace them (two parallel 82uF 450V low esr) with two *series* 470uF 230V general purpose capacitors...
Should last an hour at least to prove the rest of the TV works, no?
Then I wonder what model/brand of caps to use for a more permanent fix...
) However, considering all of these sets are from 15+ years ago, I don't think they did too bad. Now, it is possible that these caps could have failed even when the TV was back in use many years ago, but just didn't affect it enough to stop working. In any case, getting 15 years out of non-Japanese caps regardless if used or sat in storage, is not to obad IMO. In contrast, I've seen CapXon go bad as little as 2-3 years in old LCD monitors (though the one I saw did have a really hot-running PSU, so I won't blame the CapXon's alone.)
