td system k32dlm7h firmware tv
  • spantor
    • Jan 2020
    • 46
    • spain
    Hello.
    I have a problem with this tv. It constantly restarts just showing the logo. It has panel lc320dxy-ska8 and board cv512h-u42. I have seen firmware for the lc320dxy-ska6 panel on other forums but I have not been able to download it. I think how well it could be valid but I'm not sure. If someone can pass me some firmware I would be very grateful. Thank you
  • lotas
    • Jan 2016
    • 4665
    • Russia
    Re: td system k32dlm7h firmware tv
    Galatec tvs-3205mc _cv512h-u42_lc320dxy (sk)(a8)
    • spantor
      • Jan 2020
      • 46
      • spain
      My eeprom is 25q64jvsIQ winbond. It is not listed in my programmer. Could I select another type of model to read write?
      • lotas
        • Jan 2016
        • 4665
        • Russia
        What programmer?
        W25Q64 can you just put it out?
        • spantor
          • Jan 2020
          • 46
          • spain
          Originally posted by lotas
          What programmer?
          I use sofi sp8-A.
          In auto detect there are several options. I have selected 25q64cv. It reads correctly, but since it is not exactly the same id I am afraid of corrupting the dump and losing it.
          • lotas
            • Jan 2016
            • 4665
            • Russia
            And there is no superfluous one, some kind of 64 spi flash, so as not to touch the original one.
            • spantor
              • Jan 2020
              • 46
              • spain
              Sorry friend but I did not understand your last comment.
              I installed the dump you gave me and the symptoms were the same. It would start up and shut down, then sometimes it doesn't respond to the buttons but other times it does. I think it's a cpu failure or some other component. I have moved tv a bit and now it works perfectly so I would think that maybe it is a problem of negative to the main ones.
              Any suggestion would be welcome.
              • nomoresonys
                • 12206
                • U.S.
                check all the solder joints if you haven't already.
                • spantor
                  • Jan 2020
                  • 46
                  • spain
                  It fails randomly, it is not due to the movement of the tv. I think there may be a cold weld. Tomorrow I am going to apply hot air to the processor and other components with the hope that the fault will subside.
                  • spantor
                    • Jan 2020
                    • 46
                    • spain
                    By the way. Thank you very much for the help
                    • lotas
                      • Jan 2016
                      • 4665
                      • Russia
                      I meant to write a dump to another (new or removed from some kind of donor) not exactly like your original, but from a different company.
                      • slavetothesound
                        HP ProDesk 600 G6 Mini BIOS unlocked - now EC can't find valid firmware
                        by slavetothesound
                        I Used a T48 and RCUnlocker to remove password from the BIOS on a previously fully functional HP ProDesk 600 G6 Mini. Everything went very smoothly and I was able to boot the machine and install an OS. I then unplugged the machine and put it on the shelf for a week.
                        Now when I boot the machine, it does not POST. It plays 5.2 beep codes which are interpreted as:
                        I read the firmware with the T48 and it is different than what I flashed to it, so I flashed the unlocked firmware that I had saved. No change. I could use some advice on next steps to take.
                        04-12-2024, 10:05 AM
                      • TheUser
                        Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                        by TheUser
                        Hello to everyone ,
                        This is my first post here, and i would like to share with you a small story in case you can help me.
                        Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                        All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                        I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                        02-10-2024, 02:07 PM
                      • zklgfs
                        Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                        by zklgfs
                        I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                        08-11-2025, 02:14 PM
                      • gurj1979
                        Ubiquiti firmware help. US-8-150W POE
                        by gurj1979
                        Hi guys.
                        I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                        Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                        So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                        Got New chip and writes good.
                        THE PROBLEM...
                        It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                        Does anyone have a Good Firmware I can have?...
                        07-22-2024, 05:13 PM
                      • wattage
                        by wattage
                        Hello Badcaps Community,
                        07-13-2025, 04:41 PM
