Grundig 40VLE4421 - no picture
  • betmen
    • May 2019
    • 90
    • Croatia
    I changed few leds on led background and tv works for about one year.
    It is not much in use.Then stops working again, I checked leds on background, all are ok.
    When I light up the screen with lamp there is a picture but background is not working and you can`t se the picture on the screen.
    When I touch connector for led background with probes of backlight tester they light up and tester shows 108V. After that TV turn on normaly and picture is ok, backlight is working. After TV is turn of again backligt is not working, just on first turning on GRUNGDIG picture on boot is shown for part of the second and after that is dark screen.
    If I again touch connector for led background with probes of backlight tester, TV turn on with picture again. After turn of and on again there is no picture.
    Voltages on connector S2401 are:
    Pins 1 and 2 - 5,2V,
    pins 3-7 - 0V - GROUND,
    pins 8-11 - 19,08V,
    STBY - 2,75V,
    BL+ - 46,3V,
    BL- - 0,47V (last two when backlight is working)
    When backlight is not working:
    BL+ - 18,85V,
    BL- - 0V.
    other pins are the same.
    I changed all electrolites, checked diodes D2402,24112413,2406,2405,2415,2404,2416 on board and they shown ok measurements.
    What can be the problem?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Grundig 40VLE4421 - no picture
    I would say bad connection or bad led.
    • betmen
      • May 2019
      • 90
      • Croatia
      I checked and checked again leds, even replace two which are working but they start working last of all leds (I gradually increase voltage on each led strip) so I think leds are ok.
      Checked connector again today - ok.
      Anybody have some idea?
      • dskall
        • Oct 2016
        • 2905
        • usa
        With leds unplugged what voltage do you get from led connector when you first turn it on?
        • betmen
          • May 2019
          • 90
          • Croatia
          Connector unplugged - about 3,5 - 3,8 V for split of the second, then drop to 0v.
          Then if I again touch connector (connector pluged in) with probes of backlight tester, after try to turn tv on it turns on normaly.
          On connector first it get 112V then screen turnf off briefly and then the voltage gets to 132V. (this is normal procedure I think) onf tv is working.
          Then when I turn it off and try to turn it on ... nothing ...
          • Diah
            • Feb 2013
            • 6357
            cancle the sockets solder the wires of LED direct to the boards.
            • betmen
              • May 2019
              • 90
              • Croatia
              I soldered all wires directly to led stripes and from connector to the board...nothing changed, so bad connection on leds and led cennector is ruled out... any other ideas?
              • dskall
                • Oct 2016
                • 2905
                • usa
                Have you checked for bad solder joints on underside of led connector?
                • Diah
                  • Feb 2013
                  • 6357
                  can you tell yours Tv chassis code? you have it on the lable at back cover
                  • betmen
                    • May 2019
                    • 90
                    • Croatia
                    Tv chassis sticker is in attachment.
                    I think it is not bad solder joints because I soldered wires from connector directly to the elements on board which are connected to connector.
                      • 12129
                      • U.S.
                      show us a picture of your work.
                      • Diah
                        • Feb 2013
                        • 6357
                        yours chassis share same firmware with TT/TY
                        try to downgrade to V5, to close out if firmware did clitch at panel section.
                        how to:
                        Code:
                        Step 1:
                        Copy Target folder into USB memory.
                        Step 2:
                        Insert USB memory to the USB socket on the side of TV.
                        Step 3:
                        Press the “Program +” key of the keypad on TV and plug in the TV.
                        Step 4:
                        Hold down the “P+” key of the keypad on TV until you see that code installation has
                        started.
                        Step 5:
                        If the software is installed without any problems, TV will be started itself with the new
                        software.
                        Step 6:
                        Switch off the TV to remove the USB.
                        • betmen
                          • May 2019
                          • 90
                          • Croatia
                          Picture of soldered wires...
                          • betmen
                            • May 2019
                            • 90
                            • Croatia
                            how to:
                            Code:
                            Step 1:
                            Step 2:
                            Step 3:
                            Step 4:
                            started.
                            Step 5:
                            software.
                            Step 6:
                            Chrome is block this files for download.
                            Whad do you mean by "yours chassis share same firmware with TT/TY"?
                            • Diah
                              • Feb 2013
                              • 6357
                              grundig TV with chassis TT use same firmware as your TV chassis TY.
                              if your dirty chrome /pc have issue don't post such rubbish... instate you write thanks...
                              this is trusted clean firmware for downgrade.. next time i will not response to any of yours post.
                              • betmen
                                • May 2019
                                • 90
                                • Croatia
                                I dowloaded it with Opera...I don˙t know why are you angry.... I just told what hapened...nothing else, it is not
                                • dskall
                                  • Oct 2016
                                  • 2905
                                  • usa
                                  Got to love the language barriers on this forum. Easy to misunderstand each other.
                                  • betmen
                                    • May 2019
                                    • 90
                                    • Croatia
                                    My TV have sofware version TTGMR....V01.027.08 and TV does˙t have V+ key, programs can be changed only on remote, on TV is possible to change only volume.
                                    This TV is driving me crazy, when it turns on everything works ok, but for that I have to bust it first with led tester or it want turn on without that.
                                    Anybody have some idea, circuit diagram is in the first post.
                                    • betmen
                                      • May 2019
                                      • 90
                                      • Croatia
                                      Does somebody have some actual suggestion about how to try to fix this?
                                      This forum is about that...I think
                                      • thommyX
                                        • Apr 2016
                                        • 93
                                        There are almost 2 mistakes at Chassis Ty.
                                        Defective mainboard or defective lighting.
                                        The lighting is definitely to blame for you.
                                        Your LED strips are called ZCC606 and these always cause problems when repairing them. Always exchange completely.
                                        Any software that posts "diah" here is from my forum iwenzo.de
                                        Your software is old, but has nothing to do with your mistake.
                                        https://www.dropbox.com/s/omflqxh0a2...02.00.rar?dl=0
                                        LG Thomas
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • betmen
                                          Grundig 49 VLE 420 BN - no picture
                                          by betmen
                                          I bought this used TV as defective, it does not show any picture or menu screen.
                                          When it is turned on, there is no picture, but the backlight works.
                                          The motherboard is ZG7190R-9 and it is probably defective.
                                          Through ads I can buy a cheap TV Grundig tv 43 gua 7000 Barcelona with a broken screen. How can I find out which motherboard is in that TV because if it doesn't match I wouldn't buy it.
                                          Stickers from both TVs are attached....
                                          07-15-2022, 10:08 AM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • Pipolups
                                          Corsair K70 LUX RGB dying LEDs
                                          by Pipolups
                                          Hi there !
                                          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                          10-08-2024, 11:58 AM
