Samsung UE65KS9000 lines and reboot loop
  • mrsith
    • Mar 2021
    • 146
    • Wielka Brytania
    #41
    Re: Samsung UE65KS9000 lines and reboot loop
    Should it give me different readings when switching probes then?
    • Diah
      • Feb 2013
      • 6439
      Originally posted by mrsith
      It doesn't look like a cap, see last photo in my previous post.
      Took all 3 ESD diodes out and measured the pads, still all 9 of them shorted to ground.
      COF short
      • mrsith
        • Mar 2021
        • 146
        • Wielka Brytania
        #43
        Any possibility at all to find out which COF exactly? My friend has ordered a COF machine so I could take the TV to his workshop to try and sort it....what would be next steps to fix or bypass the problem?
        • Diah
          • Feb 2013
          • 6439
          follow the short point u got before and go where the line on screen.. you can trce it on the panel glass as the cof ribbon will not cover all pins on glass
          • mrsith
            • Mar 2021
            • 146
            • Wielka Brytania
            #45
            Unfortunately the lines show on the whole width of the panel, they just start by being short and become longer and more visible every reboot or so. Not really possible to find at which point of the screen they appear (possible to say on what height it starts, but not width as it's all over). I cannot see any traces going from shorted pads either.
            Is there any way I can confirm the COF short? Or are there any other possibilities at all? Tough diagnosis to accept
              • 12276
              • U.S.
              #46
              might be able to bypass it, there's one of many videos, you might even find one in English but it might take some looking, why youtube doesn't have a choice to search for a preferred language is a mystery: https://www.youtube.com/watch?v=wQA02AvViRE
              • Diah
                • Feb 2013
                • 6439
                yours photo... can you upload one for complete cof ribbon include the buffer boards
                • mrsith
                  • Mar 2021
                  • 146
                  • Wielka Brytania
                  #48
                  Pics attached with this particular ribbon next to the shorted spot.
                  • Diah
                    • Feb 2013
                    • 6439
                    i don't like the look of the end left & right cof ribbon specialty the right end.. its look like it had suffered from short of the COF. if you have microscope you can exam it because the first line are GND of the boards where the ESD GND side go same for left side first line GND of boards... yours ESD out side the boards if there no short to them put them back... and if this cof where the line.. take it out and wait to yours friend machine arrived to do it... but i have doubt it will worth.. as i mentioned before post #9 this panel are scrap and cheat from SAMI
                    BY the way... you have short messurment even the LVDS disconnect right !
                    • mrsith
                      • Mar 2021
                      • 146
                      • Wielka Brytania
                      #50
                      Right side of that ribbon looks tiny bit different because of hot air used to take ESD diode out. Surprised you've noticed that, good eye. I examined it closely and it seems totally okay. It surely was before desoldering at least.
                      This resistor/diode thing I've been asking about in #36 - if it indeed is a resistor, shouldn't it have constant resistance? And shouldn't the resistance be the same regardless of probe switching? I know this may sound silly, but the fault is getting worse with the set warming up, and this resistance getting higher with time seems a bit related. At least I hope it is, everything would be better than fighting with COFs....
                      • Diah
                        • Feb 2013
                        • 6439
                        take it out.. as its one pin go to GND where short point of ESD share with
                        but dont lost it LOL
                        • mrsith
                          • Mar 2021
                          • 146
                          • Wielka Brytania
                          #52
                          Just seen your edit from post 49...yes, I even disconnected the U-shaped ribbon connecting two buffer boards. The resistor/diode thing that I asked about in my previous post is on the other board. I mean, there are 4 buffer boards in total. The SMD is on the same side as 3 shorted diodes, but not on the same physical board, they were connected by the U-shaped ribbon. If I'm still reading short with that ribbon disconnected, I suppose I should be only looking at this particular board....
                          Are these diodes/pads 100% definitely shorted? I mean, is there any logical way in which these pads SHOULD be shorted to ground?
                          • Diah
                            • Feb 2013
                            • 6439
                            my questions was if the lvds between MB and panel disconnected while you trace the short on panel?
                            in general any check on panel all lvds must disconnected.
                            • mrsith
                              • Mar 2021
                              • 146
                              • Wielka Brytania
                              #54
                              yes, the motherboard isn't even attached to the tv at the moment. I remembered that lesson during fighting with Philipses recently
                              Just out of curiosity - is it still ok to have lvds tapes plugged into panel but not into mainboard? I had them disconnected both ends but still better to know for future.
                              • Diah
                                • Feb 2013
                                • 6439
                                only in case you are sure all LVDS gold pins are fine and nothings move aside ( make short ) or broken. my ways always to keep boards / panel SOLO. to avoid any miss from third party
                                • mrsith
                                  • Mar 2021
                                  • 146
                                  • Wielka Brytania
                                  #56
                                  Makes sense.
                                  Would a bad resistor, that reads for example 0.2ohm instad of couple of Kohms, possibly cause short reading on esd diodes?
                                  • mrsith
                                    • Mar 2021
                                    • 146
                                    • Wielka Brytania
                                    #57
                                    Hi again folks. I'm clearing my workshop so getting rid of old unrepaired stuff. Had a success with taping 70" Samsung recently, so got extra motivation to get back to this one.
                                    1st of all, I've soldered back the ESD diodes. Checked if the bottom pins aren't shorted with DMM. Top pins are all gnd anyway so didn't check them for shorts.
                                    Tried turning the TV on - it started but I had no picture at all, just backlight. It did reboot after a while so it looked like everything is as it was, and thought I must have had connected something wrong. Reseated all the ribbons - and the TV doesn't want to start anymore. Tried playing around with ribbons and cables - the backlight still goes on when MB disconnected. I am getting the red standby diode, it does blink when I press the power button, but that's it.
                                    Main board and PSU were both OK, and the TV started twice for a minute before reseating the ribbons. What could I possibly screw up this time? I've tried playing with ribbons, disconnecting them, taping part of them over etc - but can't get the TV so start again, even without picture.
                                    Honestly - is there any point in playing with this TV anymore or should I cut my losses and strip it for parts? Hate doing that when the LCD isn't broken but there's no point in keeping dead TV.
                                    • blaster_
                                      Samsung UE49MU6105K - boot loop, horizontal lines
                                      by blaster_
                                      Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                                      Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                                      06-22-2022, 05:19 PM
                                    • brkie
                                      Samsung UE75TU6905 reboot loop
                                      by brkie
                                      I have a Samsung UE75TU6905 from 2021, with a maximum of 10 hours of usage as it has been used as a presentation TV in the office. It started rebooting, the picture disappears, the sound continues for 2-3 seconds, and then it restarts (Samsung logo with Tizen OS), after which it returns to the previous activity. I tried disconnecting HDMI, antenna, WiFi, and using different power outlets, and it seemed to improve (or so I thought). Before, it happened occasionally, but now it happens all the time, so the TV stays on for a maximum of 30 seconds.
                                      I read on Samsung's website (reviews)...
                                      09-04-2024, 01:45 AM
                                    • Takeatry
                                      Yet another Samsung QLED Boot Loop
                                      by Takeatry
                                      Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                      10-04-2024, 02:57 PM
                                    • natiz
                                      Samsung QE50Q60AA - Reboot loop
                                      by natiz
                                      I have a QE50Q60AA that won't stay on - when turning it on, it makes the sound and reboots right after (sound is ok).
                                      Disconnecting the LVDS cable stops the restart loop but no image.
                                      I tried the tape method mentioned in other threads in many variations, but I couldn't get it to properly work (either reboot loop, or no image).
                                      Tested the caps on the left buffer board, no beeps.
                                      What else can be checked?...
                                      08-30-2024, 09:26 AM
                                      09-07-2024, 05:50 AM
