Samsung UE65KS9000 lines and reboot loop
  • Storyteller12
    • Jun 2020
    • 625
    Re: Samsung UE65KS9000 lines and reboot loop
    Looking closer at your pics in the first post. The 7th pic shows the cof tab burned up if I not mistaken. I had this happen on a 75” ks9000 model before.
    I got it from a customer. I plugged it in to test and flames shot out the bottom. Opened it up and the cof tab caught on fire and burned a whole through it.
    Unfortunately it’s trash at this point. But just to confirm you can pull the tab off completely and power on. Should stay on but will have a black strip on the screen when the cof tab was pulled.
    • mrsith
      • Mar 2021
      • 146
      • Wielka Brytania
      The COF tab isn't burnt, it was just reflection on that photo.
      I'm suspecting mainboard at this point, a resistor or possibly a diode fail. Not sure how to identify VGH-responsible components though. Do you know if any boardview or schematic is available for this board? BN41-02504a / BN94-10989A
      Also I have noticed one of the diodes (Ajs7, see photo) measurements seem odd, gives me 126 one way and 210 the other way. Shouldn't it conduct just one way?
      Do different sizes of this model share the exact same maninboard? Seems like it looking on service manual. Thinking about sourcing replacement mainboard. Found one from UE65KS9000T but BN94 number slightly differs (BN94-10844F vs mine BN94-10989A). Would this one do? It's price is a third of bn94-10989a's available no ebay...
        • 12307
        • U.S.
          • 12307
          • U.S.
          ok, my bad, i didn't notice it was from same size.
          • mrsith
            • Mar 2021
            • 146
            • Wielka Brytania
            The board I found is from the same size TV, think I'll give it a try then.
            edit: not sure what's the difference between those two (if there is any). Mine says UE65KS9000TXXU, the cheaper ones I could find are from UE65KS900LXXH or UE65KS9090T(X/K)ZG (blurry photo). They're both BN94-10844f. Looking on the photos there is no visible difference between them and mine board. Why different BN number then? Not really keen to spend almost 100 quid for the same model as I have, but if there's any risk of incompatibility I'd rather not try.
              • 12307
              • U.S.
              #26
              what is your panel number? white sticker on metal chassis someplace.
                • 12307
                • U.S.
                #27
                or if the seller knows their business, they might be able to tell you if it will work, most don't want to sell the wrong thing, because usually only the shipping companies win when that happens.
                • mrsith
                  • Mar 2021
                  • 146
                  • Wielka Brytania
                  #28
                  Cy-xk065fllv5h
                  Edit: ebay sellers say it's a trial and error and it might work, it might not. Googling/ebaying screen number doesn't clarify that, but I couldn't see any single proper match for my panel number + bn94-10844f.
                  I'll try to hunt my exact board number in reasonable price, in the meantime any advice/ideas how to diagnose and fix mine would be highly appreciated.
                    • 12307
                    • U.S.
                    #29
                      • 12307
                      • U.S.
                      #30
                      hard to get any conclusive results of what matches with this tv, I see one here that matches your part number so we know it will work, not sure if it's a good price or not: https://www.electromix.co.uk/main-pc...l5514-wg2.html
                      • mrsith
                        • Mar 2021
                        • 146
                        • Wielka Brytania
                        #31
                        I managed to get a straight answer - BN94 number has to be a match. I was digging yesterday and ordered exactly the same board as you linked above, it's the best deal available. The rest are ~£80+ so almost double this money.
                        Thank you once again and I will let you know as soon as the parcel arrives and I'll test it. Pretty excited, I really hope this is it.
                        Just in case though - how do I test diode packs? 2-legged diodes are straightforward, not sure how the 6-legged ones should be operating. Many many thanks
                        • mrsith
                          • Mar 2021
                          • 146
                          • Wielka Brytania
                          #32
                          Cannot edit the post unfortunately.
                          Please see pic attached: all of the top pins of all 3 diodepacks marked .e5 are shorted together and to the ground. I have checked bottom pins vs other bottom pins, no continuity. Top pins vs bottom pins, no continuity. I have tried every single combination possible, switched black and red probes etc. I think I'd expect middle pins to be ground, left side continuity top-to-bottom (or opposite) with the same on the right side?
                          I've measured kb0n diodes in different place and they seem to measure as expected - both middle pins are ground, there is one-way continuity between top and bottom left pins, same with right side.
                          Does it mean the .e5 diodes are bad, or that there's actually a short on that line?
                          Also there's an IC (photo included), what is it responsible for and is it any way to test it as well? Just want to completely rule out panel boards while I can still cancel the mainboard order today
                            • 12307
                            • U.S.
                            #33
                            Wish I knew, I'll have to leave that question for the pros, was a good thread about them on here not long ago, I'll take a look for it.
                            • mrsith
                              • Mar 2021
                              • 146
                              • Wielka Brytania
                              #34
                              This big IC seems to be a flash memory so I can probably rule it out. It's just the weird diodes' behaviour that concerns me. And given that this sets have common problems with diodes...
                              If anyone could help me identifying them, I'd just try and replace all 3 to see if anything changes. I'll wait with trying new mainboard until I'm 100% sure the panel boards are okay.
                              Pros
                              • mrsith
                                • Mar 2021
                                • 146
                                • Wielka Brytania
                                #35
                                Been trying to identify these components over weekend. I have attached a datasheet of the closest thing I could find (same or similar package type SOC363 and marking E5), but I am far from being sure this is it. Any ideas how to proceed?
                                • mrsith
                                  • Mar 2021
                                  • 146
                                  • Wielka Brytania
                                  #36
                                  Apologies for yet another post, I hate that I cannot edit older ones anymore.
                                  So I decided to give it a go and check once again everything on the panel boards. Again didn't find any shorted caps, so started taking measures of all resistors to try and find something out of order.
                                  Firstly I was a bit surprised that one of the resistors had only 0.2ohms while most of them ranged in Kohms. But going further there was something that looks like schottky diode - didn not get continuity either way on it. Checked with ohms - resistance was rising, from about 0 to 60k ohms. Switched probes and again - from negative values until around 28k ohms. The higher the value, the slower it went up. Took about 20-30 seconds until it stopped.
                                  I have also noticed that if I took a probe away and put it back on a pin within short time (5 seconds?), it didn't raise from 0, started mid-way.
                                  Not sure if this is wrong because I'm not entirely sure what smd I have been measuring (suspecting schottky but is it really it?), but the behaviour seems similar to the lines appearing on the screen - almost nothing on cold start, the longer the set is on, the more lines appear, up to the point they are over whole screen.
                                  If it is indeed a diode, how can I identify it's values so I can search for replacement?
                                  I'm getting repair-depressed again, desperately need a success
                                  Any help at all highly appreciated!
                                  • Diah
                                    • Feb 2013
                                    • 6499
                                    take out all esd diode from the buffer boards and see if the short remain... tv will work with out them
                                      • 12307
                                      • U.S.
                                      #38
                                      hopefully that's a cap you have been measuring, don't think diodes should read like that.
                                      • mrsith
                                        • Mar 2021
                                        • 146
                                        • Wielka Brytania
                                        #39
                                        It doesn't look like a cap, see last photo in my previous post.
                                        Took all 3 ESD diodes out and measured the pads, still all 9 of them shorted to ground.
                                          • 12307
                                          • U.S.
                                          #40
                                          i think that's a resistor.
                                          • blaster_
                                            Samsung UE49MU6105K - boot loop, horizontal lines
                                            by blaster_
                                            Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                                            Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                                            06-22-2022, 05:19 PM
                                          • brkie
                                            Samsung UE75TU6905 reboot loop
                                            by brkie
                                            I have a Samsung UE75TU6905 from 2021, with a maximum of 10 hours of usage as it has been used as a presentation TV in the office. It started rebooting, the picture disappears, the sound continues for 2-3 seconds, and then it restarts (Samsung logo with Tizen OS), after which it returns to the previous activity. I tried disconnecting HDMI, antenna, WiFi, and using different power outlets, and it seemed to improve (or so I thought). Before, it happened occasionally, but now it happens all the time, so the TV stays on for a maximum of 30 seconds.
                                            I read on Samsung's website (reviews)...
                                            09-04-2024, 01:45 AM
                                          • Takeatry
                                            Yet another Samsung QLED Boot Loop
                                            by Takeatry
                                            Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                            10-04-2024, 02:57 PM
                                          • natiz
                                            Samsung QE50Q60AA - Reboot loop
                                            by natiz
                                            I have a QE50Q60AA that won't stay on - when turning it on, it makes the sound and reboots right after (sound is ok).
                                            Disconnecting the LVDS cable stops the restart loop but no image.
                                            I tried the tape method mentioned in other threads in many variations, but I couldn't get it to properly work (either reboot loop, or no image).
                                            Tested the caps on the left buffer board, no beeps.
                                            What else can be checked?...
                                            08-30-2024, 09:26 AM
                                            09-07-2024, 05:50 AM
