22LG3DDH stuck in hospital/hotel mode
  • nomoresonys
    • 12184
    • U.S.
    Have this little tv seems to be stuck in hospital mode, only have universal remotes, just trying to get it in regular tv mode or at least get the hdmi working, when pressing input button on tv it just goes bank 1,2,3,4, hdmi never shows as an option. Yep I have been too dumb to figure it out so far.
  • Diah
    • Feb 2013
    • 6367
    Re: 22LG3DDH stuck in hospital/hotel mode
    in menu - Lock. you may have system Lock (ON ) need to turn it off.. LG default password 0000 if you are lucky no one change it.. if this the case then only IN_STOP help.
    • nomoresonys
      • 12184
      • U.S.
      Thanks Diah, system lock is off, it's an oldie from 2010, doesn't seem to have wifi, don't I need wifi on both tv and phone to work the in_stop?
      • Diah
        • Feb 2013
        • 6367
        no need to any wifi or lan.. IN_STOP should be send via IR sender.. so mobile with IR will do the job. if not you need to DIY one Ir with headphone jack to play wave file.
        EDIT: BTW the old LG from 2010 will have reset puttom close to AV In as i remember
        • nomoresonys
          • 12184
          • U.S.
          yes, I saw that reset button previously and tried it, held it for 30 seconds but no joy. Wonder if that button is suppose to put it back to factory?
          • R_J
            • Jun 2012
            • 9535
            In the service manual, the reset button is just a manual reset, this reset normally happens when you plug in the tv
            If 0000 did not work, try 0413 or 1105 (the hotel etc. may have set their own code)
            There are a few other options here https://theconchtech.com/smart-tv/lg...ithout-remote/
            • nomoresonys
              • 12184
              • U.S.
              I did previously get into ez-adjust menu with 0413 but I didn't see anything in there to turn off hotel mode.
              • nomoresonys
                • 12184
                • U.S.
                this is in the easy adjust menu when opened with 0413: http://beau.org/~jmorris/linux/lg-hacking/ez-adjust.txt
                • lotas
                  • Jan 2016
                  • 4597
                  • Russia
                  Maybe the instructions will help
                  Mode Setup Guide
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    The TV has a feature called external input blocking, perhaps the inputs have been blocked ?
                    • Diah
                      • Feb 2013
                      • 6367
                      since you are able to call EZ_Adj then you can send IN_STOP for hard reset ( shipping condition ) and IN_START for turn on or off future and option.. all will use same code as you did before 0-4-1-3
                      • nomoresonys
                        • 12184
                        • U.S.
                        trying to get a diy rf blaster working with amazon hd 10, tried lean remote, keeps saying your phone isn't rf blaster capable, do any of the remote apps work right except anymote, which is not free?
                        • nomoresonys
                          • 12184
                          • U.S.
                          Only getting the screens in the link in post #8, Don't think I can get it done from that ez-adjust menu, not seeing in_stop, looks like only a service remote will do it.
                          • Diah
                            • Feb 2013
                            • 6367
                            In_STOP after you put the code 0431 TV go to Stanfby, nothing will show on screen.. because its hard reset..mean after turnning it on you need do the first install..
                            IN_Start after code it will show you optiones of service menu.
                            • angelos
                              • Dec 2012
                              • 571
                              • South Africa
                              Hi Nomoresonys,
                              Just a note. If you don't have a LG service remote which in my country is only supplied to LG service agents I can help you get a cloned remote if you like?
                              • nomoresonys
                                • 12184
                                • U.S.
                                no worries they're only 8 bucks, I just don't want to add to my dusty collection of very seldom used crap.
                                • angelos
                                  • Dec 2012
                                  • 571
                                  • South Africa
                                  I have a supplier in Italy that manufactures blank remotes of which they get programmed via a device on a USB port. You can use the remote to set it up for almost any tv out there.
                                  I have got one step further with the lads from Superior Remotes and they sent me a infra red reader. I now capture remote codes from remotes that I want cloned and I email it to them. They then make it available on their database so that I can clone the remotes using their blank units.
                                  This way I came across the LG service remote of which I immediately made a copy and wow, i know don't have to struggle with a WAV file and a infra red wire connected to the laptops audio out socket to transmit the bit pattern that corresponds to IN-START etc.
                                  I now have my own service remote and stuff all LG agents who would not sell me one, those bustitches.....
                                  Hope you understand.
                                  • angelos
                                    • Dec 2012
                                    • 571
                                    • South Africa
                                    https://superior-electronics.com/en/...ols/#universal
                                    • nomoresonys
                                      • 12184
                                      • U.S.
                                      ok, I see what you mean, that would be much easier than messing with wav and laptops and diy blasters.
                                      • angelos
                                        • Dec 2012
                                        • 571
                                        • South Africa
                                        Just holler if you want to clone that remote. This depends if someone is importing these remotes from Italy.
                                        You will need
                                        1. Superior blank 2 in 1 remote
                                        2. USB Programming tool
                                        • modtool
                                          HP x360 Chromebook 14A-CA, DA00GIMB6H0 REV:H, flooded, restored, slow and stuck in tablet mode
                                          by modtool
                                          Dear colleagues,
                                          I've entered the repair of the chromebook machines just one month ago and I've found some significant differences from the classic laptops or macbooks, so I'm searching some advices.
                                          The owner of this chromebook gave it to me after it has been left flooded by water for almost a week, so chances of repair were not so high, the mainboard was oxidyzed in many spots but I made a nice cleaning, resoldering and component replaging work and now it is almost working.
                                          Among other things I've cleaned many spots from oxyds, reballed CPU, EMMC, EC, replaced...
                                          05-07-2025, 06:10 AM
                                        • The_Memory_Guy
                                          Dell T7820 stuck in Bios Recovery Mode
                                          by The_Memory_Guy
                                          HI,
                                          I have a Dell T7820 stuck in Bios recovery mode. I never get Dell Boot screen or anything visible on screen. The system just gives me 3 white lights and 3 orange lights indicating Bios recovery mode.
                                          What I have tried to get to recover the Bios, there seems to be some conflicting advice about recovering the system.
                                          All of them say to download the latest bios from the dell website which is a .exe file. I have done that
                                          https://www.dell.com/support/product...BUT090/drivers
                                          Some...
                                          07-07-2025, 06:52 AM
                                        • grimacelord
                                          PS5 | CFI-1215A | EDM-030 | Stuck In Safe Mode 99% Processing
                                          by grimacelord
                                          I have a CFI-1215A PS5 (EDM-030 board) here that won't boot normally. It currently will immediately boot into Safe Mode upon power button press with a screen that says "Processing" and then a progress bar that usually begins around 75-84% and slowly climbs up to 99% where it will hang forever. The console will not ever escape past the 99% mark.
                                          Things I have tried:
                                          1. Tried force booting into Safe Mode by pressing and holding power button for 2 beeps so I could use a reinstallation USB, but the console still boots into Safe Mode with the...
                                          03-27-2025, 12:09 PM
                                        • bseinfo
                                          Brother MFC-J480DW printer stuck in maintenance mode
                                          by bseinfo
                                          I have a Brother MFC-J480DW printer stuck in maintenance mode (BHL2 USB Maintenance). The screen only shows white bars, and it’s completely unresponsive. The official Firmware Update Tool doesn’t detect it, and I’ve tried multiple versions.
                                          I’m looking for the raw firmware file LZ5313_L.blf (or .djf), compatible with FILEDG32.exe, so I can attempt a manual recovery.
                                          If anyone has a full dump of this model (or a compatible one like MFC-J485DW or J885DW), or knows a private Discord or Telegram group where this kind of firmware is shared,...
                                          07-05-2025, 10:53 AM
                                        • Omron
                                          Kenwood KDC 3051G Car Radio permanently stuck in Demo Mode please help
                                          by Omron
                                          Hello Guys! I have trouble with my car radio Kenwood KDC 3051G I hope someone more knowledgeable can help me, I tried everything in my power that I stumbled upon online.
                                          My radio is permanently in demo mode, it says Press Volume Knot Cancel Demo and when I press it nothing happens.
                                          - Tried to unplug radio and plug it back in into power,
                                          - Tried to reset radio by holding reset button key for 5,10,30 seconds while in power and without power, plugging it back in, it wouldn't work.
                                          - Tried to hold 3,6 while turning it back on and then pressing 1,2...
                                          05-23-2024, 01:27 PM
