philips 65pus6162/05 pfc ic faulty
+ More Options
Posts
  • jimbofz
    • Apr 2013
    • 537
    • uk
    Hi
    this tv uses LD7591T ic for pcf boost voltage in psu
    the chip is s/c
    causing dead no led lit
    only 330v across main smoothing caps
    so no boosted voltage or stable secondary o/p voltages
    ive tried all the usual suppliers no one has this chip
    i can order from china but dont want to wait until july
    can anyone suggest a supplier here in uk
    or maybe possible equivalent
    the chassis type is tmp 17.7e la
    thanks
  • jimbofz
    • Apr 2013
    • 537
    • uk
    Re: philips 65pus6162/05 pfc ic faulty
    any thaughts?
    • dskall
      • Oct 2016
      • 2905
      • usa
      I have bought on ebay and AliExpress. Stuff from China off of ebay seems to get here faster.
      • jimbofz
        • Apr 2013
        • 537
        • uk
        thanks for taking time to reply
        .looks like i will just have to live with this monster tv under my feet untill july
        • tony359
          Faulty CRT AKF12/Philips CM8500: bad flyback?
          by tony359
          I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
          What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
          There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
          Can it be a short somewhere...
          08-22-2023, 04:39 PM
        • Spudgun
          Why doesn't current just bypass faulty capacitors.
          by Spudgun
          Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
          04-01-2025, 10:33 AM
        • aidanmo
          Philips 43PUS7506/12 - Loud blown out sound
          by aidanmo
          I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
          I thought maybe the speakers got damaged, so I replaced them - no dice.
          • Using the internal speakers, it always happens.
          • Using the headphone jack, it never happens.
          • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
          02-28-2025, 03:13 PM
        • b-slayer
          Acer A317-53 need help to disable faulty onboard ram
          by b-slayer
          Hello.
          I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
          - first one is to modify le bios to disable the onboard ram.
          - second one is to disable the onboard ram by desoldering some components on the mainboard.
          so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
          so i found that my motherboard...
          10-12-2024, 03:46 AM
        • brispuss
          Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
          by brispuss
          Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
          Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
          I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
          12-28-2022, 02:58 AM
