Sony Bravia KDL-70W850B T-CON board / software update issue
  • shahnld
    replied
    wel. he just did not provided the firmware. otherwise there is no further issue with the tv..
    replied
    If Nick couldn't help you then I doubt any one can, he knows sonys from front to back.
    replied
    Well hell if I know, that's a strange one, the procedure is there: https://www.sony.co.uk/electronics/s...tware/00267389
  • shahnld
    replied
    Oh mate.. think of anything possible doing with that file and i have done that. 1st file. 2nd file. even 2nd file extracted, renamed, i have tried more than 100 times with 10 different usb sticks in different ways.. pfff. non helped. .pkg is the only way for it to work same like a windows bootle usb/disk can start the setup. putting extraced windows or iso or .zip will never boot for setup..
    .zip work only when the tv is working and you want to update its firmware then you access it with the tv menu and run it..
    It will never start the update from a usb port on its own.
    replied
    Ok, did you do this, when you see that second zip file, that is the one you want to put on your thumb drive, try that it should work.
  • shahnld
    replied
    If you mean the one in video then that is not my tv. My set is kd-65xg9505,. and all i can see is .zip on sony site for this model.. So yes i am downloading the right firmware but that is not .pkg.
    replied
    Are you sure you are getting the proper software? from what I see it was taken off 01/30/2022
  • shahnld
    replied
    Try using a 4gb or less drive, Nick knows the procedure: https://www.youtube.com/watch?v=3kYPjIHt8Lc
    Wel. As you can see in the video. His downloaded file is a .PKG file. not a zip file after extraction. This is the issue. When i extract the file for my tv. i dont get a .pkg but again a .zip with multiple files in there.
    I have also contacted nick and sad enough no clear anwser from them only suggested download from sony site which i end up again with .zip firmware.
    replied
  • shahnld
    replied
    Good Day.
    I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
    i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
    renaming, in original state nothing helps. any idea's which may help is welcome..
    cheers
    replied
    Re: Sony Bravia KDL-70W850B T-CON board / software update issue
    Originally posted by eclectric
    The backlight still comes on with either new or old tcon board. It turns on and shows full picture with the old tcon installed, sound and menus work. It shows my android box backgrounds and looks great with no lines or dead pixels... but shuts off after 10 seconds with tcon error.
    That's what burns my ass... that it can work, it just chooses not to.
    ok, does it come back on by itself after it shuts of, like on 10 seconds off for whatever time then back on for 10 seconds or it just shuts off and stays off?
  • Diah
    replied
    with original T-CON. if you unplug BL_ERR wire from the socket.. what will happen?
    did you inter diagnose mode from STB and cleared error count??
    also i suggust you to messure direct on LED+ and LED- all channel at start up see if the reading are same--
  • eclectric
    replied
    Originally posted by Diah
    for me this reading after PS_ON send to PCB BL_ERR are high.. and i think you had never noticed BL come on since u worked on it... i would never spend any parts for it unless you are sure 100% LED BL & its circuit are fine. this same belong to nomoresonys TV.
    replied
    agree 100 percent, I always try to verify backlights and powerboard first.
  • Diah
    replied
    I'm getting .05V in standby, 1.08V while powered on. +12V and +3.3V on the power board are also normal.
    replied
    from all i read, some did fix this issue with a replacement mainboard, I think I overcooked mine and the replacement for my model was 150 or so, seems like more than the tv is worth, I'm curious if one would fix it BUT not quite that curious. :
  • eclectric
    replied
    Would a new main board possibly solve this issue? I don't mind throwing a bit of money at it if there's a good chance it would work. Seems awfully nice to throw away when it technically should work.
  • eclectric
    replied
    Indeed, lots of similar problems I've had and seen here and elsewhere, can't solve it for some reason, can you report the voltage of the BL_ERR pin on the powerboard connector, black neg. probe on chassis ground, red pos. probe on the pin, check in standby[tv plugged in but off] then power on and check it while it's on for those 5-10 seconds, report voltages.
    replied
    ok, thanks Diah, didn't know if it was suppose to be high or low power, unpower, like some voltages high is right some low is right, hard to comprehend at times.
  • Diah
    replied
    yes it was high all the time 2.3, been trying to find out what that bl-err voltage should be on a working tv but no luck, that is, what it should be at standby and when powered up.
    of course <=0
  • x_orange90_x
    TCL 50S535 bad tcon or panel issue?
    by x_orange90_x
    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
    03-29-2025, 11:02 PM
  • thelankanguy
    Sony KD-55X9000F TCON Issue
    by thelankanguy
    The TV shows a black screen with no image.
    TCON ribbon connectors were disconnected individually for image and there was no half image even.
    Later both ribbons were disconnected and TCON voltages were tested.
    12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
    There is also a short to ground in this circled inductor.
    Is this a TCON issue or something else ?...
    12-13-2024, 12:27 AM
  • cagri
    BOE HV650QUB-F70 TCON issue - VGH AVDD HAVDD no voltage - caps seem ok
    by cagri
    I have an Arcelik TV with BOE HV650QUB-F70 TCON board, but I think there's an issue with/around PMIC.
    PMIC: iML8940
    There is backlight and sound, but no picture. I watched a YouTube video and turned it off, half an hour later it was dead.
    Input 12v, fuse ok
    DVDD1V2 = 1.2v
    DVDD1V8 = 1.8v
    DVDD3V3 = 3.3v
    VGL = -7v
    **VGH = -0.3v
    **VCOM0, AVDD, HAVDD = 0v
    SWBK1 = 3.3v
    SW1 = 12v
    VGH to GND resistance is 500kohm as expected
    Readings are same after I disconnected the two cables from TCON to panel...
    07-27-2023, 09:48 PM
  • T4-BR
    T470S - TPM issue since TPM/BIOS update from Windows Update
    by T4-BR
    Many thanks for the high quality ressources available on your website.
    I'm currently facing some issues with my T470S:
    - I sat a Supervisor Password using special chars which was causing issues
    - Access to BIOS was locked but I was still able to use my PC
    2 weeks ago, I got an update of BIOS/TPM from Windows Update.
    Computer restarted and after Lenovo logo a loading bar appeared and at the end something went wrong + an error popped.
    Computer restarted one more time and I got the prompt for typing Bitlocker...
    09-26-2024, 02:50 AM
  • ahmypc
    Microsoft Surface Pro 4 Bios Update Issue
    by ahmypc
    The device that has not received an update for a long time cannot update the new ME Region. That's why touch doesn't work. Bios file cannot be opened with Flash Image Tool. Additionally, I am attaching the update file downloaded to the device and the original bios file. I would be glad if you help....
    09-21-2023, 02:14 AM
