Sony Bravia KD43XF7596BAEP - Android no picture
    • 12085
    • U.S.
    Re: Sony Bravia KD43XF7596BAEP - Android no picture
    maybe check the caps on on panel driver board/s.
    • Spc.
      • May 2022
      • 16
      • Slovenia
      TV is now 3 years old.
      We bought it arround 05/2019
      It worked flawlessly, no problems and now this.
      I'll let you know if I fix it, thanks everyone for quick response.
      • kasfamily
        • Aug 2014
        • 765
        • Russia
        On the T-con board, check the voltage at the control points designated V15/ V25, etc.
        • dskall
          • Oct 2016
          • 2905
          • usa
          You need to check t-con voltages and data lines. But I would suggest getting a new t-con.
          • kasfamily
            • Aug 2014
            • 765
            • Russia
            • Spc.
              • May 2022
              • 16
              • Slovenia
              #26
              Thanks, i'll do that tomorrow.
                • 12085
                • U.S.
                #27
                this one worked fine, then I think I went to switch from tv to hdmi source, them bam no video or backlight, no warning and no acting strange like some will do before a problem gets worse, just straight from working fine to that problem described.
                • Spc.
                  • May 2022
                  • 16
                  • Slovenia
                  #28
                  HDMI ARC is only for audio channel return right ?
                  So i can't connect this tv to another display to check if OS is working correctly.
                    • 12085
                    • U.S.
                    #29
                    HDMI ARC: https://www.tomsguide.com/us/hdmi-ar...ews-26262.html
                    • Spc.
                      • May 2022
                      • 16
                      • Slovenia
                      #30
                      Yes it's audio only.
                      It can't do video output to other display via HDMI to check if it works on other monitor.
                      • Diah
                        • Feb 2013
                        • 6344
                        Dont play any more with ribbons... you will damage them. take out the white heat sink of the MB Soc. and tell which type MT or MS.. also you have several Fuse on MB which are with F marked.. need to check them all with yours DMM, also remove the WIFI usb from MB and do hard reset again..
                        • Spc.
                          • May 2022
                          • 16
                          • Slovenia
                          #32
                          Motherboard works 100%.
                          I can hear all the sounds and even picture is decoding.
                          I am pretty sure it's T-Con.
                          • MoreMagnets
                            • Oct 2022
                            • 16
                            I'm having almost the exact same issue with a Sony Android TV. Have replaced power board and mainboard so I think they can be ruled out. Left right panel ribbon behavior the exact same as you when they are removed.
                            I'm thinking it could be a dead TCON as well as a dead panel. Did you ever fix this?
                              • 12085
                              • U.S.
                              #34
                              Probably eemc chip is dead on both mainboards.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4275
                                • Italy - Milan
                                #35
                                Disconnect lvds cable and make a jumper from mainboard 12v out and tcon 12v in, or mask every pin ov lvds cable except 12v, then turn on, screen should perform a self visual test..
                                  • 12085
                                  • U.S.
                                  #36
                                  Nick's tv fixing dead eemc: https://www.youtube.com/watch?v=YL123l67h6w
                                  • MoreMagnets
                                    • Oct 2022
                                    • 16
                                    Update. Just did the tape trick, got video for about 10 minutes while I went through the android TV setup. Then all of a sudden green horizontal bands and the display goes black. Can still hear the android menu music but no picture again. So panel issue confirmed? Hopefully that wasn't the panel nuking my TCON board cause I tried to make it work...
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4275
                                      • Italy - Milan
                                      #38
                                      i can suspect your tape trick was not done well and/or you can have a partial shorted cap/diode on panel's distribution boards..
                                      • MoreMagnets
                                        • Oct 2022
                                        • 16
                                        Great guess. Just had a very small bit of tape on pin 1 and it must have moved. Used a bigger bit of tape over pins 1-4 and we have picture back again. What's the downside to covering up more than a single pin? Worse image quality?
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4275
                                          • Italy - Milan
                                          #40
                                          Worse image quality
                                          sometimes yes
                                          • CyberPhoenix
                                            Issue with picture quality of Sony bravia TV
                                            by CyberPhoenix
                                            Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                            01-22-2024, 02:08 AM
                                          • KYBOSH
                                            Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                                            by KYBOSH
                                            Previous owner said TV just went blank one day.
                                            They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                                            Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                                            The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                                            There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                                            I just downloaded the Sony KD-75X7800F Service Manual and...
                                            11-19-2024, 10:12 AM
                                          • lmcancu
                                            Sony Bravia 65x900F BL On but not picture
                                            by lmcancu
                                            I was watching youtube yesterday, when I paused it to go to the washroom. When I came back, the right side of the screen was showing half of the youtube channel and the left was black. I powered off/on the unit with the remote and now I have no picture whatsoever except for the bluish backlight. I did the factory reset (power + vol down), and now I when I power on I get the startup music, backlight but no picture.
                                            I took the back cover off, and reseated all cables but unfortunately same issue. I took some voltage measurements on the main 2 headers from the power supply board and...
                                            10-30-2023, 07:01 PM
                                          • jason123
                                            Sony Bravia KD-65X85J No Sign Of life (No BL, Picture, Front LED,..)
                                            by jason123
                                            Hi Folks,
                                            I have a 65" newer (2021 model) that has no sign of life. No backlight, no front LED (assuming it has one) and no audio or turn on chime.
                                            Photos below of the system
                                            The CN6401 Connector has the following vitals:
                                            STBY_3.3V is 3.432 V
                                            BL_ON low (0.153 V)
                                            BL_ERR low (0.051V)
                                            POWER_ON 3.42 V (as soon as I plug it into the wall this comes on)
                                            REG12V pins 12.7 V
                                            TCON_VCC12V pins low (0.11V)
                                            TCON_ON low (0.155)
                                            Large caps are at 392V as soon as I plug into power
                                            Seems like a Mainboard...
                                            09-08-2024, 07:05 PM
                                          • ryandesign
                                            Sony Bravia KDL-40v4100 has no picture but has power, backlight, and sound
                                            by ryandesign
                                            Hello! I would like to repair my father's Sony Bravia KDL-40v4100 LCD TV. It was in perfect working order the last time I used it before the pandemic. Then it sat plugged in but unused for a year or more. And now everything still works except that there is no picture on the screen. A relay can be heard to click when the power cable is connected. When the power button is pressed there is a green power LED and then the backlight turns on. If I connect an HDMI cable and play something with audio I can hear it through the speakers. The remote control buttons are recognized. There is just never anything...
                                            05-30-2021, 01:07 PM
