Hisense 58R6E - Changed all LEDs but...
    • 12276
    • U.S.
    Re: Hisense 58R6E - Changed all LEDs but...
    I would've just said, NO extra charge for the smudges, it's just the autograph of the artiste.
    • Fishhawk
      • Feb 2022
      I've got a hisense 58G2A300 with a shorted surface mount zener diode ZD5 on the bottom of the power supply 5835-L6R023 I don't know the voltage of the zener can someone please help me out. I'm just started using this site not too familiar with how it works. Thank you in advance for help with this matter.
      • Fishhawk
        • Feb 2022
        Re: Hisense 58G2A300
        I've got this Hisense 58G2A300 with a shorted surface mount zener diode ZD5 on the bottom of the power supply 5835-L6R023 I don't know the voltage of this diode can someone please help me out. Thank you in advance for any help I'm new to the site just learning & this is my first post.
        • dskall
          • Oct 2016
          • 2905
          • usa
          What are markings of diode?
            • 12276
            • U.S.
            Look closely, you might have component/s across it making it read shorted, carefully take it out of circuit and remeasure.
              • 12276
              • U.S.
              #26
              If you don't solder much, definitely practice on a scrap circuit board before hand.
              • nwcs
                • Dec 2015
                • 311
                • usa
                #27
                I have one of these with bad led's determined using the flashlight test and was wondering how the bezel comes off. I see screws on the bottom but none anywhere else. Do you have to pry the bezel or pop it off?
                • tech9pc
                  • Sep 2021
                  • 49
                  Yes I recently changed leds in 2 of these. Just take your time, be gentle and use an old credit card, gift voucher to gently pry the bezel clips till they snap out. Don't get rammy or pry to hard or will bust clips off. Youtube shopjimmy has good videos on that model so you can see how it's done.
                  • alfatv
                    • Sep 2020
                    • 353
                    For sure remove those screws at the bottom first, then start prying one of the sides at the bottom.
                    • EazyBone
                      Hisense 58R6E 2 blink now power
                      by EazyBone
                      So I've searched the threads and found this which is similar but not exactly the same.
                      https://www.badcaps.net/forum/showthread.php?p=1120104
                      Stby light is solid red, I hit power, flashes 2 times slowly and remains red. Doesn't flash anymore.
                      Getting voltages from 12v as 12v the 20v pins (or whatever) are constant 20 v the standby volt is 2.9v and they stay steady the whole time even when power button is pressed. The filters are about 390V and look fine.
                      I've disconnected every cable and tested and same result.
                      When I test...
                      08-02-2023, 08:21 AM
                    • DoorOfTime
                      Hisense 58r6e power board troubleshooting
                      by DoorOfTime
                      Hi all, I browsed previous threads on Hisense TV's but had some questions I haven't been able to sort out myself. This TV has a red standby light that when powered on, flashes twice, returns to steady, and cycles a few times before returning to a steady solid red.
                      Poking around the power board (P/N rsag7.820.8349) I have the following voltages with everything disconnected:
                      Main board connector:
                      12V ~9.3, STB ~0, VAMP is transient; first measured ~18 and gradually dropping to sub-16V.
                      Bridge Rectifier: (+) to (-): 167VDC
                      Filter caps: 368VDC
                      03-23-2022, 06:33 PM
                    • tomketcz
                      schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ
                      by tomketcz
                      Does anybody have schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ ??
                      10-01-2025, 03:13 AM
                    • Coolgoodman
                      Faulty Hisense 85Q6NAU TV
                      by Coolgoodman
                      85” Hisense TV
                      Greetings,
                      Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
                      Dear TV technicians of forum, I hope this message finds you well.
                      I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
                      I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
                      07-24-2025, 03:02 AM
                    • ShahZaib Ghumman
                      Can I Swap Screens Between Two Hisense 75” QLED TVs?
                      by ShahZaib Ghumman
                      Hey folks,
                      I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
                      A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
                      So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
                      03-25-2025, 10:59 PM
