Hisense 58R6E - Changed all LEDs but...
  • FeerBaron
    • Sep 2018
    • 39
    I have a single glowing spot on the bottom of the screen. I know the lenses are on as they are new.
    What else can it be? I did notice one of the little plastic triangles had a bent tip. Could that be it? I'm having trouble taking a pic of the light bleed but when you scroll it's visible and its starting to take away from my enjoyment of the display.
    It's primarily used as a desktop with a low backlight so it only consumes 40W. Suggestions?
    Some video: https://imgur.com/a/fiJWcJd
  • Diah
    • Feb 2013
    • 6584
    Re: Hisense 58R6E - Changed all LEDs but...
    sure this bent tip will cause differences to the distances between LED and first hard plate so the focused of the light will be changed... nothings you can do unless take screen apart again.
    • FeerBaron
      • Sep 2018
      • 39
      Can I buy another triangle somewhere? Not sure if I could even uncurl the tip. I could 3d print something but it won't be as clear and perfect.
      • Diah
        • Feb 2013
        • 6584
        you can repair them.. use boiled water to uncurl, you can use weight on the tip or whole the parts, after it come straight just use cool water to let it hold the new shape. just be sure don't use Clothing iron or any direct heat as it will lost the transparency
        3D printer can do the job but you need to have transparent plastic feeding line. and it could at end leave shadow effect not enjoyable at all to see it on the screen.
        • dskall
          • Oct 2016
          • 2905
          • usa
          I have one of these apart for backlights under the Sharp brand with same problem. Original strips, one in middle bottom has a bright spot. Lens looks like it's melted at corner. I think it was like that from beginning.
          • FeerBaron
            • Sep 2018
            • 39
            Mine had a single strip that turned on then off. The one at the very top. I replaced all of them in the hopes I wouldn't have to open the TV again.
            Not much luck with hisense. The one this is replacing worked for a year after LED swap and it's already starting to have one strip occasionally flicker. The 58R6E was only made in 2019.
            I'm not a fan of the "smart" features. This TV supposedly has a microphone? I didn't see one inside.
            The power light blinks due to the roku being offline despite being on another input. But hey, free is free.
            • Diah
              • Feb 2013
              • 6584
              microphone build in RC to use Alexa or google voice command
              • FeerBaron
                • Sep 2018
                • 39
                Wow, I did one better.
                Pulled the TV apart again to straighten the bent pieces. I used warm water and actually had some decent success.
                Unfortunately when removing the bezel I cracked the corner of the screen and the crack propagated all along the bottom. So now I have no 4k TV.
                • nomoresonys
                  • 12330
                  • U.S.
                  that is disappointing for sure, but at least it was only a hisense.
                  • Diah
                    • Feb 2013
                    • 6584
                    i will never write over here again "" take the screen apart "" LOL
                    • nomoresonys
                      • 12330
                      • U.S.
                      • FeerBaron
                        • Sep 2018
                        • 39
                        I will be way more careful taking bezels off that's for sure.
                        Now I figured I have enough money why don't I buy a used one... all the cheap ones have cross-hatching when used as a 4k monitor
                        This is the 3rd display I broke in my life.
                        1. Plasma against the couch fell over.
                        2. Cart fell over on a commercial replacement. And took a repaired LCD with it.
                        3. Now this hisense from my rushed, overconfident bezel removal.
                        • nomoresonys
                          • 12330
                          • U.S.
                          setting to natural rather than PC display may help with the crosshatching.
                          • Diah
                            • Feb 2013
                            • 6584
                            Taking screen apart job need Piano Players finger.. not Boxer or car mechanic hands ...
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              I'm a mechanic and never broken a screen yet.
                              • nomoresonys
                                • 12330
                                • U.S.
                                • Diah
                                  • Feb 2013
                                  • 6584
                                  but you washing yours hands before attempt to screen or wearing glove LOL
                                  • nomoresonys
                                    • 12330
                                    • U.S.
                                    I know that old oil and grease can kill you, but I can't wear gloves when I fix my truck. The only thing I can do wearing gloves is shovel snow, oh and brain surgery need really thick gloves for that.
                                    • dskall
                                      • Oct 2016
                                      • 2905
                                      • usa
                                      I can barely see oil smudges after I put them back together. If they complain, I give them a discount.
                                      • Diah
                                        • Feb 2013
                                        • 6584
                                        so it sound you did realy gave discount .. LOL
                                        • EazyBone
                                          Hisense 58R6E 2 blink now power
                                          by EazyBone
                                          So I've searched the threads and found this which is similar but not exactly the same.
                                          https://www.badcaps.net/forum/showthread.php?p=1120104
                                          Stby light is solid red, I hit power, flashes 2 times slowly and remains red. Doesn't flash anymore.
                                          Getting voltages from 12v as 12v the 20v pins (or whatever) are constant 20 v the standby volt is 2.9v and they stay steady the whole time even when power button is pressed. The filters are about 390V and look fine.
                                          I've disconnected every cable and tested and same result.
                                          When I test...
                                          08-02-2023, 08:21 AM
                                        • DoorOfTime
                                          Hisense 58r6e power board troubleshooting
                                          by DoorOfTime
                                          Hi all, I browsed previous threads on Hisense TV's but had some questions I haven't been able to sort out myself. This TV has a red standby light that when powered on, flashes twice, returns to steady, and cycles a few times before returning to a steady solid red.
                                          Poking around the power board (P/N rsag7.820.8349) I have the following voltages with everything disconnected:
                                          Main board connector:
                                          12V ~9.3, STB ~0, VAMP is transient; first measured ~18 and gradually dropping to sub-16V.
                                          Bridge Rectifier: (+) to (-): 167VDC
                                          Filter caps: 368VDC
                                          03-23-2022, 06:33 PM
                                        • tomketcz
                                          schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ
                                          by tomketcz
                                          Does anybody have schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ ??
                                          10-01-2025, 03:13 AM
                                        • Coolgoodman
                                          Faulty Hisense 85Q6NAU TV
                                          by Coolgoodman
                                          85” Hisense TV
                                          Greetings,
                                          Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
                                          Dear TV technicians of forum, I hope this message finds you well.
                                          I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
                                          I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
                                          07-24-2025, 03:02 AM
                                        • ShahZaib Ghumman
                                          Can I Swap Screens Between Two Hisense 75” QLED TVs?
                                          by ShahZaib Ghumman
                                          Hey folks,
                                          I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
                                          A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
                                          So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
                                          03-25-2025, 10:59 PM
