Hitachi 58HK6100U black (blue tinge) screen
  • mace
    • Aug 2015
    • 10
    • Scotland
    I have picked up a Hitachi 58HK6100U smart TV with a black/blue screen issue.
    It's a vestel unit, using the MB230.
    Visual inspection shows no obvious issues with caps, and diodes on PSU all look reasonable. I've not been able to check voltages, as I haven't spotted a schematic that matches the power supply, a 17ips72.
    I've confirmed that the set boots successfully, albeit without picture. If I disconnect either the left or right ribbon cables, I get picture on the other side.
    I noted a few bad lines at the bottom on the right hand side of the screen, picture attached. This may have occurred during collection, so might not be related to the original fault.
    Can anyone point me in the right direction as to where to look next?
    Thanks.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Hitachi 58HK6100U black (blue tinge) screen
    I would check t-con voltages.
    And a video with a similar problem. Tv works with either side unplugged but doesn't work with both plugged in.
    https://www.youtube.com/watch?v=77ty...chaelDranfield
    • mace
      • Aug 2015
      • 10
      • Scotland
      Thanks dskall, I'll rewatch that video. Do you know of any schematics for these boards/test points I can check the voltages?
      • cheeky2
        • Dec 2012
        • 337
        Your issue with your TV will be one of three things in order I suspect the issue is with your TV. The screen, the main board or the tcon.
        • mace
          • Aug 2015
          • 10
          • Scotland
          Very good 🙂
          • dskall
            • Oct 2016
            • 2905
            • usa
            Need good pictures of t-con.
            • mace
              • Aug 2015
              • 10
              • Scotland
              Photo of tcon as requested. Let me know if you need any close ups?
              • dskall
                • Oct 2016
                • 2905
                • usa
                You have vgh, vgl, vcom, vcc test points
                • mace
                  • Aug 2015
                  • 10
                  • Scotland
                  Thanks dskall,
                  Following measurements are with both halves of the screen connected to the t-con:
                  vin1: 12.1v
                  vin_12v1: 12.1v
                  vcc3v3: 3.28v
                  vcc1v8: 1.7v
                  vcc1.2v: 1.18v
                  vcom_l/r: started higher, slowly dropping, measured at 380mV after about 5 seconds.
                  vgl: 157mV
                  vgr: 18mV
                  Repeated measurements with either left or right hand ribbons disconnected:
                  vcom_l/r: 7.14v
                  vgl: -6.08v
                  vgr: 24.7v
                    • 12129
                    • U.S.
                    this does look like similar issue as in the video, test all the caps on the panel driver board, one probe on ground other on each side of cap, one side should continuously beep, other side should not have steady beep.
                      • 12129
                      • U.S.
                      you might get lucky and find one that is hotter than the rest, which would probably be the culprit.
                      • mace
                        • Aug 2015
                        • 10
                        • Scotland
                        The only short to ground I've spotted so far was across B402, is that a bridging link?
                          • 12129
                          • U.S.
                          probably is, it's not a cap.
                          • mace
                            • Aug 2015
                            • 10
                            • Scotland
                            Yeah, wish I had an IR camera, that would be a good check, assuming that it's shorted enough to heat up visibly.
                            • mace
                              • Aug 2015
                              • 10
                              • Scotland
                              Took it off, and lost ground to quite a lot of the bypass caps, so looks like B is bridging link on these boards (for anyone that comes across this thread in the future).
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                Try checking those test points to ground, with and without ribbons connected and see if you can find a short. I don't think you have a bad dc to dc converter if you are getting voltage when first turned on.
                                • TonyDoo
                                  • Feb 2021
                                  • United Kingdom
                                  Hitachi 58K6100U. I have had 3 of these in for repair recently with this fault. On all 3 if I unhook the right-hand side (from back view) screen driver board the TV shown a pick on the other side of the screen. When I had an hour or so to spare I checked all the caps and anything else easily checkable on that board. Everything checked OK. There is an eight-pin IC on the board marked
                                  BL25080A which looks easy enough to replace, so thought worth a go to see what happens, but I cannot find one anywhere.
                                  • TonyDoo
                                    • Feb 2021
                                    • United Kingdom
                                    Before anyone pipes up, I did try the T-Con board first
                                      • 12129
                                      • U.S.
                                      well not much is coming back on those numbers, its saying its an eeprom, maybe heat it up with a hairdryer for a couple minutes then try the tv, try it right away, don't wait til it cools back down.
                                      • Tushea2023
                                        • Oct 2023
                                        • United Kingdom
                                        Sorry to hijack an old thread but can't find anything else on the net and have the exact same issue as above. Can I ask what was the issue in the end? TIA
                                        • kdaniel
                                          Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
                                          by kdaniel
                                          As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
                                          There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
                                          After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
                                          Left...
                                          11-16-2022, 09:23 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • tehmatix
                                          Led TV Hitachi 58HK6100U half screen flickering
                                          by tehmatix
                                          Hi guys,
                                          I got this tv with half bottom of the screen flickering, horizontal stripe lines.
                                          I found when disconnected right side of the screen, the problem is gone.
                                          I isolated the CK signals (by guessing ) and loose the color.
                                          Pictures 4,5,6 defect
                                          Pictures 1,2,3 with piece of tape...
                                          09-01-2022, 08:39 AM
                                        • gbbradshaw
                                          Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
                                          by gbbradshaw
                                          Hi.
                                          I have the Samsung TV Model: UE65TU7000KXXU VER:02/UTU7000 which has developed the following issue: blue screen while the sound it's still working. This happened after the screen developed some horizontal lines at first and then the next day suddenly turned into blue background. the screen was not damaged or anything. I can't access the menu. I have taken the tv to a local tech to have a look and he said that he thinks that it might be the pcb board as the back-lights are working and the sound aswell . I was hoping maybe you can guide me if I should buy the pcb board or not? Thanks
                                          02-22-2023, 01:31 AM
                                        • siuras676
                                          Dell XPS Plus 9320 blue screen and rebooting
                                          by siuras676
                                          I have a Dell XPS 9320 in for repair, and the machine has a strange issue.
                                          First, a bit of history: the laptop came in after liquid damage and was completely dead. I've repaired all the broken traces, replaced the damaged components, and it now powers on.
                                          However, it's now showing a Windows blue screen related to hardware (as seen in the picture), along with another Dell error I've never seen before.
                                          Has anyone encountered this issue on a Dell machine before and could point me in the right direction? I've checked the power rails around...
                                          04-07-2025, 12:10 PM
