This tv was a $30 Craigslist deal. The problem was a shorted diode on the power supply board. It works great on the following input sources.
HDMI
Antenna input - local DTV broadcasts
Antenna input - Channel 3 output from Dish Network receiver
I have not checked the composite inputs.
The problem is that when connected to a Comcast cable box (I've tried several different boxes), initially it works fine. If you change the channel on the cable box, the first time you change it the picture is ok. Next time you change the channel there is a horizontal black bar that takes up about 1/3 of the screen. The bar starts about 12" down from the top. There is video above and below the bar. This is not an HD cable box.
Turning the set off and on makes the picture ok. Unscrewing the cable connection and reconnecting also makes the picture ok. Could it be bad surface mount caps on the video / processor board?
There are no menu settings that are related to this problem that I could find.
Anyone seen this before? Any ideas?
Thanks,
Mike
HDMI
Thanks,
Mike
