Sanyo TV FW55C46F with white vetical lines same place and image exists
  • pharmadrahmed
    • Nov 2021
    • 5
    I've those vertical lines in fixed spots ( don't move or flicker or change)
    tcon board by Lg looks working, voltages are normal. cleaned all flat cables and sockets.
    even withe t con board disconnected I still get those lines on the white backlight background. is it a defect of the panel itself? can it be fixed?
    • 12331
    • U.S.
    Re: Sanyo TV FW55C46F with white vetical lines same place and image exists
    try squeezing the bezel, NOT the screen, where the lines are, see if they change any, seems like a bad panel.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Find the bad spots on cof and get something like surgical tubing to apply pressure to the bad areas.
      • pharmadrahmed
        • Nov 2021
        • 5
        I tried squeezed the cable at the connection with the board, No change at all in the picture also tried all the 4 connections on the 2 boards. all connections look good. It's not a connection problem between the panel and the board. it looks like the panel had liquid pour because I found few residues inside at the back of the cof. Is there any hint?
          • 12331
          • U.S.
          ah, ok, another case of people putting liquids on the screen in excess, you really should never need to do more than dust the screen with a feather duster twice a week or so.
          • dskall
            • Oct 2016
            • 2905
            • usa
            If you can't make it work by applying pressure, your screwed.
            • pharmadrahmed
              • Nov 2021
              • 5
              I'm trying heating the spots with hair dryer, hope it may get better. anybody had any luck with a case like that?
              • pharmadrahmed
                • Nov 2021
                • 5
                heating didn't work at all. somebody has any idea or any hint I xan try?
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Try reading post 3.
                  • thstuff
                    SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
                    by thstuff
                    This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
                    Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
                    1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
                    2) Waited 30 seconds, then pressed remote Power button and "Select language"...
                    01-30-2023, 05:01 PM
                  • EazyBone
                    75r648 TCL 8K Mini LED White Horizontal Lines
                    by EazyBone
                    TV turns on, lights work sound works.
                    TV shows white/gray horizontal lines across the whole screen as shown in picture. TCON is getting 12v at fuses, VCC 12v.
                    First experience with 8k and mini LED. Does this picture tell you anything?
                    Apparently a "certified TCL tech" looked at this TV before I got it free and said it's a Tcon issue but said he couldn't be sure and wrote it off as a loss and they replaced for him.
                    Any tip or trick on where to start would be appreciated.
                    Going to research the lines. Also going to disconnect...
                    11-14-2023, 06:42 PM
                  • zoontz
                    SHARP LC-70UD27U black and white lines
                    by zoontz
                    Wondering if anyone has addressed an issue with the SHARP 70” LC-70UD27U having thin black and white lines running from left to right horizontally on the screen. I snagged this TV set from a neighbor since I have been successful in repairing numerous other TVs. I assume this probably happens to other TV sets and may have been addressed in another thread. If so please point me in the right direction.
                    What I have tried so far.
                    I have tested all HDMI inputs with the same results.
                    I have checked for firmware updates.
                    I have reset to factory settings.
                    I have removed...
                    07-09-2024, 05:50 PM
                  • brad2157
                    Vizio E70-E3 Two white vertical lines
                    by brad2157
                    I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                    Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                    Replacement main board - Boots up fine, but starting...
                    12-13-2021, 05:11 PM
                    MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                    This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                    09-06-2024, 07:46 AM
