TV Plasma LG 60PN5000 ZSUS 15v missing
All Voltages are OK except ZSUS 15v.
YSUS board disconnected still 15v missing.
ZSUS was replaced: 15v missing.
Any help will be appreciatedTags: None -
Re: TV Plasma LG 60PN5000 ZSUS 15v missing
15V is produced by Y-SUS, so follow the traces on that 15V pin and see where it leads.
Never power up a plasma with loosened or missing screws on any sustain boards. -
3ohm R251 Open, Replaced.
Now I have 15v but fluctuating to 16v and 15v and a metallic sound like tin, tin tin. All other voltages fluctuating a little bit but in range.Comment
There is not green light on the control board and the TV red light is blinkingComment
Further inspection on y-sus is required, test every IGBT and gate drivers for shorts, big resistors (those green ones) cannot be open.
The inductors on Z and Y buzz when working, but it's at a low frequency.Comment
D603 shorted
After replace D603 TV works well but instead of measuring 15v it measures 17.8vComment
If memory serves correct the 15V on LG plasmas is almost always close to 17V, so 17.8 is a small offset from the norm, no need to worry if nothing is overheating and the picture is fine. Is D603 at Y-SUS?Comment
by Salvatore057Hi all,
I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
I am lost, should I change the YSUS board? Is the YSUS board damaging... -
by ugamazingBoard had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),... -
by JDCMake and Model: LG 60PB6650-UA
Issue: Turns on, no backlight, can hear static (no channel)
I've been repairing TVs for a couple years now. I know how to use a multimeter for the most part and know how to test most components for shorts.
The power board connects to the ZSUS and then connects to the YSUS. The ZSUS is where I believe the failure is because the 16v line is only 3.8V, even when I disconnect the ZSUS from the YSUS.
This particular model seems to have a common failure with its YSUS. My goal earlier was to prove the YSUS was bad so I could... -
by jprezaHi everyone,
I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
Looking at the card, it appears to be missing the following:
1x 1.0uH inductor - orange square
2x...1 Photo -
by gurj1979Hey guys.
Need help with this one.
Fan not spinning due to missing PWN Fan signal.
Also 5 seconds from powering up it freezes, unless in BIOS.
But as soon as Windows starts to load, it will freeze.
CPU is COLD / Room temp when it freezes.
I've replaced the CPU, same problem.
Replaced SIO/KBC IT8987e and reprogrammed - same problem.
Replaced fan - same problem.
Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
Checked the Thermal sensors around CPU and Board to the SIO/KBC and...08-19-2024, 05:22 PM - Loading...
