Baird TI5510DLEDDS Android ver. 6.0
  • notallbad
    • Oct 2012
    • 1190
    Hoping someone can help out with a couple of issues, possibly related.
    TV initially had a backlight fault (10 strips, 5 lamps per strip), only one bad led. Replaced with a brand new complete set, so now working!
    No remote but found a Toshiba remote that at least does basic volume +/-, channel +/-, mute. Powers tv off but will not turn it on from standby?
    I have a cheap usb wifi dongle remote that functions as an air mouse to operate through the menus etc...
    I can install apps like youtube but will either lock up (power off tv to exit) or playback really laggy, buffers for ages just for 2 secs of sound.
    Makes no difference whether connected wirelessly or via LAN cable.
    Firmware is latest according to Network upgrade.
    Its currently on FW: VOS-04.14.030.02.05
    Needs directory to be named 'TV OS', and file name 'update_signed.zip'.
    Unable to access service menu to do a reset or view available settings but does have an option to reset to factory in the user menu but has no effect correcting the above.
    Youtube via browser works ok but not via the app.
    It pops up 'Update Google play services' but update does not appear to be available.
    Any ideas other than just replace the main board. Or could it be android ver.6 is just so outdated it can't handle
    it anymore?
  • lotas
    • Jan 2016
    • 4879
    • Russia
    Re: Baird TI5510DLEDDS Android ver. 6.0
    MAIN BOARD CV538H-A Enter the service menu try: Source 2580 (Input 2580)
    • notallbad
      • Oct 2012
      • 1190
      Shall try it and let you know, that is the main, did intend on mentioning it but forgot!
      • Diah
        • Feb 2013
        • 6593
        youtube lack and cant update him self to new too because of old version of Google play services. you have 2 choices. update the Google play services manualy. or disable and uninstall youtube apk and install smart youtube or youtube next. both work fine and with out adds.
        • lotas
          • Jan 2016
          • 4879
          • Russia
          The problem with YouTube (the sound appears, the picture appears, and everything freezes) is connected with the words TP with the update of YouTube to version 2.03.XX. To solve the problem, you need to roll back the version of YouTube to 2.02.14 (go to the Play Market and remove updates from the YouTube application. And then disable auto-update applications in the Play Market settings).
          • notallbad
            • Oct 2012
            • 1190
            Yep, that worked, thanks.
            Doing 'Reset All' made no difference and wifi still connected so did the 'Shipping Mode' and that did a full reset.
            • notallbad
              • Oct 2012
              • 1190
              Thanks Diah & Lotas, shall see what I can/can't do and update here.
                LCD LED TV Service Menu Codes
                TCL LED TV Service Menu Code
                LG LED TV Service Menu Code
                10-31-2024, 03:58 AM
              • cstout
                DeLonghi AC Remote only accepts 3V
                by cstout
                Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                I can't find any schematics...
                06-03-2024, 03:53 PM
              • notallbad
                LG Service menu android app
                by notallbad
                I had been using wave audio files to play via the headphone jack to an ir led but had difficulty getting the InStop file to light the led, no sign of life when viewing the led through the camera app on my mobile phone.
                Anyway, came across this free android app called IR Wave Plus that can utilise a homemade audio jack to ir led lead.
                Not limited to just LG either!
                A few settings require adjustment but the app itself is rather straightforward.
                In settings ensure the slider bar is set to maximum and Force volume to 100% for audio ir blaster is ticked.
                10-23-2024, 04:54 PM
              • notallbad
                LG 55LM6200-TA country group/Area option
                by notallbad
                This is a 2012 LG TV so aware full functionality of the smart functions/apps will be limited however currently unable to get the LG Smart Store.
                Youtube, Netflix and LG Smart store icons briefly appear in the apps list but then automatically disappear after doing 'Initialisation of Premium' via the standard menu, I'm guessing this is due to the Country/Area group its set to is wrong for the UK.
                Unable to change the country group, Area option can be changed which alters the country group but none make any difference. So believe its the country group that needs changing....
                10-20-2024, 11:16 AM
              • janos6662000
                TCL U55C7006 TV does not start
                by janos6662000
                Hello
                I received from a friend from Norway a faulty TCL U55C7006 TV
                TV had a white power led on when powered on, later the LED went off, but no picture.
                Initially i thought that it has a bad backlight. I tested the led strips with a tester but they proved good. I also checked the screen with a powerful flashlight, but no sign of any signal on screen.
                I made some research and i discovered that the TV is an Android TV and the fault i have is often connected to a firmware problem.
                I downloaded some firmware images and made some trials.
                I tried with 3 different...
                07-08-2025, 11:42 AM
