NEC E464 no picture/backlight, standby light blinks on 10s interval
  • billg123
    • Apr 2022
    Hoping you might be able to help me with an odd issue. I have a bank of 4 NEC E464 commercial screens that have been running on an ~8hr cycle for maybe 5 years. I unplugged them during some electrical work, and when I plugged them back in, one refused to come back up. It doesn't respond to the hard buttons or the remote at all. The main "clue" I have to work with is that the standby light blinks twice on a 10-second interval. I can't find a technical manual for these screens to see what that indicates. I've already tried many of the easy internet suggestions (plug directly into the wall, hard power cycle while holding the power button, etc.). I would really love to revive this screen because it would really trigger my OCD to have 1 of the 4 screens be slightly different. I have never cracked open an LCD TV, but am certainly willing to get my hands dirty.
    To reiterate, the displays were not plugged in while the electrical work was being done, and there's no obvious reason why the thing just decided to stop working now.
    Can anyone suggest where I might start?
    Thanks!
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: NEC E464 no picture/backlight, standby light blinks on 10s interval
    I would say open it up and post pictures of boards. Sounds like maybe a bad capacitor.
      • 12206
      • U.S.
      might not work but you could try this: Turn the TV off.
      Then press the {MENU}, {MUTE}, {OK} & {POWER} buttons.
      The TV should turn on with the Service Menu displayed. might bring up the service menu, where you could do a factory reset, you MUST be very careful in the service menu or you could brick your whole unit.
      • kca
        Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
        by kca
        Hello all ~
        I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
        This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
        No picture. No sound.
        I tested all the voltages coming out of the power supply...
        10-12-2023, 05:23 PM
      • slimsoul
        Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
        by slimsoul
        Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
        I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
        I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
        The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power...
        03-12-2024, 03:55 AM
      • Elecfronicsssss
        DA0NJJMBAG0 charging light blinks
        by Elecfronicsssss
        Laptop motherboard DA0NJJMBAG0
        PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
        CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
        GUIDE ME WITH THE PROBLEM..
        SUMMARY-
        1.NO 1.8VOLTS ON BIOS PIN NO 8.
        2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
        05-12-2025, 02:32 AM
      • Jackching
        Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
        by Jackching
        I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
        04-15-2024, 05:14 PM
      • PNI E.
        tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
        by PNI E.
        hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
        02-20-2025, 08:36 AM
