55" Element tv turns on, no picture E4SJ5517BF
    • 12276
    • U.S.
    #61
    Re: 55" Element tv turns on, no picture E4SJ5517BF
    shit, the pictures stayed behind but it's post #16 with the pics.
    • Jerdejong
      • Apr 2022
      • 48
      Gotcha
      • Jerdejong
        • Apr 2022
        • 48
        Will check this afternoon after work
          • 12276
          • U.S.
          #64
          ok, also look at post #10, see all the little round copper looking spots by the connector where the ribbon cable plugs in, test those with tcon plugged in and hit power, see if you find any voltage on any of them.
          • Jerdejong
            • Apr 2022
            • 48
            If you look at post #7, 1st picture... there's a legend for those copper test points. I only see one of those points that should read 12v. Are there more points that should have 12v, even if they're not labeled 12v?
              • 12276
              • U.S.
              #66
              you do have 12 on the first one? if so follow out the trace to the next stop.
                • 12276
                • U.S.
                #67
                so if you have 12 there you should have 12 on the fuse that would be the next stop.
                • Jerdejong
                  • Apr 2022
                  • 48
                  I did have 12v at the fuse, when the tv would power on. Now that it won't power on, I can't test at the fuse. However, with that cable unplugged, I'm still able to test for 12v coming from the main board, which I do have. I just need to find that stinkin short
                    • 12276
                    • U.S.
                    #69
                    for sure, does anyone know why the fuse would be short to ground?
                    • Jerdejong
                      • Apr 2022
                      • 48
                      I'll post a pic of the back side of the board when I get home. I have a hunch of the general area that is causing the short
                        • 12276
                        • U.S.
                        #71
                        ok, did you recheck the pads where the caps came off that you removed to see if the short is still there on the pads?
                        • Jerdejong
                          • Apr 2022
                          • 48
                          Yes, the short is still there
                          • Jerdejong
                            • Apr 2022
                            • 48
                            Ok so I discovered vias which are small holes connecting the front and back of the circuit board. In the pic, the far right red circle is where the fuse leads to, in turn, feeding the blue circles on the left. I'll do a little more desoldering and see what I come up with.
                            • Jerdejong
                              • Apr 2022
                              • 48
                              I think I'm done unless someone wants to come tackle this. I removed the rest of the caps that looked like they were traced back to the fuse. Still getting a short to ground(now about 80ohms). The only traces that look like they're connected to fuse, lead to the 2 chips. I think this is out of my expertise to go any farther
                                • 12276
                                • U.S.
                                #75
                                I'm baffled too, seems like it would be fairly simple to find that short but it sure isn't.
                                • Jerdejong
                                  • Apr 2022
                                  • 48
                                  Probably one of the chips is shorted out. I might attempt to replace one at some point but I'm gonna hang it up for now. I do appreciate all the help though!!
                                  • ygorsan
                                    by ygorsan
                                    🧩 Problem Summary:
                                    • I
                                    07-28-2025, 08:34 AM
                                  • jb_Bak
                                    by jb_Bak
                                    CN6401
                                    Pin 01 NC
                                    Pin 02 NC
                                    Pin 03 "BL_ON": 0V
                                    Pin 04 "N/C"
                                    Pin 05 "STBY 3.3V": 3.5V
                                    Pin 06 "GND": N/C
                                    Pin 07 "AC_OFF"...
                                    09-27-2021, 04:52 PM
                                  • m1ch43lzm
                                    by m1ch43lzm
                                    05-12-2025, 08:37 PM
                                  • cheeky2
                                    by cheeky2
                                    05-25-2024, 03:27 AM
                                  • Asraf Atb
                                    by Asraf Atb
                                    01-27-2025, 05:02 PM
