Sony XBR-55A8G 4K OLED image ghosting/jumping around
  • Cheesesteak
    • Apr 2022
    • 11
    Hello All,
    Hoping one of you wizards might be able to help me, I'm new to TV repair, I'm trying to troubleshoot a ghosting/jumping image on a 4k 55in Sony XBR-55A8G OLED TV.
    I have tried re-seating all cables, and lightly manipulating the cables while the TV is on to see if the picture changes with pressure on any of the cables/connectors. I also replaced the TCON board and the ribbon cables connecting the TCON board to the panel, the issue has not changed with the replacements or with any cable manipulation / re-seating.
    I saw some people had success on LCD TVs with a similar issue by taping off portions of the ribbon cable pins responsible for the clock signal coming from the TCON board, but in those videos their boards only have two cable outputs, mine has four and I have been unable to identify which pins are for the clock signals. I am not sure if OLED is similar to that.
    I have tried searching everywhere I could for a service manual for this tv or a datasheet for the TCON board but cannot find anything. I also have not been able to find any related issues online for this model TV. I am new to this, does anyone have any suggestions on things to try? Or things I should read up on? Or maybe just some general suggestions would be great. Thank you all!
    Close up pictures of components and video showing the display issue I am experiencing here:
    https://drive.google.com/drive/folde...2d?usp=sharing
    TV Model Number: Sony XBR-55A8G
    TCON Board Model Number: LG LE650AQP-AMA2-Y31
    Mainboard Model Number: Sony A2229178A / 1-983-249-52
  • William1967
    • Nov 2017
    • 215
    • Netherlands
    Re: Sony XBR-55A8G 4K OLED image ghosting/jumping around
    Taping cables will result in a shut down / error. This t-con is not similar like the ones from lcd/led tv's.
    The problem looks like a gate error but i'm not 100% sure because i've never seen this failure in an oled tv.
    • Diah
      • Feb 2013
      • 6445
      it sound you have BGA issue at MB. FRC IC react of losing signal from main IC.
      FRC IC = the one close to LVDS.
      • Cheesesteak
        • Apr 2022
        • 11
        Do you think replacing the mainboard would fix this issue? Or mainboard and cables?
        • Diah
          • Feb 2013
          • 6445
          Repair the MB by reflew it by heating. show us the photo please over here use GO advanced and post the MB photos clear and focused from the TOP and down side.
          • Cheesesteak
            • Apr 2022
            • 11
            I uploaded pics of the front of the mainboard, any suggestions on getting these ribbon cables out? These are the only two I could not get, I don't want to break them.
            I will upload pics of the back once I get these out, thank you for the help so far.
            • Cheesesteak
              • Apr 2022
              • 11
              Thank you for the information William. That helps me from going on a wild goose chase.
              • Diah
                • Feb 2013
                • 6445
                1- Press
                2- Pull
                • Cheesesteak
                  • Apr 2022
                  • 11
                  1- Press
                  2- Pull
                  Hello, the side of these is hard molded plastic, there is nothing to press in.
                  • Diah
                    • Feb 2013
                    • 6445
                    this is yours problem... bad connection... i wrote at post #3
                    • Cheesesteak
                      • Apr 2022
                      • 11
                      Hello again, I have replaced the motherboard with a new motherboard and the issue still persists exactly the same, any other suggestions of things to try?
                      • nomoresonys
                        • 12284
                        • U.S.
                        might need to update/pair the firmware.
                        • Cheesesteak
                          • Apr 2022
                          • 11
                          Yes I upgraded firmware to latest from Sony website already as well.
                          • Nick's Tvs
                            • Jan 2014
                            • 621
                            You might have a faulty panel, but you might still be able to fix it by blocking the correct clock lines.
                            Check out this video from frugal TV repair on how to do this.
                            https://youtu.be/pfrRhw7-ZII
                            • Diah
                              • Feb 2013
                              • 6445
                              here OLED Panel not LCD.
                              as i thought in my post#3 as BGA and he did changed MB... so the issue remain BGA or bad connection at LVDS /T-CON / Ribbon / you need to put yours DMM and measure the 12V rail and 22V rail which coming from PCB to T-CON if they are stable or jumping as the picture change.
                              • Cheesesteak
                                • Apr 2022
                                • 11
                                Thank you Diah, I will check those with multimeter and respond to the thread with results.
                                I have also ordered replacement FLEXIBLE FLAT CABLES 41P/51P for connection from mainboard to TCON but they will not arrive for a couple weeks.
                                • lotas
                                  • Jan 2016
                                  • 4762
                                  • Russia
                                  You need to press on these latches, one of you is broken on one side.
                                  • Cheesesteak
                                    • Apr 2022
                                    • 11
                                    Thanks Lotas, I figured that out, the connectors are still secure and function, just the little tab thing broke at the top.
                                    • Cheesesteak
                                      • Apr 2022
                                      • 11
                                      Hi Diah,
                                      Are you referencing testing these input voltages from PSU rails to TCON? (See image)
                                      • Diah
                                        • Feb 2013
                                        • 6445
                                        Hi Diah,
                                        yes
                                          ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 04:30 AM
                                        • Glaval
                                          Sony OLED XBR-65A8G 4 flashes
                                          by Glaval
                                          Hello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...
                                          01-23-2025, 04:04 PM
                                          Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 07:12 AM
                                          Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:40 AM
