Lg55lv4400ua
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Lg55lv4400ua
    Picked up as a non-working set from a friend who could not remember symptoms of failure.
    Fired up this set and worked normally (low audio volume) for an hour. Turned off and let sit overnight plugged in. Next attempt not so successful. No reaction from push button or remote.
    I have 5.3 and 12.8 volts where labeled. Constant 3.14 volts on Remote_ON/OFF in standby and when on/off button is depressed on TV and remote.
    Does main board remove 3 volts to signal smps to fire up?
    Any assistance is greatly appreciated.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Lg55lv4400ua
    I would heat up main and power board and see if it then powers on.
    • neilc6
      • Nov 2015
      • 1550
      Re: Lg55lv4400ua
      LE LV LW LS series have main board bga failures. Search eBay for repair services.
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        Re: Lg55lv4400ua
        My initial thoughts were that the main board was at fault. BGA failure makes sense. Thanks for your support!!
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Re: Lg55lv4400ua
          BGA issue had it on these boards.
          • ljintexas
            LJinTexas
            • Jan 2015
            • 669
            Re: Lg55lv4400ua
            There is a known issue with eeprom U14 on this board that causes this very symptom. Ordered the chip with updated LG firmware.
            Thanks to all!
            LJ
            • dskall
              • Oct 2016
              • 2905
              • usa
              Re: Lg55lv4400ua
              Heating up processor is good way to confirm bad bga connections.
              • ljintexas
                LJinTexas
                • Jan 2015
                • 669
                Re: Lg55lv4400ua
                I have a Milwaukee heat gun...what temp do you recommend I heat it to?
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Re: Lg55lv4400ua
                  https://www.youtube.com/watch?v=6oYj...ck%27sTVRepair
                  • ljintexas
                    LJinTexas
                    • Jan 2015
                    • 669
                    Re: Lg55lv4400ua
                    Does not really tell me anything about temperature..since I don't have a rework station, I am still guessing..400F?
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      Re: Lg55lv4400ua
                      You are not trying to reflow it, just put some heat into it, then turn the TV on. You can do it with a hair dryer.
                      • ljintexas
                        LJinTexas
                        • Jan 2015
                        • 669
                        Re: Lg55lv4400ua
                        I did just that, with no success.
                        • neilc6
                          • Nov 2015
                          • 1550
                          Re: Lg55lv4400ua
                          You can try freezing the eeprom with an upside down can of duster before plugging in.
                          • cstout
                            DeLonghi AC Remote only accepts 3V
                            by cstout
                            Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                            The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                            I can't find any schematics...
                            06-03-2024, 03:53 PM
                          • Mc_Millian
                            Toshiba 50lf711u20 fire tv remote not pairing
                            by Mc_Millian
                            I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                            The Tv model number is: 50lf711u20 Rev B.
                            I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                            I've tried 3 different remotes which should be fully compatible with this TV.
                            Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                            The power button, along with the volume,back,select, and directional...
                            04-07-2022, 12:15 PM
                          • edugimeno
                            HiSense 55A7500F won't obbey to remote after power on
                            by edugimeno
                            Hi! I have this TV set that does the following:
                            1) I press the red power button on the remote
                            2) The TV turns on normally
                            3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
                            4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
                            Then after it's off, it would again accept the TURN ON from the remote and same again
                            BUT:
                            -The remote does show the correct IR beam while observed thru a phone camera
                            -The TV works fine while using the MiRemote...
                            03-14-2023, 11:22 AM
                          • tmhobadcap
                            Pioneer VSX-522-K remote control not working???
                            by tmhobadcap
                            I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                            At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                            12-24-2020, 01:44 AM
                          • rustinjust
                            Please help, where can I get a remote for my subwoofer?
                            by rustinjust
                            I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                            Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                            Is there...
                            10-28-2023, 03:43 AM
