Hey guys, been a while since I've been in here but had some spare time to troubleshoot a tv that has had an issue for a bit. I initially assumed I had bad LEDs and tore the set down to test. LEDs all lit up and seemed fine using my tester. Reassembled and went to troubleshooting boards. PS board has all correct voltages across the outputs. Not really sure what to test in the main board… I did check the fuse on the T-con and it has continuity but no voltage tested to chassis ground. Am I wrong in my assumption the main board has failed somewhere? Shouldn't the Tcon board have 12v dc?
LG 55LN5400 LED flash then dark troubleshooting
Re: LG 55LN5400 LED flash then dark troubleshooting
I forgot to mention. Power button changes nothing on my voltages. Tv is always in power on state when plugged in. This has mostly been main board in the past for me. I found one off eBay for $15 so I’m gonna go ahead and give it a shot. -
Flash of backlights is a symptom of bad backlights. They sometimes may test good with a LED tester. Just replace all the strips with new. I rarely test with LN, LB or LF series with symptoms of bad backlights. The 55 LN uses the thick lens style of LB series. You can remove the panel, record the flash and go frame by frame to see which LEDs aren't lighting up.Last edited by neilc6; 03-30-2022, 09:58 AM.Comment
I have a set coming in today or tomorrow….. I may wait til main board comes in anyways as one of the hdmi ports are jacked up. I think my output voltage was around 110v dc for the backlights when testing to chassis ground. Hoping I don't have to replace the LEDs but I'll have them if I need to. They all looked pretty darn good when testing though.Flash of backlights is a symptom of bad backlights. They sometimes may test good with a LED tester. Just replace all the strips with new. I rarely test with LN, LB or LF series with symptoms of bad backlights. The 55 LN uses the thick lens style of LB series. You can remove the panel, record the flash and go frame by frame to see which LEDs aren't lighting up.Comment
New LEDs still haven't arrived.... Stupid DHL! put the tv back together to get out of the way, plugged it in and it worked for a little bit but then went black again. Is it really possible to have faulty LED's even if they all light well? Maybe heat causes solder seperation. The set works fine and all are lit when testing.Comment
LGs have shutdown protection for the backlight circuit. Failing LEDs can have fluctuating voltages or go open circuit triggering the shutdown. https://techhometravel.com/lg-ln-ser...ed-backlights/Last edited by neilc6; 04-05-2022, 04:20 PM.Comment
Is there a point that i can check for fluctuation? I checked the PSU output and it was a steady 116vdc. Hopeful DHL can get off their rump and get me some LED's in the next day or two. I'm ready to be done with this set already.LGs have shutdown protection for the backlight circuit. Failing LEDs can have fluctuating voltages or go open circuit triggering the shutdown. https://techhometravel.com/lg-ln-ser...ed-backlights/Comment
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
Assuming...7 Photos -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... - Loading...
