Black screen after reattaching COF, purple bars without it.
  • unimatrix93
    • Oct 2021
    • 347
    • Magyarország
    Hello there.
    I have a Phillips with de attached COF cable (the glue let it go) that had lines on its display.
    After I found out that the COF cable is dangling from the LCD panel, I looked up online if I can fix it without a bonding machine.
    After tinning the COF cable and the PCB contacts I proceded to solder them together.
    It was very tedious but using my tweezers, my phone as microscope and a shitton of agility I managed to bond them with my soldering station.
    Now, with the COF cable reattached the lines are gone, but the screen is black, only the backlight is working and if I remove the COF cable with my hot air station the display shows purple and white, vertical bars with a black bar in the middle(where the COF is deattached).
    I can upload pictures and even videos of the tinning of the contacts and of the reattached COF too if you wish.
    What should I do now, guys?
    • 12269
    • U.S.
    Re: Black screen after reattaching COF, purple bars without it.
    sure upload the pics. and video, maybe someone can figure it out.
    • unimatrix93
      • Oct 2021
      • 347
      • Magyarország
      Here is two close up footage of the COF and the PCB after tinning.
      COF tinning
      PCB tinning
      Close up photos of the end result:
      • unimatrix93
        • Oct 2021
        • 347
        • Magyarország
        I measrued the TCON board voltages, here are the results. V18 has 0.5v which is suspicious.
        VGH_ODD: 28v between -7v
        VGH_EVEN: Same
        VST: - 7v
        VCOM: 5.7v
        VCOMRFB: 5.7v
        V1: 16v
        V9: 8.4v
        V14: 3.9v
        V5: 12.2v
        V10: 7.8v
        V18: 0.4v
        VCC: 3.3v
        HVDD: 8.1v
        VCORE: 1.2v
        VDD: 16.7v
        VCC18: 0.2v
        • Unspun01
          • Jun 2011
          • 349
          Hi unimatrix93:
          I have performed this exact repair as you when I had a COF ribbon cable become detached from buffer board (also on a philips LCD panel, but due to an accident by a slight tug on the board)
          You may have some pins making connection, and some pins not making connection, or accidental solder bridging between adjacent pins.
          My advice it to detach the flex cable, and try re-soldering.
          USE LOTS OF FLUX, FRESH SOLDER, and VERY FINE SOLDER TIP.
          Use scissors to trim the entire top edge of the flex cable (like 1mm or 1/16" or whatever is the least amount) to expose the very edges of the solderable pads on the flex cable.
          Don't use too much solder, but ensure each pad on the flex ribbon is tinned, and each pad on the buffer board is tinned. Then flux everything. Then using the fine point solder tip, align the left or right most pad to ensure correct alignment. Then use individual pin soldering in consistent left-to-right, or right-to-left order. Or use DRAG-SOLDERING. If you have lots of flux, and the appropriate amount of solder, these connections will each be re-made properly without solder bridges.
          You also need to ensure the ribbon cable and buffer board are perfectly 90degrees to each other. Even slight mis-alignment between such fine pitch pins can cause adjacent pins to become connected at the end of worst mis-alignment.
          EXAMINE your work with MAGNIFYING LENS. I cannot stress enough that you need to be sure extra solder is not shoring anything out.
          In my case I had 100% success, but not before identifying a couple of spots where I noticed excess solder trapped between the board and the flex ribbon that could have caused an issue. I tested and re-tested because I was working on a 75" TV, and absolutely needed to be sure my work was perfect and not going to short out the panel.
          Best of luck.
          • unimatrix93
            • Oct 2021
            • 347
            • Magyarország
            Originally posted by Unspun01
            Hi unimatrix93:
            Best of luck.
            Thank you so much for the detailed reply! I will try again next week and with my shiny new microscope, which will help me check on the soldering.
              Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook 3 Specification for Upgrade or Repair
              This specification for the Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) boardview and Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) schematic. Our users have donated over 1 million...
              09-07-2024, 12:40 AM
            • Akira81
              LG 55LF652V-ZA flashing led bars despite their replacement
              by Akira81
              I have this 55" LG 55LF652V-ZA smart TV which suddenly started flashing intermittently every 2 seconds with the backlight.
              If I aimed the light bulb of my cell phone I could see the underlying image even in those fractions of time when the LEDs were off and the audio instead came out continuously.
              Armed with a lot of space and patience, I decided to open the TV, immediately noticing that a LED had flamed out and also burned a portion of that reflective white panel behind the transparent LED diffusers.
              04-14-2023, 11:50 AM
            • x_orange90_x
              Samsung UN46C8000XFXZA vertical bars/horizontal lines
              by x_orange90_x
              I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
              The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
              09-04-2023, 12:09 PM
            • CapLeaker
              LG 65UQ70 horizontal bars jumping
              by CapLeaker
              So I bought this LG 65UQ70 today at Walliworld. Put the wall mount on, set it up, worked for 30 mins and then I get these jumping horizontal bars. Let the TV do updates and let it cool down for 5 mins. Worked perfect for 2 mins. As soon the TV is warm I get the jumping vertical bars again.
              Keep the other TCL thread in mind. Now I am questioning are all COVID 2022 / 23 TV’s bad or what? That’s two 65” TV’s one from Amazon and this one from Walmart. What are the chances on that?
              I guess this one goes back either later today or tomorrow morning, unless...
              08-13-2024, 09:41 AM
            • gamartinelli
              Asus VG248QE won't power on / purple light
              by gamartinelli
              I have an Asus VG248QE that all suddenly stopped working. Everything was fine, I had my PC connected to the HDMI port and never had any issues. Then I decided to plug a laptop in the DisplayPort (USB-C to DP cable). It worked fine for a few hours, I left, at some point the monitor went to sleep mode and when I came back and moved the mouse monitor didn't wake up. The power button lights up in blue when the signal is good and amber when in sleep mode / no signal turned purple (first time I saw that). Did some research but couldn't find a way to bring my monitor back to life....
              09-29-2022, 04:15 PM
