Vizio E550i-b2e no standby voltage
  • Mbd3
    • Feb 2022
    • 25
    Re: Vizio E550i-b2e no standby voltage
    Well I checked the solder joints. Everything looked good. However I noticed when I first plug tv in I will get the standby voltage for about 5 seconds then it drops to 0 bit it is a gradual drop.
      • 12276
      • U.S.
      ok, see if that same gradual drop happens, with everything unplugged from the powerboard except the power cord of course, so you just turn on the power strip while your meter probes are in place.
      • Mbd3
        • Feb 2022
        • 25
        It already is unplugged. I am just working on the smps.
        • Mbd3
          • Feb 2022
          • 25
          The vcc is stable for the first 5 seconds then goes crazy after that.
            • 12276
            • U.S.
            you checked ALL diodes in diode mode?
              • 12276
              • U.S.
              #26
              so what's going on with D901? looks very hot, I would just change it out to rule it out.
              • Mbd3
                • Feb 2022
                • 25
                Ya I checked all the diodes in diode mode and suspected ones I unhooked one end. All was good. Lol that is what I was trying to figure out. That is the only the only thing that lit up. I think I will just change it out and see what happens.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  #28
                  Have you checked the secondary side? If you have 5v you can put power to your 5v output with board not plugged in. Check for shorts and also check feedback circuit.
                  • Mbd3
                    • Feb 2022
                    • 25
                    Ya I am going to try that when I get home. I will let you know my findings.
                    • Mbd3
                      • Feb 2022
                      • 25
                      Well my Bench power supply didn't get delivered. However when I got home I was messing with it and my standby would stay on for a couple minutes. Then if I unplugged it and waited a few minutes and plugged back in it would come back.
                      • Mbd3
                        • Feb 2022
                        • 25
                        Well I finally got the standby back. It was cold solder joints on that diode. However I moved on to the pfc circuit. It's not working. I have my vcc voltage and 2.9v on drive pin of ic going to gate of mosfet but I lose my voltage at a resistor any ideas.
                        • Mbd3
                          • Feb 2022
                          • 25
                          Here is the datasheet.
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            #33
                            You seem to be giving us bits and pieces of information. So now you also have a pfc problem. What are your main cap. voltages in standby and powered on?
                            • Mbd3
                              • Feb 2022
                              • 25
                              In standby mode it's 167vdc. Powered on its 167vdc also. Originally I didn't have standby voltage, but now I have that so on to the next problem. Sorry for the confusion.
                              • R_J
                                • 9588
                                So your pin8 Vcc voltage is 12 volts?
                                • Mbd3
                                  • Feb 2022
                                  • 25
                                  I have 15.6v on vcc
                                  • R_J
                                    • 9588
                                    You said you replaced Q800 and R804a, was Q800 shorted and R804a open?
                                    • Mbd3
                                      • Feb 2022
                                      • 25
                                      Yes
                                      • Mbd3
                                        • Feb 2022
                                        • 25
                                        Here is what voltages I have on that ic
                                        Pin#
                                        1. 1.074v
                                        2. 5.837v
                                        3. 0.423v
                                        4. 0v
                                        5. 0v
                                        6. 0v
                                        7. 2.418v
                                        8. 15.3v
                                        • R_J
                                          • 9588
                                          Yes
                                          Then the ic is damaged. When the mosfet shorted and the source resistor opened, 165v was applied through R805 to the CS pin of the ic, damaging it.
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • x_orange90_x
                                            Samsung UN55KU6300F no standby voltage
                                            by x_orange90_x
                                            I have no standby indicator light and no light on the optical port. I checked the standby voltage on the two mosfets in the top left and they both read 30mV. I checked the fuse and it has continuity. I also checked the voltage on the two large 450v caps they both read 153v. All of these voltages are the same with and without the main board connected as well as with backlights connected/disconnected.
                                            Nothing looks obvious like a burned ceramic disc cap or bulged electrolytic. No burned resistors, diodes, or anything like that....
                                            05-21-2025, 09:59 PM
                                          • Bad_IC
                                            Philips TV 37pfl5604h/12 no standby voltage
                                            by Bad_IC
                                            I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
                                            These are the voltages in some pins of IC fsq510:
                                            Vcc=18v
                                            D=320v
                                            Vstr=154v
                                            Unfortunately, I couldn't find the schematic
                                            What else could I check?
                                            Is it possible to provide standby voltage from an external source to allow the TV to turn on?
                                            Thank you​...
                                            11-08-2024, 01:07 PM
                                          • brock-s
                                            Asus GL503GE 3.3 standby voltage low
                                            by brock-s
                                            An Asus GL503GE laptop arrived that had had a screw dropped on the motherboard while the battery was connected. This resulted in a physical damage to the 3.3v / 5v voltage controller RT6575DGQW (pu28 on schematic, page 40). Additionally, the trace to pin 12 (VIN 19v supply) was burnt.
                                            Replaced the RT6575DGQW with a new one, repaired the damaged trace. Only getting 0.7V instead of the expected 3.3v standby voltage (3V_S5 on schematic).
                                            Replaced the AON7408 PQ60 mosfet from a donor board as resistance was low on the gate (I did not write this value down, as I optimistically...
                                            07-13-2023, 03:43 PM
