Philips 60PFL8708S/12 On Infinite Boot Loop No Logo, Only Backlight
  • DutchDIY
    • Feb 2022
    • 51
    • Nederland
    Re: Philips 60PFL8708S/12 On Infinite Boot Loop No Logo, Only Backlight
    Originally posted by Diah
    the USB should be bootable MBR ..
    how to do USB stick MBR with windows DISKPART
    Code:
    Open command terminal and type DISKPART
    # Show all disks (aka drives, like hard drives or removable media).
    DISKPART> list disk
    # Select a disk to operate on.
    DISKPART> select disk [number identifying USB flash drive]
    # Delete all partitions, resulting in a blank disk.
    DISKPART> clean
    # If the USB drive is using the GPT layout, the "list disk" command output
    # above will show an asterisk in the last "Gpt" column. If this is the
    # case, issue this command to change it to the MBR layout.
    DISKPART> convert mbr
    # Create a primary partition (using MBR).
    DISKPART> create partition primary
    # Show all partitions (should just be the one newly-created partition).
    DISKPART> list partition
    # Select the primary partition to operate on (only 1 partition exists).
    DISKPART> select partition 1
    # Make the primary partition active (aka bootable).
    # This command will fail if the USB drive is using the GPT layout.
    DISKPART> active
    # Format the active primary partition using FAT32.
    # To do a full format, instead of a quick format, omit the "quick" flag.
    DISKPART> format fs=fat32 quick
    # Assign a drive letter to the primary partition
    # (just in case Windows didn't already do it).
    DISKPART> assign
    # Quit DiskPart.
    DISKPART> exit
    Cool, I am doing that right now, hope the tv can work with this stick.
    • DutchDIY
      • Feb 2022
      • 51
      • Nederland
      No luck, still the same boot loop..
      Btw, idk if it is helpful, the LED in front blinks twice, then there is a short pause and another two blinks, this happens during the display of backlight.
      • Diah
        • Feb 2013
        • 6438
        remove heatsink and apply BGA to the chip
        • DutchDIY
          • Feb 2022
          • 51
          • Nederland
          Will do, danke schön!
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4463
            • Italy - Milan
            So now a Tv equipped with Arm Cpu/proprietary bootloader is able to run pc based booting mbr.. how much fantasy..
            the correct way to examine this set is to access Level 2 diagnostic with SDM, if confirmed error 53 then CPU soldering problem..
            • Diah
              • Feb 2013
              • 6438
              if you nothings have to do... don't hijack threat yours master involved with..
              and incase you cant read i can send you new 4° glass to read clearly POST #4
              so this forum become really upsetting.. time to leave it.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4463
                • Italy - Milan
                #27
                why i can't repeat it? i have read all things
                  • 12276
                  • U.S.
                  #28
                  Sure wouldn't be missing MUCH, this forum is deader than my grandmaw.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4463
                    • Italy - Milan
                    #29
                    ... and surely you are not my master..
                    • DutchDIY
                      • Feb 2022
                      • 51
                      • Nederland
                      #30
                      Originally posted by lotas
                      Mainboard 3104 303 54946 B
                      3104 313 66186 B
                      Would 3104 303 54945 also work?
                      • DutchDIY
                        • Feb 2022
                        • 51
                        • Nederland
                        #31
                        Does anyone know?
                        • DutchDIY
                          • Feb 2022
                          • 51
                          • Nederland
                          #32
                          I went and bought a main board (same part number Mainboard 3104 303 54946 B), but coming from a working 47PFL6678K/12 with a cracked screen.
                          So after installing the tv responds to every remote control input but the screen stays black throughout, although there is an increase in brightness coming from the backlighting after pressing the smart button.
                          I am also able to power the tv off with the remote, and am getting no LED blinking after powering on.
                          Is this main board not plug and play interchangeable between these models? Am I supposed to load model specific software or smth?
                          • lotas
                            • Jan 2016
                            • 4753
                            • Russia
                            #33
                            Name your panel code using the remote.
                            • DutchDIY
                              • Feb 2022
                              • 51
                              • Nederland
                              #34
                              I did it and it went to standbymode right after I punched in the last panel code digit. But now when I attempt to turn the tv on I am stuck in a boot loop with a blinking LED .. (it goes first a short flash LED on as it is powering on the display, then follows a code; 1 blink ---pause--- 2 blinks and a restart some 5 seconds after.
                              • DutchDIY
                                • Feb 2022
                                • 51
                                • Nederland
                                #35
                                Any other idea?
                                • lotas
                                  • Jan 2016
                                  • 4753
                                  • Russia
                                  #36
                                  Did you enter the correct code? Download the service manual, I posted it in post 10 and see the error codes and how to see the SDM error code.
                                  • Diah
                                    • Feb 2013
                                    • 6438
                                    47PFL6678K & 60PFL8708S MB als HW are same... but the TV info are different which the panel code of the 60 will not match model No of the replacement MB.
                                    if SDM didn't come on and displaying on screen. then you have only way to put yours old MB SPI on the new one and run firmware downgrade or upgrade to have the TV fixed.
                                    • DutchDIY
                                      • Feb 2022
                                      • 51
                                      • Nederland
                                      #38
                                      Really.. that sounds difficult.. I mean I can solder and am somewhat technical but I was hoping for a plug and play fix.. is there really no other way? Maybe find the motherboard from the same model and sell this one?
                                      Also, how to identify the SPI? Is it a difficult job?
                                      • DutchDIY
                                        • Feb 2022
                                        • 51
                                        • Nederland
                                        #39
                                        Also why is it needed to downgrade or upgrade after switching the SPI? Thsnks for your ideas, I appreciate it very much.
                                        • lotas
                                          • Jan 2016
                                          • 4753
                                          • Russia
                                          #40
                                          Originally posted by dutchdiy
                                          really.. That sounds difficult.. I mean i can solder and am somewhat technical but i was hoping for a plug and play fix.. Is there really no other way? Maybe find the motherboard from the same model and sell this one?
                                          Also, how to identify the spi? Is it a difficult job?
                                          spi - 7ct3 25p10vp
                                            MSI Infinite Infinite A 8RD-203DE Infinite i7-8700 Specification for Upgrade or Repair
                                            This specification for the MSI Infinite Infinite A 8RD-203DE can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Infinite Infinite A 8RD-203DE boardview and Infinite Infinite A 8RD-203DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                            09-12-2024, 03:28 PM
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
                                            MSI Infinite A 8RC-292UK Infinite i7-8700 Specification for Upgrade or Repair
                                            This specification for the MSI Infinite A 8RC-292UK can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Infinite A 8RC-292UK boardview and Infinite A 8RC-292UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-12-2024, 03:30 PM
                                            MSI Infinite 8RB-613EU Infinite i5-8400 Specification for Upgrade or Repair
                                            This specification for the MSI Infinite 8RB-613EU can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Infinite 8RB-613EU boardview and Infinite 8RB-613EU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            MSI Infinite A 8RG-097EU Infinite i7-8700 Specification for Upgrade or Repair
                                            This specification for the MSI Infinite A 8RG-097EU can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Infinite A 8RG-097EU boardview and Infinite A 8RG-097EU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
