Philips 60PFL8708S/12 On Infinite Boot Loop No Logo, Only Backlight
  • DutchDIY
    • Feb 2022
    • 51
    • Nederland
    I have another tv with issues, this one remains in an infinite boot loop but won't display a logo or anything, just backlight for some seconds and then a reboot.
    I have added some pics of it's guts.
    Any help is much appreciated, thanks everyone.
    Edit:
    I'm getting 8s of backlight, and smth of a reboot taking 15s to display another 8s of backlight. This repeats itself.
  • Diah
    • Feb 2013
    • 6497
    Re: Philips 60PFL8708S/12 On Infinite Boot Loop No Logo, Only Backlight
    wow... can you check is this MB really QF2EU chassis ?? it coast before 8 years more than 3000 €
    • DutchDIY
      • Feb 2022
      • 51
      • Nederland
      I picked this up for free 🙈. With remote and wall support even.
      • Diah
        • Feb 2013
        • 6497
        check if the MB chassis QF2EU if yes.. then you have on the MB test point SDM shorted with chassis and then plug it in wall it should pass the fault and display diagnostic report
        • lotas
          • Jan 2016
          • 4803
          • Russia
          Chassis QFU1.2E LA
          • Diah
            • Feb 2013
            • 6497
            Originally posted by lotas
            Chassis QFU1.2E LA
            cant be QFU1.2E LA ... xxPFL8708S are Fusion R2 – QF2EU
            • lotas
              • Jan 2016
              • 4803
              • Russia
              https://www.badcaps.net/forum/showthread.php?t=75843
              • lotas
                • Jan 2016
                • 4803
                • Russia
                The weak point in PHILIPS TV models assembled on the QFU1.2E LA chassis is the main SSB board (MainBoard), which usually fails after two years of operation. Its replacement is required.
                The cost of the board is quite high, which sometimes raises the question of the feasibility of repairs.
                Despite the efforts of the designers to make it difficult or eliminate the possibility of repairing the board, there are still options for restoring it.
                Attention masters!!! You should pay attention to the drops of the compound from the bottom of the board. When trying to heat the board or reball BGA chips, the compound must be completely removed. Otherwise, there will be a short circuit of the tracks, which will significantly complicate further repair of the board.
                • Diah
                  • Feb 2013
                  • 6497
                  wrong info. he wrote what are on sticker as region chassis. the main chassis code we used Fusion R2 – QF2EU from 2013 not 2014 as he wrote
                  look on philips firmware archive by toengel under 2013 – xxPFLxxx8
                  • lotas
                    • Jan 2016
                    • 4803
                    • Russia
                    • Diah
                      • Feb 2013
                      • 6497
                      hahaha... man you are still searching.. to let you satisfied download this firmware and inspect it. it is QF2EU-0.173.45.0 (Date published: 2014-01-29)
                      Code:
                      2022 – xxPXXxxx7 / xxOLEDxx TPM211EA
                      2021 – xxPXXxxx6 / xxOLEDxx6 TPM211EA, TPM215E, TPN216E
                      2020 – xxPXXxxx5 / xxOLEDxx5 TPM191E, TPM206E, TPM207E, TPN206E, TPS191E
                      2019 – xxPXXxxx4 / xxOLEDxx4 TPM191E, TPM196E, TPS191E
                      2018 – xxPXXxxx3 / xxOLEDxx3 TPM171E, TPM186E, TPM187E
                      2017 – xxPXXxxx2 TPM171E, TPM172E, TPM177E, TPN171E
                      2016 – xxPXXxxx1 QM161E, QM163E, QM164E
                      2015 – xxPXXxxx0 QM151E, QV151E, QM152E, TPN151E, TPN152E, TPM156E
                      2014 – xxPXXxxx9 TPN149E, TPN141E, QN141E, QN143E, AND1E
                      2013 – xxPFLxxx8 QF2EU, TPM1013E, TPM1012E,
                      2012 – xxPFLxxx7 QF1EU, Q554E / Q554M,
                      2011 – xxPFLxxx6 Q5551 / Q5553
                      2010 – xxPFLxxx5 Q5551 / Q5553, TPM51E
                      2009 – xxPFLxxx4 Q5481
                      • lotas
                        • Jan 2016
                        • 4803
                        • Russia
                        But QF2EU is not a chassis number, it is the initial firmware name (QF2EU xxxx xxxx) for the QFU1.2E LA chassis.
                        • DutchDIY
                          • Feb 2022
                          • 51
                          • Nederland
                          Is my best bet to find a replacement main board?
                          Or should I reflow it?
                          • Diah
                            • Feb 2013
                            • 6497
                            lotas you are clever... read the table 3 chassis are in 2013 share one firmware.
                            look on the boards self. tv chassis are different from MB code. this why i asked on the MB code not the TV chassis. because he had boot and no error code BL come on and off.. are absoult different from BGA issue to the post you linked where i asked him from start to do BGA
                            • Diah
                              • Feb 2013
                              • 6497
                              dont kill your tv as you did with samsung... download first the firmware and downgrade it,,, if your screen come on with upgrade every things will be fine. if not you need to check the BL if they come high and low at start up... if they are fine then go to BGA
                              • DutchDIY
                                • Feb 2022
                                • 51
                                • Nederland
                                Will try the firmware with USB stick, I have to buy a USB stick first lol. Thanks!
                                • lotas
                                  • Jan 2016
                                  • 4803
                                  • Russia
                                  Mainboard 3104 303 54946 B
                                  3104 313 66186 B
                                  • lotas
                                    • Jan 2016
                                    • 4803
                                    • Russia
                                    Look, not with all usb flash drives the update will start (they just won't be seen by the TV), you need to look for old ones for 1-2 Gb
                                    • DutchDIY
                                      • Feb 2022
                                      • 51
                                      • Nederland
                                      I found one in my drawer, 4gb, will try.
                                      • Diah
                                        • Feb 2013
                                        • 6497
                                        the USB should be bootable MBR ..
                                        how to do USB stick MBR with windows DISKPART
                                        Code:
                                        Open command terminal and type DISKPART
                                        # Show all disks (aka drives, like hard drives or removable media).
                                        DISKPART> list disk
                                        # Select a disk to operate on.
                                        DISKPART> select disk [number identifying USB flash drive]
                                        # Delete all partitions, resulting in a blank disk.
                                        DISKPART> clean
                                        # If the USB drive is using the GPT layout, the "list disk" command output
                                        # above will show an asterisk in the last "Gpt" column. If this is the
                                        # case, issue this command to change it to the MBR layout.
                                        DISKPART> convert mbr
                                        # Create a primary partition (using MBR).
                                        DISKPART> create partition primary
                                        # Show all partitions (should just be the one newly-created partition).
                                        DISKPART> list partition
                                        # Select the primary partition to operate on (only 1 partition exists).
                                        DISKPART> select partition 1
                                        # Make the primary partition active (aka bootable).
                                        # This command will fail if the USB drive is using the GPT layout.
                                        DISKPART> active
                                        # Format the active primary partition using FAT32.
                                        # To do a full format, instead of a quick format, omit the "quick" flag.
                                        DISKPART> format fs=fat32 quick
                                        # Assign a drive letter to the primary partition
                                        # (just in case Windows didn't already do it).
                                        DISKPART> assign
                                        # Quit DiskPart.
                                        DISKPART> exit
                                          MSI Infinite Infinite A 8RD-203DE Infinite i7-8700 Specification for Upgrade or Repair
                                          This specification for the MSI Infinite Infinite A 8RD-203DE can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Infinite Infinite A 8RD-203DE boardview and Infinite Infinite A 8RD-203DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-12-2024, 03:28 PM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                          MSI Infinite A 8RC-264EU Infinite i7-8700 Specification for Upgrade or Repair
                                          This specification for the MSI Infinite A 8RC-264EU can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Infinite A 8RC-264EU boardview and Infinite A 8RC-264EU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:30 PM
                                          MSI Infinite 8RB-613EU Infinite i5-8400 Specification for Upgrade or Repair
                                          This specification for the MSI Infinite 8RB-613EU can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Infinite 8RB-613EU boardview and Infinite 8RB-613EU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          MSI Infinite A 8RE-287EU Infinite i7-8700 Specification for Upgrade or Repair
                                          This specification for the MSI Infinite A 8RE-287EU can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Infinite A 8RE-287EU boardview and Infinite A 8RE-287EU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
